Beta2 tools build problem
Mike Davies mikert at noco.demon.co.uk
Mon May 1 20:01:45 UTC 2000
Hi,
I am trying to build the tools for an i386-elf build of RTEMS but I'm
not having any luck.  I'm using NT4.0 SP4 to host Cygwin beta 20.1
upgraded with native gcc-2.95.2.
I've downloaded the versions of binutils, gcc.2.95.2, newlib-1.8.2 that
are in the beta directory and patched them OK.
I first tried to use the ./bit script,  but this crashes out very early
in its run,
Then I tried the old method (David Fiddes ?) in one of the old versions
of the docs, binutils compiles fine using this method,  but the gcc
build crashes out with a unresolved reference to stdio.h.
Does anyone know any special tricks that are required to get the
i386-elf tools to build under cygwin ?   Has the ./bit script worked for
anyone else here under Cygwin ?
Thanks a lot,
Mike Davies
