FWD:"make clean all" broken on Beta2 ???
Smith, Gene
Gene.Smith at sea.siemens.com
Mon May 1 19:34:23 UTC 2000
-----Original Message-----
Sent: Monday, May 01, 2000 1:16 PM
"Smith, Gene" wrote:
> Matt,
> I thought you mentioned something about the makefiles not working on
> clean/all. When I am in netdemo and type "make clean all" like before it
does
> not work. Do you know what the deal is? I have looked at the Makefile (at
> least the top level Makefile in netdemo) and it looks basically like the
old
> one from 4.0.0. Do you know why they might have they changed/broken this?
There are two copies of leaf.cfg in the beta, in c/src/make/leaf.cfg and
make/leaf.cfg. The one with the latest timestamp, the one in src, gets
installed (last maybe?).
If you copy make/leaf.cfg over the one that got installed, everthing
works fine.
Matt
I replaced the shorter install/make/leaf.cfg with the longer
tools/rtems-4.5.0-beta2/make/leaf.cfg and now "make clean" and "make clean
all" seem to work as in 4.0.0.
I also noticed that the dependency to networkconfig.h is not seem when a
"make" is done in netdemo, ttcp etc. You have to do a "make clean all" for
the change to networkconfig.h to be picked up.
-Gene
