4.5.0 B2 configure fun
Thu May 11 11:25:03 UTC 2000
Nick.SIMON at syntegra.bt.co.uk wrote:
> Dear chaps,
> I'm doing:
> ../rtems-4.5.0-beta2/configure --target=powerpc-rtems --disable-posix
> --disable-itron --enable-cxx --enable-rtemsbsp="eth-comm"
> and getting lots of other stuff followed by:
> checking for Cygwin environment... no
> checking for mingw32 environment... no
> checking for executable suffix... configure: error: installation or
> configuration problem: compiler cannot create executables.
> configure: error: ../../../rtems-4.5.0-beta2/tools/build/configure failed
> for tools/build
> I've got powerpc-rtems-gcc and the binutils in the path, build path (where
> I/m running the configure) is /home/rtems/build.
> Any ideas?
What host are you on again?  Is the native compiler
named "cc" or "gcc"?
Try CC=gcc .../configure ....
> -- Nick Simon
