netdemos-4.5.0-beta3 build fails under rtems-4.5-beta3 for m68k (gen68360)
OUTWATER vac4050 at cae597.rsc.raytheon.com
Thu May 18 23:30:26 UTC 2000
All -
Had this problem under rtems-4.5-beta2 also.
I've sucessfully built all of the beta3 c_tools as well as the beta3 of RTEMS on a stock
Redhat 6.2 x86 system.
Invoking make in the netdemo directory produces:
darkstar:/home/vac4050/projects/netdemos-4.5.0-beta3/netdemo> make
test -d o-optimize || mkdir o-optimize
/home/vac4050/usr/local/rtems/bin/m68k-rtems-gcc --pipe
-B/home/vac4050/usr/local/rtems//gen68360/lib/ -specs bsp_specs -qrtems -g -Wall -ansi -fasm
 -O4 -fomit-frame-pointer       -mcpu32      -c   -o o-optimize/init.o init.c
 -O4 -fomit-frame-pointer       -mcpu32      -c   -o o-optimize/test.o test.c
make: *** No rule to make target `/home/vac4050/usr/local/rtems//gen68360/lib/librtemsall',
needed by `o-optimize/netdemo.exe'.  Stop.
I followed up "m ds <mdsdm at yahoo.com>"'s suggestion, but the fix described in the archive
appears to have already been applied to RTEMS beta3.
Does anyone else using the gen68360 BSP have this problem?
Thanks,
Keith
