Lower defaults in confdefs.h
Fri May 19 12:18:10 UTC 2000
I have been mulling over lowering some of the default values
in confdefs.h to reduce executive workspace size.  In particular,
these default too high for most applications:
CONFIGURE_MAXIMUM_TASKS - Classic API tasks defaults to 10
CONFIGURE_MAXIMUM_POSIX_THREADS - POSIX threads defaults to
  10 when POSIX API is enabled
CONFIGURE_MAXIMUM_ITRON_TASKS - ITRON tasks defaults to
  10 when ITRON API is enabled
CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS is the number of
  file descriptors and defaults to 20.
Remember each task configured results in stack space
being reserved so 30 tasks can be a LOT of memory.
I think the defaults for tasks/threads should be 0 thus
forcing the application to specify an appropriate number.
I think the default number of file descriptors should
be 3 to support stdin, stdout, and stderr.
I am also open to discussion as to whether
CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM should be the default.
This reduces the functionality of the IMFS to be comparable
to the functionality in version 4.0 -- device nodes.
I bring this up now because if the defaults are to change it
should happen before a major release to avoid getting more
applications dependent on the higher defaults.
Comments appreciated.
