RTEMS monitor and other information
Joel Sherrill
joel.sherrill at OARcorp.com
Fri May 19 11:07:20 UTC 2000
John Bebbington wrote:
> Hi,
> I am having trouble trying to locate a real-time crash of my system and need
> to get some information about the state of
> RTEMS kernel, stack usage and processor register values while the sw is
> running. I have no Debbuger capabilties on the target, only printf.
> How can I get access to this information please, and where do I find
> documentation about the RTEMS monitor.
What documentation there is for the monitor is in READMEs in
the same directory as the code (c/src/libmisc/monitor).
Running with the stack checker enabled might trip it.
Also using the debug variant might point it out. The run-time
checks might spot something.
What target CPU/BSP and RTEMS version are you on?
joel at OARcorp.com On-Line Applications Research
