cannot create executables
Daniel Talayco
dtalayco at broadcom.com
Thu May 25 23:34:58 UTC 2000
This is likely a stupid problem with my installation....but I can't see it yet.
bit ran to completion building the tools.
Shortly after starting bit_rtems, I got 'cannot create executables'. From the log:
../rtems-4.5.0-beta3/configure --target=powerpc-rtems --prefix=/export/home/det/tools/cross/gcc-2.95.2-newlib-1.8.2-rtems-4.5.0-beta3 --disable-hwapi --disable-multiprocessing --enable-cxx --enable-rdbg --enable-tests --enable-networking --enable-posix --disable-itron
creating cache ./config.cache
creating doc/Makefile
configuring in tools/build
running /bin/sh ../../../rtems-4.5.0-beta3/tools/build/configure --target=powerpc-rtems --prefix=/export/home/det/tools/cross/gcc-2.95.2-newlib-1.8.2-rtems-4.5.0-beta3 --disable-hwapi --disable-multiprocessing --enable-cxx --enable-rdbg --enable-tests --enable-networking --enable-posix --disable-itron --cache-file=../.././config.cache --srcdir=../../../rtems-4.5.0-beta3/tools/build
checking whether to enable maintainer-specific portions of Makefiles... no
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... configure: error: installation or configuration problem: compiler cannot create executables.
configure: error: ../../../rtems-4.5.0-beta3/tools/build/configure failed for tools/build
Could not successfully configure into build-powerpc-rtems!
This is all with the fresh new 4.5.0beta3 sources building under SunOS5.6.
Any help appreciated.
-Dan
