rtems-4.5.0-beta/c_tools build error
gerke.kok at ascom.nl gerke.kok at ascom.nl
Thu May 4 06:12:32 UTC 2000
There is an other way to build thing. When you download the rpm's from:
	ftp.rtems.com/pub/....../c_tools/...
then you only have to build RTEMS it self. This goes very well and takes of
a whole load of trouble building the GNU tools and compilers!
wkr,
Gerke
> -----Original Message-----
> From: Stephan Wilms [mailto:Stephan.Wilms at CWA.de]
> Sent: Tuesday, May 02, 2000 09:54
> To: rtems-users at oarcorp.com
> Subject: Re: rtems-4.5.0-beta/c_tools build error
> Hi Eli Kozikaro,
> > I'm using  RedHat 6.2 and  rtems-4.5.0-beta.
> > I untared the  tools and applied the patches then I ran ./bit m68k
> > The ./bit m68k build did not complete  (see error messages bellow).
> > I was able to complete the build when I added the install point
> > (/usr/local/rtems/bin ) to the PATH environment variable.
> > I wonder if this is a bug or am I missing a step.
> It apears to be a bug, or at least an omission in the "bit"
> script. As
> far as I know OAR is looking into this (I reported this last week).
> Your fix is correct: when you want to use the current "bit"
> script you
> must add the <INSTALL_POINT>/bin subdirectory to the PATH.
> OAR says they'll put a fix right into the "bit" script, so this won't
> be needed with future releases.
> Greetings,
> Stephan Wilms (stephan.wilms at cwa.de)
> CWA-GmbH, Aachen, Germany
