FW: procedure for building rtems-4.5.0beta2
Mike Davies
mikert at noco.demon.co.uk
Thu May 4 19:18:05 UTC 2000
>> and it gave me more details about the problem. ( Turned out that it was
>> using 'cc', not 'gcc', so I just set $CC=gcc, though that probably isn't
>> your problem. )
>Then it may be interesting for you to hear that it may very likely be
>the same problem under Solaris and Cygwin :) Both by default do not have
>a working cc.
>Under Cygwin it is missing, under Solaris cc is a script which returns
>false if you don't have Sun's cc installed.
>Ralf.
Well I tried setting $CC=gcc in the configure script, but that didn't
help at all.
Thanks,
Mike Davies
