tool update was Re: Posix missing?/timercmp
Joel Sherrill
joel.sherrill at OARcorp.com
Mon May 15 11:08:54 UTC 2000
There were two issues that required an updated to the
RTEMS gcc and newlib patches:
1. In order to be able to support the multi-threading
support in the C++ libraries, it was necessary
to move pthread.h to newlib. This makes it
visible at tool build time and thus standard
language libraries can use the services.
2. timercmp (and a couple of others) are BSD-ish
routines sometimes found on other systems. They
were needed to support including the nearly
complete RPC/XDR support.
You need to build new gcc/newlib or grab the RPMs.
gerke.kok at ascom.nl wrote:
> Hello,
> I try to build the beta3 of RTEMS with BSP=gen68360 and get the failure:
> [/usr/src/beta3/m68k-rtems/c/gen68360/exec/posix/src]$ make
> /opt/rtems/bin/m68k-rtems-gcc --pipe -B../../../../../../gen68360/lib/
> -specs bsp_specs -qrtems
> -g -Wall -ansi -fasm -mcpu32 -c -D__RTEMS_INSIDE__ -O4
> -fomit-frame-pointer -o o-optimi
> ze/adasupp.o
> ../../../../../../../rtems-4.5.0-beta3/c/src/exec/posix/src/adasupp.c
> ../../../../../../../rtems-4.5.0-beta3/c/src/exec/posix/src/adasupp.c:7:
> pthread.h: No such fil
> e or directory
> make: *** [o-optimize/adasupp.o] Error 1
> The strange thing is: I did build the beta2 with great succes. What's
> changed that this does nog work anylonger?
> wkr,
> Gerke
joel at OARcorp.com On-Line Applications Research
