tool update was Re: Posix missing?/timercmp
gerke.kok at ascom.nl
Mon May 15 11:21:01 UTC 2000
Where do I get the RPMS? I do like the way the RPMS are available at
ftp.rtems.com buf these are not different from the ones I downloaded for
beta2.
I have downloaded:
m68k-rtems-chill-gcc2.95.2newlib1.8.2-4.i386.rpm etc. etc.
Do I need a newer one? Where do I get it?
wkr,
Gerke
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> Sent: Monday, May 15, 2000 13:09
> To: gerke.kok at ascom.nl
> Cc: rtems-users at OARcorp.com
> Subject: tool update was Re: Posix missing?/timercmp
> There were two issues that required an updated to the
> RTEMS gcc and newlib patches:
> 1. In order to be able to support the multi-threading
> support in the C++ libraries, it was necessary
> to move pthread.h to newlib. This makes it
> visible at tool build time and thus standard
> language libraries can use the services.
> 2. timercmp (and a couple of others) are BSD-ish
> routines sometimes found on other systems. They
> were needed to support including the nearly
> complete RPC/XDR support.
> You need to build new gcc/newlib or grab the RPMs.
> gerke.kok at ascom.nl wrote:
> > Hello,
> > I try to build the beta3 of RTEMS with BSP=gen68360 and get
> the failure:
> > [/usr/src/beta3/m68k-rtems/c/gen68360/exec/posix/src]$ make
> > /opt/rtems/bin/m68k-rtems-gcc --pipe
> -B../../../../../../gen68360/lib/
> > -specs bsp_specs -qrtems
> > -g -Wall -ansi -fasm -mcpu32 -c -D__RTEMS_INSIDE__ -O4
> > -fomit-frame-pointer -o o-optimi
> > ze/adasupp.o
> ../../../../../../../rtems-4.5.0-beta3/c/src/exec/posix/src/adasupp.c
> asupp.c:7:
> > pthread.h: No such fil
> > e or directory
> > make: *** [o-optimize/adasupp.o] Error 1
> > The strange thing is: I did build the beta2 with great
> succes. What's
> > changed that this does nog work anylonger?
> > wkr,
> > Gerke
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
