Adding bsp to beta3
Mon May 15 15:51:00 UTC 2000
Ralf Corsepius wrote:
> Nick.SIMON at syntegra.bt.co.uk wrote:
> > According to README.configure, configure.in has to be modded to add a new
> > BSP, and autoconf used to re-generate configure.  I had shuftie at
> > configure.in, but it was all greek to me.  Any suggeations on this, and on
> > running autoconf?
I would also add to Ralf's that there are likely to be places in the
documentation
that do not refer to Makefile.am's and configure.in's in the lower level
directories
as these are VERY new.  Please report these documentation problems when
you
find them.
> Start with a BSP resembling to yours, and use its configuration as a
> template for yours.
> Further RTEMS specific information can be found inside of RTEMS'
> source-tree at
> c/src/lib/libbsp/MERGE.PROCEDURE
> and on OAR's ftp site
> ftp://ftp.oarcorp.com/pub/rtems/betas/rtems-4.5.0-beta/contrib/4.5-build-FAQ/rtems-FAQ-0.2.tar.gz
> [Both documents are rather incomplete, but should provide enough
> information to get you started]
> General information about auto*-tools:
> info automake
> info autoconf
> Ralf
> Ralf Corsepius
> Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
> (FAW)
> Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
> mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
> http://www.faw.uni-ulm.de
