Java ports to RTEMS
Joel Sherrill
joel.sherrill at OARcorp.com
Wed May 17 18:03:41 UTC 2000
Rosimildo da Silva wrote:
> Hi,
> How are these beasts coming along ?
> + JGC
> Where can I get the files to play around with this one ?
> Once beta3 toolset has included the proper thread support
> for exceptions, Can I build the toolset with java support ?
The RPMs include gjc so you should not have to build it unless
you are working on fixing something. This is the list of RPMs
for the "revision 6" of the gccnewlib set:
rtems-base-gcc-gcc2.95.2newlib1.8.2-6.i386.rpm
i386-rtems-chill-gcc2.95.2newlib1.8.2-5.i386.rpm
i386-rtems-g77-gcc2.95.2newlib1.8.2-5.i386.rpm
i386-rtems-gcc-gcc2.95.2newlib1.8.2-5.i386.rpm
i386-rtems-gcj-gcc2.95.2newlib1.8.2-5.i386.rpm
i386-rtems-objc-gcc2.95.2newlib1.8.2-5.i386.rpm
Install the base RPM and gcc-gcc one, then you
can install the optional languages. The gjc one
is the one you are interested in.
WARNING: I have no idea how well any of the secondary
languages work. As people use them, they will
improve.
> Any URL where I can read a bit about it ?
gcc.gnu.org to find out what is really in
gcc 2.95.2. It would not surprise me to find
out that it is immature and that you need add-on
libraries.
> + Kaffe
> Rosimildo.
joel at OARcorp.com On-Line Applications Research
