Java ports to RTEMS
Joel Sherrill
joel.sherrill at OARcorp.com
Thu May 18 01:57:09 UTC 2000
Joel Sherrill wrote:
> Rosimildo da Silva wrote:
> > Hi,
> > How are these beasts coming along ?
> > + JGC
> > Where can I get the files to play around with this one ?
> > Once beta3 toolset has included the proper thread support
> > for exceptions, Can I build the toolset with java support ?
> The RPMs include gjc so you should not have to build it unless
> you are working on fixing something. This is the list of RPMs
> for the "revision 6" of the gccnewlib set:
> rtems-base-gcc-gcc2.95.2newlib1.8.2-6.i386.rpm
> i386-rtems-chill-gcc2.95.2newlib1.8.2-5.i386.rpm
> i386-rtems-g77-gcc2.95.2newlib1.8.2-5.i386.rpm
> i386-rtems-gcc-gcc2.95.2newlib1.8.2-5.i386.rpm
> i386-rtems-gcj-gcc2.95.2newlib1.8.2-5.i386.rpm
> i386-rtems-objc-gcc2.95.2newlib1.8.2-5.i386.rpm
Ralf caught a typo in the above set .. You need to use the same
revision across all gcc2.95.2newlib1.8.2 packages. :)
Also I should have once again pointed out that
the "revision 5" has the patches to enable
multithreaded safe support in gcc language libraries
but it is NOT enabled. That was an accident.
> Install the base RPM and gcc-gcc one, then you
> can install the optional languages. The gjc one
> is the one you are interested in.
> WARNING: I have no idea how well any of the secondary
> languages work. As people use them, they will
> improve.
> > Any URL where I can read a bit about it ?
> gcc.gnu.org to find out what is really in
> gcc 2.95.2. It would not surprise me to find
> out that it is immature and that you need add-on
> libraries.
> > + Kaffe
> > Rosimildo.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
