PDF for beta3 docs available
Erwin Rol
320094152587-0001 at t-online.de
Tue May 23 11:27:49 UTC 2000
Joel Sherrill wrote:
> Erwin Rol wrote:
> > Try Acroread 4 , i think i can remeber i had some problem with
> > "blackholes" in other document too when using AR3.
> > BTW.
> > some of the text in the index seems wrong.
> Could you cite the specific text? It is easy to fix that once
> you know where to look.
hmmm good point :-)
all with acroread 4
for example:
started.pdf
bookmarks header
Building the GNU C/C{@char 43}{@char 43} Cross Compiler Toolset
actual header in text
Building the GNU C/C++ Cross Compiler Toolset
I saw it in a other doc too but can't find it anymore :-)
- Erwin
> > - Erwin
> > Mike Davies wrote:
> > > Hi,
> > > Unless it's just me, they seem to have parts that print as blocked out text
> > > ? (I mean that an occasional line or so is completely overwritten with
> > > "black space"). They seem to view OK under Acrobat 3, it's only printing
> > > them off that gives me a problem.
> > > Mike Davies
> > > Senior Software Engineer
> > > Eurotherm Process Automation Ltd
> > > Southdownview Way
> > > Worthing
> > > West Sussex BN14 8NN
> > > Tel:- 44 (0) 1903 205277
> > > Fax:- 44 (0) 1903 524016
> > > mike.davies at epid.eurotherm.co.uk
> > > >ftp://ftp.oarcorp.com/pub/rtems/betas/rtems-4.5.0-beta/docs
> > > >I know there have been a lot of requests for these.
> > > >Please comment on them. When possible, do more than comment
> > > >and send in text. :)
> > > >Joel Sherrill, Ph.D. Director of Research & Development
> > Q - S O F T - E N G I N E E R I N G
> > Rodachtalweg 11, 81549 Muenchen, Germany
> > Erwin Rol (Software Engineer) phone: +49-89-68050051
> > Erwin.Rol at Q-Soft-Engineering.com fax : +49-89-68050052
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
