PDF for beta3 docs available
Joel Sherrill
joel.sherrill at OARcorp.com
Tue May 23 14:42:43 UTC 2000
Erwin Rol wrote:
> Joel Sherrill wrote:
> > Erwin Rol wrote:
> > > Try Acroread 4 , i think i can remeber i had some problem with
> > > "blackholes" in other document too when using AR3.
> > > BTW.
> > > some of the text in the index seems wrong.
> > Could you cite the specific text? It is easy to fix that once
> > you know where to look.
> hmmm good point :-)
> all with acroread 4
> for example:
> started.pdf
> bookmarks header
> Building the GNU C/C{@char 43}{@char 43} Cross Compiler Toolset
> actual header in text
> Building the GNU C/C++ Cross Compiler Toolset
> I saw it in a other doc too but can't find it anymore :-)
Now I know what you are talking about. This is the
left hand side index shown in Acrobat. It is generated
automatically by texinfo based on the table of contents.
I thought you were referring to a concept of function
index.
You will see this in EVERY document. This is a bug
in texinfo IMO. Every section header with an _
or apparently a "+" in it gets translated to that awful
stuff.
joel at OARcorp.com On-Line Applications Research
