Problem compiling C++ package
Rosimildo da Silva
rdasilva at connecttel.com
Fri May 26 16:00:25 UTC 2000
Alexey wrote:
> ----- Original Message -----
> From: Rosimildo daSilva <rdasilva at connecttel.com>
> To: Alexey <alexey at vocord.com>; <rtems-users at oarcorp.com>
> Sent: Thursday, May 25, 2000 9:59 PM
> Subject: Re: Problem compiling C++ package
> > From: Alexey <alexey at vocord.com>
> > To: rtems-users at oarcorp.com <rtems-users at oarcorp.com>
> > Date: Thursday, May 25, 2000 10:33 AM
> > >> C++ folks... I have made a couple of suggestions to
> > >> Alexey on this but I thought you folks might know more. :)
> > >> He is porting a VERY interesting add-on to RTEMS. If
> > >> he wants to tip his hand with a URL, then I will give
> > >> him that privilege. :)
> > >I'm trying to port openh323 (www.openh323.org ) to RTEMS
> > >I build it with a lots of stub and now trying to build somthing like
> "hello
> > >h323"
> > >but without success up till now.
> > >As soon as I try call somthing from librtemsh323 (it's openh323 by
> itself)
> > I
> > >recieve somthing like that:
> > Alexey,
> > This seems to be a very good add-on to RTEMS. You need to define the
> > confuguration for the network. It'll be better if you start with the
> > netdemos
> > programs to get familiar with the details. You would have to change some
> > parameters to match your environment ( IP, GateWay, etc ).
> > If you have trouble with that, I can send my network configuration files.
> > They're have been tested for PC386, but that should not matter.
> > Rosimildo.
> Thank you for interest, but it's only my distraction.
> As soon as I add my network configuration it linked immediately.
> But there are some problems any way..
> As far as I remember a time ago we talk about C++ exceptions.
> Unfortunatly I did't have enough time to "dig" with them, but in rtems-4.5.0
> there are still not working for me.Well, cdtest gives me
> *** END OF CONSTRUCTOR/DESTRUCTOR TEST ***
> and hangs.
Well, it looks like C++ exceptions are not working for you.
Try to increase the size of the stack of the init task.
If that does not help, comment out the exception code
and check if the test completes ok. If it does, then
you isolated a problem to C++ exceptions.
> And one more question about network:
> Do you use loopback interface?
I have not use it myself, but I guess recent
network demos, has examples on how to use it.
Rosimildo.
