binmode mount was Re: CygWin - RPMS --- problems --- follow up -- Success
Fri May 26 17:47:11 UTC 2000
Rosimildo da Silva wrote:
>  !!! ARGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH !!!!!!!!!
> It is the f@#$ing CygWin 1.1 that is causing problems.
> It installs the "/" mount point as binmode. I created
> a directory underneath it for RTEMS development, and it
> behaves in "binmode" as well. This makes some tools to
> behave very strange.
I have run into this before.  It is VERY confusing.  I saw
random Makefile problems. :(
> I had to mount a new mount point for RTEMS development
> in "textmode". Reconfigured it again, and now everything compiles fine.
> Finally, I have got beta3 working and using the RPMS for Cygwin.
> NOTE: After I apply some patches to the code, and had to
> "bootstrap" it again, I've got this error. It does not
> seem to affect what I am doing, but it would be nice to
> have it corrected.
> bash-2.03$ ./bootstrap
> ./c
> ./c/make
> ./c/src
> ./c/src/exec
> ./c/src/exec/itron
> ./c/src/exec/posix
> ./c/src/exec/score/cpu/a29k
> ./c/src/exec/score/cpu/hppa1.1
> ./c/src/exec/score/cpu/i386
> ./c/src/exec/score/cpu/i960
> ./c/src/exec/score/cpu/m68k
> ./c/src/exec/score/cpu/mips64orion
> ./c/src/exec/score/cpu/no_cpu
> ./c/src/exec/score/cpu/powerpc
> ./c/src/exec/score/cpu/sh
> ./c/src/exec/score/cpu/sparc
> ./c/src/exec/score/cpu/unix
> ./c/src/lib
> makefile.am:8: variable `LIBHWAPI' not defined
> ./c/src/lib/libbsp/a29k
> ./c/src/lib/libbsp/a29k/portsw
> Rosimildo.
> > I have got the a compilation problem, after getting the
> > RPMS installed last night. The bsp_specs fie is there on its
> > usual place. I have ran "dos2unix" on it just in case,
> > but it did not help.
> > NOTE: I am using CygWin 1.1, and this could be the reason that
> > I am facing a few problems.
> > Rosimildo.
> > make[8]: Nothing to be done for `all-am'.
> > make[8]: Leaving directory
> > `/tools/build-i386-rtems/i386-rtems/c/pc386/exec/scor
> > e/cpu/i386/rtems'
> > make[7]: Leaving directory
> > e/cpu/i386/rtems'
> > make[7]: Entering directory
> > re/cpu/i386'
> > /opt/rtems/bin/i386-rtems-gcc --pipe -B../../../../../../.././pc386/lib/
> > -specs
> > bsp_specs -qrtems -g -Wall -ansi -fasm         -c  -O4 -o
> > o-optimize/cpu.o ../..
> > /../../../../../../rtems-4.5.0-beta3/c/src/exec/score/cpu/i386/cpu.c
> > i386-rtems-gcc: bsp_specs: No such file or directory
> > make[7]: *** [o-optimize/cpu.o] Error 1
> Rosimildo da Silva            rdasilva at connectel.com
> ConnectTel, Inc.              Austin, TX -- USA
> Phone : 512-338-1111          Fax : 512-918-0449
> Mobile: 512-632-7579
> Company Page: http://www.connecttel.com
> Home Page: http://members.xoom.com/rosimildo/
