rtems++ failure help....
Sat May 27 18:48:46 UTC 2000
"John S. Gwynne" wrote:
> | > I'm trying to make progress in understanding why the rtems++ test program
> | > (beta3) fails on the efi332 (m68332) target.
> <delete>
> | > The virtual pointer table (_vptr) is zero, which leads to my "bus
> | > error" when the virtual function task->body is resolved and
> | > executed (I think :).
> | Looking at the code, Task1 is a global object. If you do not run static
> | constructors this test will fail. Maybe the test code should check for
> | this case.
> And that is indeed the case.  Turns out bootcard was not calling _init
> which was not calling the appropriate constructor... easy fix... add
> "AM_CPPFLAGS = -DUSE_INIT_FINI" to startup/Makefile. Now onto the
> problem in sp28...
Does this mean that ALL m68k BSPs need to have this turned on?
Comments appreciated before I do something broad. :)
> john gwynne
