top level build problem c instead of "TARGET/c"
Frank Szczerba
frank at wmi.com
Wed May 31 13:20:55 UTC 2000
The Solaris sed does not understand the '\+' construct. The translation
could be done with sed under Solaris as either:
> echo c x xyzzy | /bin/sed -e 's%\([^ ]*\)%sparc-rtems/\1%g'
sparc-rtems/x sparc-rtems/x sparc-rtems/xyzzy
or (probably more correctly):
> echo c x xyzzy | /bin/sed -e 's%\([^ ]\{1,\}\)%sparc-rtems/\1%g'
Also, on the topic of top level build problems, the 'bit' script in
c_build_scripts-4.5.0-beta3.tgz does not check for success when it builds
the binutils. If the binutils make fails bit removes the build directory and
goes on to building gcc, which will of course fail without the binutils. My
fix was:
*** orig/bit Mon May 8 14:43:20 2000
--- tools/bit Tue May 16 14:57:41 2000
*** 163,168 ****
--- 163,169 ----
echo "**** SKIPPING BUILD OF BINUTILS ****"
else
${MAKE} all ${MAKE_DOCS} install
+ check_fatal $? "**** FAILED **** base build (binutils)"
fi
cd ..
This seems to make things better. I also ran into a problem building gcc. At
some point it wants to do a fix-includes or something similar in the target
directory, but there are no include files there so it fails. It seems that
creating an empty $(INSTALL_POINT)/mips64orion-rtems/include directoy fixes
it. Perhaps this should be done in the bit script?
Last point (I promise): in
rtems-4.5.0-beta3/c/src/exec/sapi/include/confdefs.h it seems the console.h
should be included if CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER is defined
and clockdrv.h included if CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER is
defined:
*** orig/rtems-4.5.0-beta3/c/src/exec/sapi/include/confdefs.h Fri May 5
08:57:14 2000
--- tools/rtems-4.5.0-beta3/c/src/exec/sapi/include/confdefs.h Wed May 24
16:08:50 2000
*** 216,221 ****
--- 216,228 ----
#include <stubdrv.h>
#endif
+ #ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+ #include <console.h>
+ #endif
+ #ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+ #include <clockdrv.h>
+ #endif
#ifndef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
#ifdef CONFIGURE_INIT
Frank Szczerba
Development Engineer
Woodward McCoach Inc
frank at wmi.com
-----Original Message-----
To: rtems-users at oarcorp.com <rtems-users at oarcorp.com>; Ralf Corsepius
<corsepiu at faw.uni-ulm.de>
Date: Thursday, May 25, 2000 3:33 PM
Subject: top level build problem c instead of "TARGET/c"
>I have finally reproduced a problem reported multiple times
>on the list with beta's. I have tracked down the
>cause to a specific spot and wanted some feedback on
>my proposed fix.
>Does this look familiar to you?
>make[1]: Leaving directory `/home/joel/b-rtems/tools'
>Making all in c
>/bin/bash: c: No such file or directory
>I got this on Solaris with CONFIG_SHELL settings of
>/bin/sh, ksh, and an old bash. It is because of this
>substitution in the top level Makefile:
>target_subdirs = c
>SUBDIRS = doc make tools c
>The "c" subdirectory should be "sparc-rtems/c" in
>both cases. This is what is produced there when this
>works. I tracked this down to the following
>sed in the top level configure.in:
>TARGET_SUBDIRS=`echo "$target_subdirs" | \
> sed -e "s%\([^ ]\+\)%$target_alias/\1%g"`
>Basically sed on some OSes (Solaris in this case is broken).
>Look at the output of the following:
>$ echo c | /usr2/tools/bin/sed -e "s%\([^ ]\+\)%sparc-rtems/\1%g"
>sparc-rtems/c
>$ echo c | /bin/sed -e "s%\([^ ]\+\)%sparc-rtems/\1%g"
>c
>If you tripped this problem and the default sed in your
>path fails the above test, then I have explained the failure. :)
>My fix is to avoid sed. This is what I ended up with:
>Index: configure.in
>RCS file: /usr1/CVS/rtems/configure.in,v
>retrieving revision 1.101.2.2
>diff -u -r1.101.2.2 configure.in
>--- configure.in 2000/05/08 18:59:18 1.101.2.2
>+++ configure.in 2000/05/25 19:21:50
>@@ -45,10 +45,10 @@
> RTEMS_CONFIG_SUBDIRS(c)
> if test "$target_alias" != "$host_alias"; then
>-changequote(,)dnl
>-TARGET_SUBDIRS=`echo "$target_subdirs" | \
>- sed -e "s%\([^ ]\+\)%$target_alias/\1%g"`
>-changequote([,])dnl
>+TARGET_SUBDIRS=
>+for t in $target_subdirs ; do
>+ TARGET_SUBDIRS="${TARGET_SUBDIRS} ${target_alias}/${t}"
>+done
> else
> TARGET_SUBDIRS="$target_subdirs"
> fi
>After applying this patch, you will need to run bootstrap.
>[Or edit the generated configure by hand to make the above
>substitution]
>Comments?
>Joel Sherrill, Ph.D. Director of Research & Development
>joel at OARcorp.com On-Line Applications Research
>Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
