top level build problem c instead of "TARGET/c"
Joel Sherrill
joel.sherrill at OARcorp.com
Thu May 25 19:25:32 UTC 2000
I have finally reproduced a problem reported multiple times
on the list with beta's. I have tracked down the
cause to a specific spot and wanted some feedback on
my proposed fix.
Does this look familiar to you?
make[1]: Leaving directory `/home/joel/b-rtems/tools'
Making all in c
/bin/bash: c: No such file or directory
I got this on Solaris with CONFIG_SHELL settings of
/bin/sh, ksh, and an old bash. It is because of this
substitution in the top level Makefile:
target_subdirs = c
SUBDIRS = doc make tools c
The "c" subdirectory should be "sparc-rtems/c" in
both cases. This is what is produced there when this
works. I tracked this down to the following
sed in the top level configure.in:
TARGET_SUBDIRS=`echo "$target_subdirs" | \
sed -e "s%\([^ ]\+\)%$target_alias/\1%g"`
Basically sed on some OSes (Solaris in this case is broken).
Look at the output of the following:
$ echo c | /usr2/tools/bin/sed -e "s%\([^ ]\+\)%sparc-rtems/\1%g"
sparc-rtems/c
$ echo c | /bin/sed -e "s%\([^ ]\+\)%sparc-rtems/\1%g"
If you tripped this problem and the default sed in your
path fails the above test, then I have explained the failure. :)
My fix is to avoid sed. This is what I ended up with:
Index: configure.in
RCS file: /usr1/CVS/rtems/configure.in,v
retrieving revision 1.101.2.2
diff -u -r1.101.2.2 configure.in
--- configure.in 2000/05/08 18:59:18 1.101.2.2
+++ configure.in 2000/05/25 19:21:50
@@ -45,10 +45,10 @@
RTEMS_CONFIG_SUBDIRS(c)
if test "$target_alias" != "$host_alias"; then
-changequote(,)dnl
-TARGET_SUBDIRS=`echo "$target_subdirs" | \
- sed -e "s%\([^ ]\+\)%$target_alias/\1%g"`
-changequote([,])dnl
+TARGET_SUBDIRS=
+for t in $target_subdirs ; do
+ TARGET_SUBDIRS="${TARGET_SUBDIRS} ${target_alias}/${t}"
+done
else
TARGET_SUBDIRS="$target_subdirs"
fi
After applying this patch, you will need to run bootstrap.
[Or edit the generated configure by hand to make the above
substitution]
Comments?
joel at OARcorp.com On-Line Applications Research
