RTEMS on Cygwin as target environment
Stephan Merker
merker at decrc.abb.de
Wed Nov 8 17:11:34 UTC 2000
Has anyone tried to use Cygwin as target environment using the posix BSP?
I was able to configure and compile the posix BSP under Cygwin, however most
of the tests do not run through (e.g. sp01.exe stalls after a few seconds).
Interestingly, once it ran through in gdb.
I'm was trying with the last RTEMS Snapshot (rtems-ss-20001103), a fairly
up-to-date Cygwin 1.1, and gcc 2.95.2.
Thanks,
Stephan
