from a very newbie (I'm sorry)
Pieter De Troyer pieter.detroyer at mech.kuleuven.ac.be
Thu Nov 9 09:56:02 UTC 2000
Hi all,
I just started to build my first RTEMS (4.5.0), and guess what...
everything goes fine till almost the end (I suppose).
I installed the precompiled crosscompilertoolset (RPMS), then I
configured RTEMS for an i386 target, with bsp pc686  (I intend to do
some testing on an ordinary pc). Next I start 'make all install' . After
compiling a while the make comes up with en error message : no : command
not found.
I'm not a very experienced programmer and I only understand a little bit
of Makefile so if anyone could help me out on tackling this error, I
would be really grateful!
thanks in advance!
Pieter
After this horizontal line I put the output of
'[pdtroyer at pc-10-33-39-170 build-rtems]$ ../rtems-4.5.0/configure
--target=i386 -enable-rtemsbsp=pc686 --prefix=/opt/rtems'
_______________________________________________________________________________________
creating cache ./config.cache
checking for RTEMS Version... 4.5.0
checking host system type... i686-pc-linux-gnu
checking target system type... i386-pc-none
checking build system type... i686-pc-linux-gnu
checking rtems target cpu... i386
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... found
checking whether to enable maintainer-specific portions of Makefiles...
no
checking if the test suites are enabled? ... no
checking if cpu i386 is supported... yes
updating cache ./config.cache
creating ./config.status
creating Makefile
creating tools/Makefile
creating make/Makefile
creating make/custom/Makefile
creating make/Templates/Makefile
creating make/compilers/Makefile
creating doc/Makefile
configuring in tools/build
running /bin/sh ../../../rtems-4.5.0/tools/build/configure
--cache-file=../.././config.cache
--srcdir=../../../rtems-4.5.0/tools/build
loading cache ../.././config.cache
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking whether make sets ${MAKE}... (cached) yes
no
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... no
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for strerror... yes
checking for strtol... yes
checking for bash... /bin/bash
updating cache ../.././config.cache
creating Makefile
creating install-if-change
creating lock-directory
creating unlock-directory
creating config.h
configuring in tools/update
running /bin/sh ../../../rtems-4.5.0/tools/update/configure
--srcdir=../../../rtems-4.5.0/tools/update
no
checking for bash... (cached) /bin/bash
checking for perl... /usr/bin/perl
creating Makefile
configuring in tools/cpu
running /bin/sh ../../../rtems-4.5.0/tools/cpu/configure  --target=i386
--srcdir=../../../rtems-4.5.0/tools/cpu
no
creating Makefile
configuring in generic
running /bin/sh ../../../../rtems-4.5.0/tools/cpu/generic/configure
--cache-file=../../.././config.cache
--srcdir=../../../../rtems-4.5.0/tools/cpu/generic
loading cache ../../.././config.cache
no
creating Makefile
creating size_rtems
configuring in i386/c
running /bin/sh ../../../rtems-4.5.0/c/configure  --target=i386
-enable-rtemsbsp=pc686 --prefix=/opt/rtems --cache-file=./config.cache
--srcdir=../../../rtems-4.5.0/c
no
checking for make/custom/pc686.cfg... yes
creating Makefile
configuring in make
running /bin/sh ../../../../rtems-4.5.0/c/make/configure  --target=i386
-enable-rtemsbsp=pc686 --prefix=/opt/rtems --with-target-subdir=i386
--cache-file=.././config.cache --srcdir=../../../../rtems-4.5.0/c/make
loading cache .././config.cache
no
checking for i386-gcc... no
checking for i386-cc... /opt/rtems/bin//i386-cc
checking whether the C compiler (/opt/rtems/bin//i386-cc  ) works... yes
checking whether the C compiler (/opt/rtems/bin//i386-cc  ) is a
cross-compiler... yes
checking whether /opt/rtems/bin//i386-cc accepts -g... yes
checking whether /opt/rtems/bin//i386-cc accepts -specs... yes
checking whether /opt/rtems/bin//i386-cc accepts --pipe... yes
checking target's ar...
checking for i386-ar... /opt/rtems/i386-rtems/bin/ar
checking target's as...
checking for i386-as... /opt/rtems/i386-rtems/bin/as
checking target's ld...
checking for i386-ld... /opt/rtems/i386-rtems/bin/ld
checking target's nm...
checking for i386-nm... /opt/rtems/i386-rtems/bin/nm
checking target's ranlib...
checking for i386-ranlib... /opt/rtems/i386-rtems/bin/ranlib
checking target's objcopy...
checking for i386-objcopy... no
checking target's size...
checking for i386-size... no
checking target's strip...
checking for i386-strip... /opt/rtems/i386-rtems/bin/strip
updating cache .././config.cache
creating Makefile
creating target.cfg
target architecture: i386.
available BSPs: pc686.
'make all' will build the following BSPs: pc686.
other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
After this horizontal line I put the outcome of 'make all install'
Making all in doc
make[1]: Entering directory `/home/pdtroyer/RTEMS/tools/build-rtems/doc'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/pdtroyer/RTEMS/tools/build-rtems/doc'
Making all in make
`/home/pdtroyer/RTEMS/tools/build-rtems/make'
Making all in Templates
make[2]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/make/Templates'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory
Making all in custom
`/home/pdtroyer/RTEMS/tools/build-rtems/make/custom'
Making all in compilers
`/home/pdtroyer/RTEMS/tools/build-rtems/make/compilers'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/home/pdtroyer/RTEMS/tools/build-rtems/make'
make[1]: Leaving directory `/home/pdtroyer/RTEMS/tools/build-rtems/make'
Making all in tools
`/home/pdtroyer/RTEMS/tools/build-rtems/tools'
Making all in build
`/home/pdtroyer/RTEMS/tools/build-rtems/tools/build'
gcc -DHAVE_CONFIG_H -I. -I../../../rtems-4.5.0/tools/build -I.     -g
-O2 -c ../../../rtems-4.5.0/tools/build/cklength.c
gcc  -g -O2  -o cklength  cklength.o
-O2 -c ../../../rtems-4.5.0/tools/build/eolstrip.c
gcc  -g -O2  -o eolstrip  eolstrip.o
-O2 -c ../../../rtems-4.5.0/tools/build/packhex.c
gcc  -g -O2  -o packhex  packhex.o
-O2 -c ../../../rtems-4.5.0/tools/build/unhex.c
gcc  -g -O2  -o unhex  unhex.o
-O2 -c ../../../rtems-4.5.0/tools/build/binpatch.c
gcc  -g -O2  -o binpatch  binpatch.o
Making all in cpu
`/home/pdtroyer/RTEMS/tools/build-rtems/tools/cpu'
Making all in generic
make[3]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/tools/cpu/generic'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory
make[3]: Nothing to be done for `all-am'.
Making all in update
`/home/pdtroyer/RTEMS/tools/build-rtems/tools/update'
creating word-replace
creating update
Making all in i386/c
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c'
Making all in make
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/make'
Making all in .
Configuring RTEMS_BSP=pc686
no
checking for RTEMS_BSP... pc686
checking whether BSP supports networking... yes
creating Makefile
creating wrapup/Makefile
configuring in make
running /bin/sh ../../../../../rtems-4.5.0/c/src/make/configure
--with-target-subdir=i386 --cache-file=.././config.cache
--srcdir=../../../../../rtems-4.5.0/c/src/make
no
checking for RTEMS_BSP... (cached) pc686
checking for cat... /bin/cat
checking for cp... /bin/cp
checking for mv... /bin/mv
checking for ln... /bin/ln
checking whether ln -s works... yes
checking for chmod... /bin/chmod
checking for sort... /bin/sort
checking for touch... /bin/touch
checking for cmp... /usr/bin/cmp
checking for sed... /bin/sed
checking for gm4... no
checking for m4... /usr/bin/m4
checking for 16 bit mode assembler support... yes
checking whether BSP supports multiprocessing... no
checking whether BSP supports networking... (cached) yes
checking whether BSP supports librdbg... yes
checking whether BSP supports libposix... yes
checking whether to build rtems++... no
checking whether BSP supports libitron... yes
creating Makefile
creating Makefile.inc
creating main.cfg
creating host.cfg
creating bsp.cfg
creating custom/Makefile
creating custom/default.cfg
creating compilers/Makefile
linking
../../../../../rtems-4.5.0/c/src/make/../../../make/custom/pc686.cfg to
custom/pc686.cfg
linking
../../../../../rtems-4.5.0/c/src/make/../../../make/custom/pc386.cfg to
custom/pc386.cfg
linking
../../../../../rtems-4.5.0/c/src/make/../../../make/Templates/Makefile.lib
to Templates/Makefile.lib
linking
../../../../../rtems-4.5.0/c/src/make/../../../make/Templates/Makefile.leaf
to Templates/Makefile.leaf
linking
../../../../../rtems-4.5.0/c/src/make/../../../make/Templates/Makefile.dir
to Templates/Makefile.dir
linking
../../../../../rtems-4.5.0/c/src/make/../../../make/compilers/gcc-target-default.cfg
to compilers/gcc-target-default.cfg
linking
../../../../../rtems-4.5.0/c/src/make/../../../make/directory.cfg to
directory.cfg
linking ../../../../../rtems-4.5.0/c/src/make/leaf.cfg to leaf.cfg
linking ../../../../../rtems-4.5.0/c/src/make/../../../make/lib.cfg to
lib.cfg
linking ../../../../../rtems-4.5.0/c/src/make/../../../make/README to
README
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/make'
rm -f pc686.cache
configuring in exec
running /bin/sh ../../../../../rtems-4.5.0/c/src/exec/configure
--srcdir=../../../../../rtems-4.5.0/c/src/exec
no
checking for i386-gcc... (cached) /opt/rtems/bin//i386-cc
checking whether /opt/rtems/bin//i386-cc accepts -specs... (cached) yes
checking whether /opt/rtems/bin//i386-cc accepts --pipe... (cached) yes
checking target's ar... (cached) /opt/rtems/i386-rtems/bin/ar
checking target's as... (cached) /opt/rtems/i386-rtems/bin/as
checking target's ld... (cached) /opt/rtems/i386-rtems/bin/ld
checking target's nm... (cached) /opt/rtems/i386-rtems/bin/nm
checking target's ranlib... (cached) /opt/rtems/i386-rtems/bin/ranlib
checking target's objcopy... (cached) no
checking target's size... (cached) no
checking target's strip... (cached) /opt/rtems/i386-rtems/bin/strip
checking for newlib... yes
checking whether BSP supports multiprocessing... (cached) no
checking whether BSP supports libposix... (cached) yes
checking whether BSP supports libitron... (cached) yes
creating Makefile
creating rtems/Makefile
creating rtems/src/Makefile
creating rtems/include/Makefile
creating rtems/include/rtems/Makefile
creating rtems/include/rtems/rtems/Makefile
creating rtems/optman/Makefile
creating rtems/inline/Makefile
creating rtems/inline/rtems/Makefile
creating rtems/inline/rtems/rtems/Makefile
creating rtems/macros/Makefile
creating rtems/macros/rtems/Makefile
creating rtems/macros/rtems/rtems/Makefile
creating sapi/Makefile
creating sapi/src/Makefile
creating sapi/include/Makefile
creating sapi/include/rtems/Makefile
creating sapi/include/rtems/sptables.h
creating sapi/inline/Makefile
creating sapi/inline/rtems/Makefile
creating sapi/macros/Makefile
creating sapi/macros/rtems/Makefile
creating sapi/optman/Makefile
creating score/Makefile
creating score/cpu/Makefile
creating score/include/Makefile
creating score/include/rtems/Makefile
creating score/include/rtems/score/Makefile
creating score/inline/Makefile
creating score/inline/rtems/Makefile
creating score/inline/rtems/score/Makefile
creating score/macros/Makefile
creating score/macros/rtems/Makefile
creating score/macros/rtems/score/Makefile
creating score/src/Makefile
creating wrapup/rtems/Makefile
creating wrapup/itron/Makefile
creating wrapup/posix/Makefile
configuring in posix
running /bin/sh
../../../../../../rtems-4.5.0/c/src/exec/posix/configure  --target=i386
--srcdir=../../../../../../rtems-4.5.0/c/src/exec/posix
no
checking for newlib... (cached) yes
creating Makefile
creating src/Makefile
creating include/Makefile
creating include/sys/Makefile
creating include/rtems/Makefile
creating include/rtems/posix/Makefile
creating optman/Makefile
creating inline/Makefile
creating inline/rtems/Makefile
creating inline/rtems/posix/Makefile
creating macros/Makefile
creating macros/rtems/Makefile
creating macros/rtems/posix/Makefile
configuring in itron
running /bin/sh
../../../../../../rtems-4.5.0/c/src/exec/itron/configure  --target=i386
--srcdir=../../../../../../rtems-4.5.0/c/src/exec/itron
no
creating Makefile
creating include/itronsys/Makefile
creating include/rtems/itron/Makefile
creating inline/rtems/itron/Makefile
configuring in score/cpu/i386
running /bin/sh
../../../../../../../../rtems-4.5.0/c/src/exec/score/cpu/i386/configure
--with-target-subdir=i386 --cache-file=../../../.././config.cache
--srcdir=../../../../../../../../rtems-4.5.0/c/src/exec/score/cpu/i386
loading cache ../../../.././config.cache
no
creating Makefile
creating rtems/score/Makefile
configuring in lib
running /bin/sh ../../../../../rtems-4.5.0/c/src/lib/configure
--srcdir=../../../../../rtems-4.5.0/c/src/lib
no
creating Makefile
creating include/motorola/Makefile
creating include/zilog/Makefile
creating libc/Makefile
configuring in libcpu
running /bin/sh
../../../../../../rtems-4.5.0/c/src/lib/libcpu/configure  --target=i386
--srcdir=../../../../../../rtems-4.5.0/c/src/lib/libcpu
no
creating Makefile
configuring in i386
running /bin/sh
../../../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/configure
--with-target-subdir=i386 --cache-file=../../.././config.cache
--srcdir=../../../../../../../rtems-4.5.0/c/src/lib/libcpu/i386
no
checking for RTEMS_CPU_MODEL... pentiumpro
checking for RTEMS_BSP_FAMILY... (cached) pc386
updating cache ../../.././config.cache
creating Makefile
configuring in libbsp
running /bin/sh
../../../../../../rtems-4.5.0/c/src/lib/libbsp/configure  --target=i386
--srcdir=../../../../../../rtems-4.5.0/c/src/lib/libbsp
no
creating Makefile
creating shmdr/Makefile
configuring in i386
running /bin/sh
../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/configure
--srcdir=../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386
no
checking for RTEMS_CPU_MODEL... (cached) pentiumpro
creating Makefile
creating shared/Makefile
creating shared/comm/Makefile
creating shared/io/Makefile
creating shared/irq/Makefile
creating shared/pci/Makefile
configuring in pc386
running /bin/sh
../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/configure
--srcdir=../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386
no
checking for 16 bit mode assembler support... (cached) yes
creating Makefile
creating clock/Makefile
creating console/Makefile
creating start/Makefile
creating startup/Makefile
creating timer/Makefile
creating 3c509/Makefile
creating ne2000/Makefile
creating wd8003/Makefile
running /bin/sh
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/tools/configure
--with-target-subdir=i386 --cache-file=../../../../.././config.cache
--srcdir=../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/tools
loading cache ../../../../.././config.cache
no
checking for strtoul... yes
updating cache ../../../../.././config.cache
creating Makefile
configuring in libmisc
running /bin/sh ../../../../../rtems-4.5.0/c/src/libmisc/configure
--srcdir=../../../../../rtems-4.5.0/c/src/libmisc
no
checking whether we are using GNU C... (cached) yes
checking whether /opt/rtems/bin//i386-cc accepts -g... (cached) yes
creating Makefile
creating cpuuse/Makefile
creating dummy/Makefile
creating dumpbuf/Makefile
creating monitor/Makefile
creating rtmonuse/Makefile
creating stackchk/Makefile
creating untar/Makefile
configuring in libchip
running /bin/sh ../../../../../rtems-4.5.0/c/src/libchip/configure
--srcdir=../../../../../rtems-4.5.0/c/src/libchip
no
creating Makefile
creating network/Makefile
creating rtc/Makefile
creating serial/Makefile
configuring in libnetworking
running /bin/sh
../../../../../rtems-4.5.0/c/src/libnetworking/configure  --target=i386
--srcdir=../../../../../rtems-4.5.0/c/src/libnetworking
no
creating Makefile
creating arpa/Makefile
creating machine/Makefile
creating kern/Makefile
creating sys/Makefile
creating vm/Makefile
creating lib/Makefile
creating net/Makefile
creating netinet/Makefile
creating nfs/Makefile
creating pppd/Makefile
creating rtems_servers/Makefile
creating rtems_webserver/Makefile
configuring in librpc
running /bin/sh ../../../../../rtems-4.5.0/c/src/librpc/configure
--srcdir=../../../../../rtems-4.5.0/c/src/librpc
no
creating Makefile
creating include/rpc/Makefile
creating include/rpcsvc/Makefile
creating src/xdr/Makefile
creating src/rpc/Makefile
creating src/rpc/PSD.doc/Makefile
configuring in tests
running /bin/sh ../../../../../rtems-4.5.0/c/src/tests/configure
--srcdir=../../../../../rtems-4.5.0/c/src/tests
no
creating Makefile
running /bin/sh
../../../../../../rtems-4.5.0/c/src/tests/tools/configure  --target=i386
--srcdir=../../../../../../rtems-4.5.0/c/src/tests/tools
no
creating Makefile
running /bin/sh
../../../../../../../rtems-4.5.0/c/src/tests/tools/generic/configure
--srcdir=../../../../../../../rtems-4.5.0/c/src/tests/tools/generic
no
creating Makefile
creating difftest
creating sorttimes
configuring in support
running /bin/sh
../../../../../../rtems-4.5.0/c/src/tests/support/configure
--with-target-subdir=i386 --cache-file=../.././config.cache
--srcdir=../../../../../../rtems-4.5.0/c/src/tests/support
no
creating Makefile
creating stubdr/Makefile
configuring in samples
running /bin/sh
../../../../../../rtems-4.5.0/c/src/tests/samples/configure
--srcdir=../../../../../../rtems-4.5.0/c/src/tests/samples
no
checking whether to build rtems++... (cached) no
creating Makefile
creating base_sp/Makefile
creating hello/Makefile
creating minimum/Makefile
creating paranoia/Makefile
creating ticker/Makefile
creating unlimited/Makefile
creating base_mp/Makefile
creating base_mp/node1/Makefile
creating base_mp/node2/Makefile
creating cdtest/Makefile
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686'
Making preinstall in make
make[4]: Entering directory
Making preinstall in compilers
make[5]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/make/compilers'
make[5]: Nothing to be done for `preinstall'.
make[5]: Leaving directory
Making preinstall in custom
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/make/custom'
make[5]: Nothing to be done for `preinstall-am'.
make[4]: Leaving directory
Making preinstall in exec
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec'
Making preinstall in score
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score'
Making preinstall in include
make[6]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/include'
Making preinstall in rtems
make[7]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/include/rtems'
make[8]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/include/rtems/score'
/usr/bin/install -c -m 644
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/address.h
../../../../../../../../pc686/lib/include/rtems/score/address.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/apiext.h
../../../../../../../../pc686/lib/include/rtems/score/apiext.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/bitfield.h
../../../../../../../../pc686/lib/include/rtems/score/bitfield.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/chain.h
../../../../../../../../pc686/lib/include/rtems/score/chain.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/context.h
../../../../../../../../pc686/lib/include/rtems/score/context.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/copyrt.h
../../../../../../../../pc686/lib/include/rtems/score/copyrt.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/coremsg.h
../../../../../../../../pc686/lib/include/rtems/score/coremsg.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/coremutex.h
../../../../../../../../pc686/lib/include/rtems/score/coremutex.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/coresem.h
../../../../../../../../pc686/lib/include/rtems/score/coresem.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/heap.h
../../../../../../../../pc686/lib/include/rtems/score/heap.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/interr.h
../../../../../../../../pc686/lib/include/rtems/score/interr.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/isr.h
../../../../../../../../pc686/lib/include/rtems/score/isr.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/object.h
../../../../../../../../pc686/lib/include/rtems/score/object.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/priority.h
../../../../../../../../pc686/lib/include/rtems/score/priority.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/stack.h
../../../../../../../../pc686/lib/include/rtems/score/stack.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/states.h
../../../../../../../../pc686/lib/include/rtems/score/states.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/sysstate.h
../../../../../../../../pc686/lib/include/rtems/score/sysstate.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/thread.h
../../../../../../../../pc686/lib/include/rtems/score/thread.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/threadq.h
../../../../../../../../pc686/lib/include/rtems/score/threadq.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/tod.h
../../../../../../../../pc686/lib/include/rtems/score/tod.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/tqdata.h
../../../../../../../../pc686/lib/include/rtems/score/tqdata.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/userext.h
../../../../../../../../pc686/lib/include/rtems/score/userext.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/watchdog.h
../../../../../../../../pc686/lib/include/rtems/score/watchdog.h
../../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/score/wkspace.h
../../../../../../../../pc686/lib/include/rtems/score/wkspace.h
/usr/bin/install -c -m 644 targopts.h
../../../../../../../../pc686/lib/include/rtems/score/targopts.h
make[8]: Leaving directory
../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/debug.h
../../../../../../../pc686/lib/include/rtems/debug.h
../../../../../../../../rtems-4.5.0/c/src/exec/score/include/rtems/system.h
../../../../../../../pc686/lib/include/rtems/system.h
make[7]: Leaving directory
make[7]: Nothing to be done for `preinstall-am'.
make[6]: Leaving directory
Making preinstall in inline
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/inline'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/inline/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/inline/rtems/score'
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/address.inl
../../../../../../../../pc686/lib/include/rtems/score/address.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/chain.inl
../../../../../../../../pc686/lib/include/rtems/score/chain.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/coremsg.inl
../../../../../../../../pc686/lib/include/rtems/score/coremsg.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/coremutex.inl
../../../../../../../../pc686/lib/include/rtems/score/coremutex.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/coresem.inl
../../../../../../../../pc686/lib/include/rtems/score/coresem.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/heap.inl
../../../../../../../../pc686/lib/include/rtems/score/heap.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/isr.inl
../../../../../../../../pc686/lib/include/rtems/score/isr.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/object.inl
../../../../../../../../pc686/lib/include/rtems/score/object.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/priority.inl
../../../../../../../../pc686/lib/include/rtems/score/priority.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/stack.inl
../../../../../../../../pc686/lib/include/rtems/score/stack.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/states.inl
../../../../../../../../pc686/lib/include/rtems/score/states.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/sysstate.inl
../../../../../../../../pc686/lib/include/rtems/score/sysstate.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/thread.inl
../../../../../../../../pc686/lib/include/rtems/score/thread.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/tod.inl
../../../../../../../../pc686/lib/include/rtems/score/tod.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/tqdata.inl
../../../../../../../../pc686/lib/include/rtems/score/tqdata.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/userext.inl
../../../../../../../../pc686/lib/include/rtems/score/userext.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/watchdog.inl
../../../../../../../../pc686/lib/include/rtems/score/watchdog.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/score/inline/rtems/score/wkspace.inl
../../../../../../../../pc686/lib/include/rtems/score/wkspace.inl
make[8]: Nothing to be done for `preinstall-am'.
Making preinstall in macros
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/macros'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/macros/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/macros/rtems/score'
make[8]: Nothing to be done for `preinstall'.
Making preinstall in cpu
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/cpu'
Making preinstall in i386
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/cpu/i386'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/cpu/i386/rtems'
make[9]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/cpu/i386/rtems/score'
../../../../../../../../../../rtems-4.5.0/c/src/exec/score/cpu/i386/rtems/score/cpu.h
../../../../../../../../../pc686/lib/include/rtems/score/cpu.h
../../../../../../../../../../rtems-4.5.0/c/src/exec/score/cpu/i386/rtems/score/i386.h
../../../../../../../../../pc686/lib/include/rtems/score/i386.h
../../../../../../../../../../rtems-4.5.0/c/src/exec/score/cpu/i386/rtems/score/i386types.h
../../../../../../../../../pc686/lib/include/rtems/score/i386types.h
make[9]: Leaving directory
make[9]: Nothing to be done for `preinstall-am'.
../../../../../../../../rtems-4.5.0/c/src/exec/score/cpu/i386/asm.h
../../../../../../.././pc686/lib/include/asm.h
Making preinstall in src
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/src'
make[6]: Nothing to be done for `preinstall'.
make[6]: Nothing to be done for `preinstall-am'.
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/include'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/include/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/include/rtems/rtems'
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/asr.h
../../../../../../../../pc686/lib/include/rtems/rtems/asr.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/attr.h
../../../../../../../../pc686/lib/include/rtems/rtems/attr.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/clock.h
../../../../../../../../pc686/lib/include/rtems/rtems/clock.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/config.h
../../../../../../../../pc686/lib/include/rtems/rtems/config.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/dpmem.h
../../../../../../../../pc686/lib/include/rtems/rtems/dpmem.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/event.h
../../../../../../../../pc686/lib/include/rtems/rtems/event.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/eventset.h
../../../../../../../../pc686/lib/include/rtems/rtems/eventset.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/intr.h
../../../../../../../../pc686/lib/include/rtems/rtems/intr.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/message.h
../../../../../../../../pc686/lib/include/rtems/rtems/message.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/modes.h
../../../../../../../../pc686/lib/include/rtems/rtems/modes.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/options.h
../../../../../../../../pc686/lib/include/rtems/rtems/options.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/part.h
../../../../../../../../pc686/lib/include/rtems/rtems/part.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/ratemon.h
../../../../../../../../pc686/lib/include/rtems/rtems/ratemon.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/region.h
../../../../../../../../pc686/lib/include/rtems/rtems/region.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/rtemsapi.h
../../../../../../../../pc686/lib/include/rtems/rtems/rtemsapi.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/sem.h
../../../../../../../../pc686/lib/include/rtems/rtems/sem.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/signal.h
../../../../../../../../pc686/lib/include/rtems/rtems/signal.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/status.h
../../../../../../../../pc686/lib/include/rtems/rtems/status.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/support.h
../../../../../../../../pc686/lib/include/rtems/rtems/support.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/tasks.h
../../../../../../../../pc686/lib/include/rtems/rtems/tasks.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/timer.h
../../../../../../../../pc686/lib/include/rtems/rtems/timer.h
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems/rtems/types.h
../../../../../../../../pc686/lib/include/rtems/rtems/types.h
../../../../../../../rtems-4.5.0/c/src/exec/rtems/include/rtems.h
../../../../../../pc686/lib/include/rtems.h
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/inline'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/inline/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/inline/rtems/rtems'
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/asr.inl
../../../../../../../../pc686/lib/include/rtems/rtems/asr.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/attr.inl
../../../../../../../../pc686/lib/include/rtems/rtems/attr.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/dpmem.inl
../../../../../../../../pc686/lib/include/rtems/rtems/dpmem.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/event.inl
../../../../../../../../pc686/lib/include/rtems/rtems/event.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/eventset.inl
../../../../../../../../pc686/lib/include/rtems/rtems/eventset.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/message.inl
../../../../../../../../pc686/lib/include/rtems/rtems/message.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/modes.inl
../../../../../../../../pc686/lib/include/rtems/rtems/modes.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/options.inl
../../../../../../../../pc686/lib/include/rtems/rtems/options.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/part.inl
../../../../../../../../pc686/lib/include/rtems/rtems/part.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/ratemon.inl
../../../../../../../../pc686/lib/include/rtems/rtems/ratemon.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/region.inl
../../../../../../../../pc686/lib/include/rtems/rtems/region.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/sem.inl
../../../../../../../../pc686/lib/include/rtems/rtems/sem.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/status.inl
../../../../../../../../pc686/lib/include/rtems/rtems/status.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/support.inl
../../../../../../../../pc686/lib/include/rtems/rtems/support.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/tasks.inl
../../../../../../../../pc686/lib/include/rtems/rtems/tasks.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/rtems/inline/rtems/rtems/timer.inl
../../../../../../../../pc686/lib/include/rtems/rtems/timer.inl
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/macros'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/macros/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/macros/rtems/rtems'
Making preinstall in optman
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/optman'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/src'
Making preinstall in posix
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/include'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/include/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/include/rtems/posix'
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/cancel.h
../../../../../../../../pc686/lib/include/rtems/posix/cancel.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/cond.h
../../../../../../../../pc686/lib/include/rtems/posix/cond.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/config.h
../../../../../../../../pc686/lib/include/rtems/posix/config.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/key.h
../../../../../../../../pc686/lib/include/rtems/posix/key.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/mqueue.h
../../../../../../../../pc686/lib/include/rtems/posix/mqueue.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/mutex.h
../../../../../../../../pc686/lib/include/rtems/posix/mutex.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/posixapi.h
../../../../../../../../pc686/lib/include/rtems/posix/posixapi.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/priority.h
../../../../../../../../pc686/lib/include/rtems/posix/priority.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/psignal.h
../../../../../../../../pc686/lib/include/rtems/posix/psignal.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/pthread.h
../../../../../../../../pc686/lib/include/rtems/posix/pthread.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/ptimer.h
../../../../../../../../pc686/lib/include/rtems/posix/ptimer.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/semaphore.h
../../../../../../../../pc686/lib/include/rtems/posix/semaphore.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/seterr.h
../../../../../../../../pc686/lib/include/rtems/posix/seterr.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/threadsup.h
../../../../../../../../pc686/lib/include/rtems/posix/threadsup.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/time.h
../../../../../../../../pc686/lib/include/rtems/posix/time.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/timer.h
../../../../../../../../pc686/lib/include/rtems/posix/timer.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/condmp.h
../../../../../../../../pc686/lib/include/rtems/posix/condmp.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/mqueuemp.h
../../../../../../../../pc686/lib/include/rtems/posix/mqueuemp.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/mutexmp.h
../../../../../../../../pc686/lib/include/rtems/posix/mutexmp.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/pthreadmp.h
../../../../../../../../pc686/lib/include/rtems/posix/pthreadmp.h
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/rtems/posix/semaphoremp.h
../../../../../../../../pc686/lib/include/rtems/posix/semaphoremp.h
Making preinstall in sys
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/include/sys'
../../../../../../../../rtems-4.5.0/c/src/exec/posix/include/sys/utsname.h
../../../../../../../pc686/lib/include/sys/utsname.h
../../../../../../../rtems-4.5.0/c/src/exec/posix/include/sched.h
../../../../../../pc686/lib/include/sched.h
../../../../../../../rtems-4.5.0/c/src/exec/posix/include/aio.h
../../../../../../pc686/lib/include/aio.h
../../../../../../../rtems-4.5.0/c/src/exec/posix/include/mqueue.h
../../../../../../pc686/lib/include/mqueue.h
../../../../../../../rtems-4.5.0/c/src/exec/posix/include/semaphore.h
../../../../../../pc686/lib/include/semaphore.h
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/inline'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/inline/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/inline/rtems/posix'
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/inline/rtems/posix/cond.inl
../../../../../../../../pc686/lib/include/rtems/posix/cond.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/inline/rtems/posix/key.inl
../../../../../../../../pc686/lib/include/rtems/posix/key.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/inline/rtems/posix/mqueue.inl
../../../../../../../../pc686/lib/include/rtems/posix/mqueue.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/inline/rtems/posix/mutex.inl
../../../../../../../../pc686/lib/include/rtems/posix/mutex.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/inline/rtems/posix/pthread.inl
../../../../../../../../pc686/lib/include/rtems/posix/pthread.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/inline/rtems/posix/priority.inl
../../../../../../../../pc686/lib/include/rtems/posix/priority.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/posix/inline/rtems/posix/semaphore.inl
../../../../../../../../pc686/lib/include/rtems/posix/semaphore.inl
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/macros'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/macros/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/macros/rtems/posix'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/src'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/optman'
Making preinstall in itron
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/include'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/include/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/include/rtems/itron'
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/config.h
../../../../../../../../pc686/lib/include/rtems/itron/config.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/eventflags.h
../../../../../../../../pc686/lib/include/rtems/itron/eventflags.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/fmempool.h
../../../../../../../../pc686/lib/include/rtems/itron/fmempool.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/intr.h
../../../../../../../../pc686/lib/include/rtems/itron/intr.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/itronapi.h
../../../../../../../../pc686/lib/include/rtems/itron/itronapi.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/mbox.h
../../../../../../../../pc686/lib/include/rtems/itron/mbox.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/msgbuffer.h
../../../../../../../../pc686/lib/include/rtems/itron/msgbuffer.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/network.h
../../../../../../../../pc686/lib/include/rtems/itron/network.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/object.h
../../../../../../../../pc686/lib/include/rtems/itron/object.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/port.h
../../../../../../../../pc686/lib/include/rtems/itron/port.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/semaphore.h
../../../../../../../../pc686/lib/include/rtems/itron/semaphore.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/sysmgmt.h
../../../../../../../../pc686/lib/include/rtems/itron/sysmgmt.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/task.h
../../../../../../../../pc686/lib/include/rtems/itron/task.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/time.h
../../../../../../../../pc686/lib/include/rtems/itron/time.h
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/rtems/itron/vmempool.h
../../../../../../../../pc686/lib/include/rtems/itron/vmempool.h
Making preinstall in itronsys
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/include/itronsys'
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/eventflags.h
../../../../../../../pc686/lib/include/itronsys/eventflags.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/fmempool.h
../../../../../../../pc686/lib/include/itronsys/fmempool.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/intr.h
../../../../../../../pc686/lib/include/itronsys/intr.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/mbox.h
../../../../../../../pc686/lib/include/itronsys/mbox.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/msgbuffer.h
../../../../../../../pc686/lib/include/itronsys/msgbuffer.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/network.h
../../../../../../../pc686/lib/include/itronsys/network.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/port.h
../../../../../../../pc686/lib/include/itronsys/port.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/semaphore.h
../../../../../../../pc686/lib/include/itronsys/semaphore.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/status.h
../../../../../../../pc686/lib/include/itronsys/status.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/sysmgmt.h
../../../../../../../pc686/lib/include/itronsys/sysmgmt.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/task.h
../../../../../../../pc686/lib/include/itronsys/task.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/time.h
../../../../../../../pc686/lib/include/itronsys/time.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/types.h
../../../../../../../pc686/lib/include/itronsys/types.h
../../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itronsys/vmempool.h
../../../../../../../pc686/lib/include/itronsys/vmempool.h
../../../../../../../rtems-4.5.0/c/src/exec/itron/include/itron.h
../../../../../../pc686/lib/include/itron.h
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/inline'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/inline/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/inline/rtems/itron'
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/eventflags.inl
../../../../../../../../pc686/lib/include/rtems/itron/eventflags.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/fmempool.inl
../../../../../../../../pc686/lib/include/rtems/itron/fmempool.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/intr.inl
../../../../../../../../pc686/lib/include/rtems/itron/intr.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/mbox.inl
../../../../../../../../pc686/lib/include/rtems/itron/mbox.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/msgbuffer.inl
../../../../../../../../pc686/lib/include/rtems/itron/msgbuffer.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/network.inl
../../../../../../../../pc686/lib/include/rtems/itron/network.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/port.inl
../../../../../../../../pc686/lib/include/rtems/itron/port.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/semaphore.inl
../../../../../../../../pc686/lib/include/rtems/itron/semaphore.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/sysmgmt.inl
../../../../../../../../pc686/lib/include/rtems/itron/sysmgmt.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/task.inl
../../../../../../../../pc686/lib/include/rtems/itron/task.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/time.inl
../../../../../../../../pc686/lib/include/rtems/itron/time.inl
../../../../../../../../../rtems-4.5.0/c/src/exec/itron/inline/rtems/itron/vmempool.inl
../../../../../../../../pc686/lib/include/rtems/itron/vmempool.inl
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/src'
Making preinstall in sapi
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/include'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/include/rtems'
../../../../../../../../rtems-4.5.0/c/src/exec/sapi/include/rtems/config.h
../../../../../../../pc686/lib/include/rtems/config.h
../../../../../../../../rtems-4.5.0/c/src/exec/sapi/include/rtems/directives.h
../../../../../../../pc686/lib/include/rtems/directives.h
../../../../../../../../rtems-4.5.0/c/src/exec/sapi/include/rtems/extension.h
../../../../../../../pc686/lib/include/rtems/extension.h
../../../../../../../../rtems-4.5.0/c/src/exec/sapi/include/rtems/fatal.h
../../../../../../../pc686/lib/include/rtems/fatal.h
../../../../../../../../rtems-4.5.0/c/src/exec/sapi/include/rtems/init.h
../../../../../../../pc686/lib/include/rtems/init.h
../../../../../../../../rtems-4.5.0/c/src/exec/sapi/include/rtems/io.h
../../../../../../../pc686/lib/include/rtems/io.h
../../../../../../../../rtems-4.5.0/c/src/exec/sapi/include/rtems/mptables.h
../../../../../../../pc686/lib/include/rtems/mptables.h
/usr/bin/install -c -m 644 sptables.h
../../../../../../../pc686/lib/include/rtems/sptables.h
../../../../../../../rtems-4.5.0/c/src/exec/sapi/include/confdefs.h
../../../../../../pc686/lib/include/confdefs.h
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/inline'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/inline/rtems'
../../../../../../../../rtems-4.5.0/c/src/exec/sapi/inline/rtems/extension.inl
../../../../../../../pc686/lib/include/rtems/extension.inl
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/macros'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/macros/rtems'
make[7]: Nothing to be done for `preinstall'.
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/optman'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/src'
Making preinstall in wrapup
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/wrapup'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/wrapup/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/wrapup/posix'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/wrapup/itron'
Making preinstall in lib
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/include'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/include/sys'
../../../../../../../rtems-4.5.0/c/src/lib/include/sys/utime.h
../../../../../../pc686/lib/include/sys/utime.h
../../../../../../../rtems-4.5.0/c/src/lib/include/sys/termios.h
../../../../../../pc686/lib/include/sys/termios.h
Making preinstall in motorola
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/include/motorola'
../../../../../../../rtems-4.5.0/c/src/lib/include/motorola/mc68230.h
../../../../../../pc686/lib/include/motorola/mc68230.h
../../../../../../../rtems-4.5.0/c/src/lib/include/motorola/mc68681.h
../../../../../../pc686/lib/include/motorola/mc68681.h
Making preinstall in zilog
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/include/zilog'
../../../../../../../rtems-4.5.0/c/src/lib/include/zilog/z8036.h
../../../../../../pc686/lib/include/zilog/z8036.h
../../../../../../../rtems-4.5.0/c/src/lib/include/zilog/z8530.h
../../../../../../pc686/lib/include/zilog/z8530.h
../../../../../../../rtems-4.5.0/c/src/lib/include/zilog/z8536.h
../../../../../../pc686/lib/include/zilog/z8536.h
../../../../../../rtems-4.5.0/c/src/lib/include/chain.h
../../../../../pc686/lib/include/chain.h
../../../../../../rtems-4.5.0/c/src/lib/include/console.h
../../../../../pc686/lib/include/console.h
../../../../../../rtems-4.5.0/c/src/lib/include/clockdrv.h
../../../../../pc686/lib/include/clockdrv.h
../../../../../../rtems-4.5.0/c/src/lib/include/iosupp.h
../../../../../pc686/lib/include/iosupp.h
../../../../../../rtems-4.5.0/c/src/lib/include/ringbuf.h
../../../../../pc686/lib/include/ringbuf.h
../../../../../../rtems-4.5.0/c/src/lib/include/spurious.h
../../../../../pc686/lib/include/spurious.h
../../../../../../rtems-4.5.0/c/src/lib/include/timerdrv.h
../../../../../pc686/lib/include/timerdrv.h
../../../../../../rtems-4.5.0/c/src/lib/include/vmeintr.h
../../../../../pc686/lib/include/vmeintr.h
Making preinstall in libc
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libc'
../../../../../../rtems-4.5.0/c/src/lib/libc/libcsupport.h
../../../../../pc686/lib/include/libcsupport.h
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs.h
../../../../../pc686/lib/include/imfs.h
../../../../../../rtems-4.5.0/c/src/lib/libc/assoc.h
../../../../../pc686/lib/include/rtems/assoc.h
../../../../../../rtems-4.5.0/c/src/lib/libc/error.h
../../../../../pc686/lib/include/rtems/error.h
../../../../../../rtems-4.5.0/c/src/lib/libc/libio.h
../../../../../pc686/lib/include/rtems/libio.h
Making preinstall in libcpu
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libcpu'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libcpu/i386'
/bin/sh
../../../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/../../../../../mkinstalldirs
../../../../../.././pc686/lib/include/libcpu
../../../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/cpu.h
../../../../../.././pc686/lib/include/libcpu/cpu.h
../../../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/registers.h
../../../../../.././pc686/lib/include/libcpu/registers.h
../../../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/cpuModel.h
../../../../../.././pc686/lib/include/libcpu/cpuModel.h
Making preinstall in libbsp
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp'
Making preinstall in shmdr
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/shmdr'
../../../../../../../rtems-4.5.0/c/src/lib/libbsp/shmdr/shm_driver.h
../../../../../../pc686/lib/include/shm_driver.h
../../../../../../../rtems-4.5.0/c/src/lib/libbsp/shmdr/mpci.h
../../../../../../pc686/lib/include/mpci.h
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386'
Making preinstall in shared
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/shared'
Making preinstall in irq
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/shared/irq'
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/shared/irq/irq.h
../../../../../../../../pc686/lib/include/irq.h
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/shared/irq/irq_asm.h
../../../../../../../../pc686/lib/include/irq_asm.h
Making preinstall in io
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/shared/io'
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/shared/io/bspIo.h
../../../../../../../../pc686/lib/include/bspIo.h
Making preinstall in comm
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/shared/comm'
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/shared/comm/uart.h
../../../../../../../../pc686/lib/include/uart.h
Making preinstall in pci
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/shared/pci'
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/shared/pci/pcibios.h
../../../../../../../../pc686/lib/include/pcibios.h
Making preinstall in pc386
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386'
Making preinstall in .
../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/bsp_specs
../../../../../../.././pc686/lib/bsp_specs
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/include'
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/include/bsp.h
../../../../../../../../pc686/lib/include/bsp.h
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/include/crt.h
../../../../../../../../pc686/lib/include/crt.h
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/include/wd80x3.h
../../../../../../../../pc686/lib/include/wd80x3.h
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/../../shared/include/coverhd.h
../../../../../../../../pc686/lib/include/coverhd.h
Making preinstall in tools
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/tools'
/bin/sh
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/tools/../../../../../../../mkinstalldirs
../../../../../../../.././pc686/build-tools
gcc -DHAVE_STRTOUL=1  -I.
-I../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/tools
-g -O2 -c
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
gcc  -g -O2  -o bin2boot  bin2boot.o
/usr/bin/install -c  bin2boot
../../../../../../../.././pc686/build-tools/bin2boot
Making preinstall in start
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/start'
Making preinstall in startup
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/startup'
Making preinstall in clock
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/clock'
Making preinstall in console
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/console'
Making preinstall in timer
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/timer'
Making preinstall in ne2000
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/ne2000'
Making preinstall in wd8003
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/wd8003'
Making preinstall in 3c509
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/3c509'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/wrapup'
Making preinstall in libmisc
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libmisc'
Making preinstall in dummy
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libmisc/dummy'
Making preinstall in dumpbuf
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libmisc/dumpbuf'
../../../../../../rtems-4.5.0/c/src/libmisc/dumpbuf/dumpbuf.h
../../../../../pc686/lib/include/rtems/dumpbuf.h
Making preinstall in stackchk
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libmisc/stackchk'
../../../../../../rtems-4.5.0/c/src/libmisc/stackchk/stackchk.h
../../../../../pc686/lib/include/rtems/stackchk.h
Making preinstall in monitor
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libmisc/monitor'
../../../../../../rtems-4.5.0/c/src/libmisc/monitor/monitor.h
../../../../../pc686/lib/include/rtems/monitor.h
../../../../../../rtems-4.5.0/c/src/libmisc/monitor/symbols.h
../../../../../pc686/lib/include/rtems/symbols.h
Making preinstall in cpuuse
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libmisc/cpuuse'
../../../../../../rtems-4.5.0/c/src/libmisc/cpuuse/cpuuse.h
../../../../../pc686/lib/include/rtems/cpuuse.h
Making preinstall in rtmonuse
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libmisc/rtmonuse'
../../../../../../rtems-4.5.0/c/src/libmisc/rtmonuse/rtmonuse.h
../../../../../pc686/lib/include/rtems/rtmonuse.h
Making preinstall in untar
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libmisc/untar'
../../../../../../rtems-4.5.0/c/src/libmisc/untar/untar.h
../../../../../pc686/lib/include/rtems/untar.h
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libmisc/wrapup'
Making preinstall in libchip
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libchip'
Making preinstall in rtc
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libchip/rtc'
../../../../../../rtems-4.5.0/c/src/libchip/rtc/rtc.h
../../../../../pc686/lib/include/libchip/rtc.h
../../../../../../rtems-4.5.0/c/src/libchip/rtc/icm7170.h
../../../../../pc686/lib/include/libchip/icm7170.h
../../../../../../rtems-4.5.0/c/src/libchip/rtc/m48t08.h
../../../../../pc686/lib/include/libchip/m48t08.h
Making preinstall in serial
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libchip/serial'
../../../../../../rtems-4.5.0/c/src/libchip/serial/mc68681.h
../../../../../pc686/lib/include/libchip/mc68681.h
../../../../../../rtems-4.5.0/c/src/libchip/serial/ns16550.h
../../../../../pc686/lib/include/libchip/ns16550.h
../../../../../../rtems-4.5.0/c/src/libchip/serial/z85c30.h
../../../../../pc686/lib/include/libchip/z85c30.h
../../../../../../rtems-4.5.0/c/src/libchip/serial/serial.h
../../../../../pc686/lib/include/libchip/serial.h
Making preinstall in network
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libchip/network'
../../../../../../rtems-4.5.0/c/src/libchip/network/sonic.h
../../../../../pc686/lib/include/libchip/sonic.h
Making preinstall in libnetworking
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/include'
../../../../../../rtems-4.5.0/c/src/libnetworking/include/../bpfilter.h
../../../../../pc686/lib/include/bpfilter.h
../../../../../../rtems-4.5.0/c/src/libnetworking/include/../loop.h
../../../../../pc686/lib/include/loop.h
../../../../../../rtems-4.5.0/c/src/libnetworking/include/../netdb.h
../../../../../pc686/lib/include/netdb.h
../../../../../../rtems-4.5.0/c/src/libnetworking/include/../opt_ipfw.h
../../../../../pc686/lib/include/opt_ipfw.h
../../../../../../rtems-4.5.0/c/src/libnetworking/include/../opt_mrouting.h
../../../../../pc686/lib/include/opt_mrouting.h
../../../../../../rtems-4.5.0/c/src/libnetworking/include/../opt_tcpdebug.h
../../../../../pc686/lib/include/opt_tcpdebug.h
../../../../../../rtems-4.5.0/c/src/libnetworking/include/../poll.h
../../../../../pc686/lib/include/poll.h
../../../../../../rtems-4.5.0/c/src/libnetworking/include/../resolv.h
../../../../../pc686/lib/include/resolv.h
../../../../../../rtems-4.5.0/c/src/libnetworking/include/../syslog.h
../../../../../pc686/lib/include/syslog.h
../../../../../../rtems-4.5.0/c/src/libnetworking/include/../memory.h
../../../../../pc686/lib/include/memory.h
Making preinstall in arpa
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/arpa'
../../../../../../rtems-4.5.0/c/src/libnetworking/arpa/ftp.h
../../../../../pc686/lib/include/arpa/ftp.h
../../../../../../rtems-4.5.0/c/src/libnetworking/arpa/inet.h
../../../../../pc686/lib/include/arpa/inet.h
../../../../../../rtems-4.5.0/c/src/libnetworking/arpa/nameser.h
../../../../../pc686/lib/include/arpa/nameser.h
../../../../../../rtems-4.5.0/c/src/libnetworking/arpa/nameser_compat.h
../../../../../pc686/lib/include/arpa/nameser_compat.h
../../../../../../rtems-4.5.0/c/src/libnetworking/arpa/telnet.h
../../../../../pc686/lib/include/arpa/telnet.h
Making preinstall in kern
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/kern'
Making preinstall in machine
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/machine'
../../../../../../rtems-4.5.0/c/src/libnetworking/machine/conf.h
../../../../../pc686/lib/include/machine/conf.h
../../../../../../rtems-4.5.0/c/src/libnetworking/machine/cpu.h
../../../../../pc686/lib/include/machine/cpu.h
../../../../../../rtems-4.5.0/c/src/libnetworking/machine/cpufunc.h
../../../../../pc686/lib/include/machine/cpufunc.h
../../../../../../rtems-4.5.0/c/src/libnetworking/machine/endian.h
../../../../../pc686/lib/include/machine/endian.h
../../../../../../rtems-4.5.0/c/src/libnetworking/machine/in_cksum.h
../../../../../pc686/lib/include/machine/in_cksum.h
../../../../../../rtems-4.5.0/c/src/libnetworking/machine/limits.h
../../../../../pc686/lib/include/machine/limits.h
../../../../../../rtems-4.5.0/c/src/libnetworking/machine/param.h
../../../../../pc686/lib/include/machine/param.h
../../../../../../rtems-4.5.0/c/src/libnetworking/machine/types.h
../../../../../pc686/lib/include/machine/types.h
../../../../../../rtems-4.5.0/c/src/libnetworking/machine/vmparam.h
../../../../../pc686/lib/include/machine/vmparam.h
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/sys'
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/buf.h
../../../../../pc686/lib/include/sys/buf.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/callout.h
../../../../../pc686/lib/include/sys/callout.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/cdefs.h
../../../../../pc686/lib/include/sys/cdefs.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/conf.h
../../../../../pc686/lib/include/sys/conf.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/domain.h
../../../../../pc686/lib/include/sys/domain.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/filio.h
../../../../../pc686/lib/include/sys/filio.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/ioccom.h
../../../../../pc686/lib/include/sys/ioccom.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/ioctl.h
../../../../../pc686/lib/include/sys/ioctl.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/kernel.h
../../../../../pc686/lib/include/sys/kernel.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/libkern.h
../../../../../pc686/lib/include/sys/libkern.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/malloc.h
../../../../../pc686/lib/include/sys/malloc.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/mbuf.h
../../../../../pc686/lib/include/sys/mbuf.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/mount.h
../../../../../pc686/lib/include/sys/mount.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/param.h
../../../../../pc686/lib/include/sys/param.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/proc.h
../../../../../pc686/lib/include/sys/proc.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/protosw.h
../../../../../pc686/lib/include/sys/protosw.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/queue.h
../../../../../pc686/lib/include/sys/queue.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/reboot.h
../../../../../pc686/lib/include/sys/reboot.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/resourcevar.h
../../../../../pc686/lib/include/sys/resourcevar.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/rtprio.h
../../../../../pc686/lib/include/sys/rtprio.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/select.h
../../../../../pc686/lib/include/sys/select.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/signalvar.h
../../../../../pc686/lib/include/sys/signalvar.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/socket.h
../../../../../pc686/lib/include/sys/socket.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/socketvar.h
../../../../../pc686/lib/include/sys/socketvar.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/sockio.h
../../../../../pc686/lib/include/sys/sockio.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/sysctl.h
../../../../../pc686/lib/include/sys/sysctl.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/syslimits.h
../../../../../pc686/lib/include/sys/syslimits.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/syslog.h
../../../../../pc686/lib/include/sys/syslog.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/systm.h
../../../../../pc686/lib/include/sys/systm.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/ttycom.h
../../../../../pc686/lib/include/sys/ttycom.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/ttydefaults.h
../../../../../pc686/lib/include/sys/ttydefaults.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/ucred.h
../../../../../pc686/lib/include/sys/ucred.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/uio.h
../../../../../pc686/lib/include/sys/uio.h
../../../../../../rtems-4.5.0/c/src/libnetworking/sys/un.h
../../../../../pc686/lib/include/sys/un.h
Making preinstall in vm
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/vm'
../../../../../../rtems-4.5.0/c/src/libnetworking/vm/vm.h
../../../../../pc686/lib/include/vm/vm.h
../../../../../../rtems-4.5.0/c/src/libnetworking/vm/vm_extern.h
../../../../../pc686/lib/include/vm/vm_extern.h
../../../../../../rtems-4.5.0/c/src/libnetworking/vm/vm_kern.h
../../../../../pc686/lib/include/vm/vm_kern.h
../../../../../../rtems-4.5.0/c/src/libnetworking/vm/vm_param.h
../../../../../pc686/lib/include/vm/vm_param.h
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/lib'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/libc'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/net'
../../../../../../rtems-4.5.0/c/src/libnetworking/net/bpf.h
../../../../../pc686/lib/include/net/bpf.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/ethernet.h
../../../../../pc686/lib/include/net/ethernet.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/if.h
../../../../../pc686/lib/include/net/if.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/if_arp.h
../../../../../pc686/lib/include/net/if_arp.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/if_dl.h
../../../../../pc686/lib/include/net/if_dl.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/if_llc.h
../../../../../pc686/lib/include/net/if_llc.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/if_ppp.h
../../../../../pc686/lib/include/net/if_ppp.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/if_types.h
../../../../../pc686/lib/include/net/if_types.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/netisr.h
../../../../../pc686/lib/include/net/netisr.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/ppp-comp.h
../../../../../pc686/lib/include/net/ppp-comp.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/ppp_defs.h
../../../../../pc686/lib/include/net/ppp_defs.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/radix.h
../../../../../pc686/lib/include/net/radix.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/raw_cb.h
../../../../../pc686/lib/include/net/raw_cb.h
../../../../../../rtems-4.5.0/c/src/libnetworking/net/route.h
../../../../../pc686/lib/include/net/route.h
Making preinstall in netinet
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/netinet'
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/icmp_var.h
../../../../../pc686/lib/include/netinet/icmp_var.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/if_ether.h
../../../../../pc686/lib/include/netinet/if_ether.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/igmp.h
../../../../../pc686/lib/include/netinet/igmp.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/igmp_var.h
../../../../../pc686/lib/include/netinet/igmp_var.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/in.h
../../../../../pc686/lib/include/netinet/in.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/in_pcb.h
../../../../../pc686/lib/include/netinet/in_pcb.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/in_systm.h
../../../../../pc686/lib/include/netinet/in_systm.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/in_var.h
../../../../../pc686/lib/include/netinet/in_var.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/ip.h
../../../../../pc686/lib/include/netinet/ip.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/ip_fw.h
../../../../../pc686/lib/include/netinet/ip_fw.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/ip_icmp.h
../../../../../pc686/lib/include/netinet/ip_icmp.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/ip_mroute.h
../../../../../pc686/lib/include/netinet/ip_mroute.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/ip_var.h
../../../../../pc686/lib/include/netinet/ip_var.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/tcp.h
../../../../../pc686/lib/include/netinet/tcp.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/tcp_debug.h
../../../../../pc686/lib/include/netinet/tcp_debug.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/tcp_fsm.h
../../../../../pc686/lib/include/netinet/tcp_fsm.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/tcp_seq.h
../../../../../pc686/lib/include/netinet/tcp_seq.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/tcp_timer.h
../../../../../pc686/lib/include/netinet/tcp_timer.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/tcp_var.h
../../../../../pc686/lib/include/netinet/tcp_var.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/tcpip.h
../../../../../pc686/lib/include/netinet/tcpip.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/udp.h
../../../../../pc686/lib/include/netinet/udp.h
../../../../../../rtems-4.5.0/c/src/libnetworking/netinet/udp_var.h
../../../../../pc686/lib/include/netinet/udp_var.h
Making preinstall in nfs
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/nfs'
../../../../../../rtems-4.5.0/c/src/libnetworking/nfs/krpc.h
../../../../../pc686/lib/include/nfs/krpc.h
../../../../../../rtems-4.5.0/c/src/libnetworking/nfs/nfs.h
../../../../../pc686/lib/include/nfs/nfs.h
../../../../../../rtems-4.5.0/c/src/libnetworking/nfs/nfsdiskless.h
../../../../../pc686/lib/include/nfs/nfsdiskless.h
../../../../../../rtems-4.5.0/c/src/libnetworking/nfs/nfsproto.h
../../../../../pc686/lib/include/nfs/nfsproto.h
../../../../../../rtems-4.5.0/c/src/libnetworking/nfs/rpcv2.h
../../../../../pc686/lib/include/nfs/rpcv2.h
../../../../../../rtems-4.5.0/c/src/libnetworking/nfs/xdr_subs.h
../../../../../pc686/lib/include/nfs/xdr_subs.h
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/rtems'
../../../../../../rtems-4.5.0/c/src/libnetworking/rtems/rtems_bsdnet.h
../../../../../pc686/lib/include/rtems/rtems_bsdnet.h
../../../../../../rtems-4.5.0/c/src/libnetworking/rtems/rtems_bsdnet_internal.h
../../../../../pc686/lib/include/rtems/rtems_bsdnet_internal.h
../../../../../../rtems-4.5.0/c/src/libnetworking/rtems/tftp.h
../../../../../pc686/lib/include/rtems/tftp.h
Making preinstall in rtems_servers
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/rtems_servers'
../../../../../../rtems-4.5.0/c/src/libnetworking/rtems_servers/ftpd.h
../../../../../pc686/lib/include/ftpd.h
Making preinstall in pppd
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/pppd'
Making preinstall in rtems_webserver
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/rtems_webserver'
../../../../../../rtems-4.5.0/c/src/libnetworking/rtems_webserver/rtems_webserver.h
../../../../../pc686/lib/include/rtems_webserver.h
/bin/sh
../../../../../../rtems-4.5.0/c/src/libnetworking/../../../mkinstalldirs
../../../../../pc686/lib/include/goahead
../../../../../../rtems-4.5.0/c/src/libnetworking/rtems_webserver/ej.h
../../../../../pc686/lib/include/goahead/ej.h
../../../../../../rtems-4.5.0/c/src/libnetworking/rtems_webserver/uemf.h
../../../../../pc686/lib/include/goahead/uemf.h
../../../../../../rtems-4.5.0/c/src/libnetworking/rtems_webserver/webs.h
../../../../../pc686/lib/include/goahead/webs.h
../../../../../../rtems-4.5.0/c/src/libnetworking/rtems_webserver/wsIntrn.h
../../../../../pc686/lib/include/goahead/wsIntrn.h
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/libnetworking/wrapup'
Making preinstall in librpc
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/librpc'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/librpc/include'
Making preinstall in rpc
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/librpc/include/rpc'
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/auth.h
../../../../../../pc686/lib/include/rpc/auth.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/auth_des.h
../../../../../../pc686/lib/include/rpc/auth_des.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/auth_unix.h
../../../../../../pc686/lib/include/rpc/auth_unix.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/clnt.h
../../../../../../pc686/lib/include/rpc/clnt.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/des.h
../../../../../../pc686/lib/include/rpc/des.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/des_crypt.h
../../../../../../pc686/lib/include/rpc/des_crypt.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/pmap_clnt.h
../../../../../../pc686/lib/include/rpc/pmap_clnt.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/pmap_prot.h
../../../../../../pc686/lib/include/rpc/pmap_prot.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/pmap_rmt.h
../../../../../../pc686/lib/include/rpc/pmap_rmt.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/rpc.h
../../../../../../pc686/lib/include/rpc/rpc.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/rpc_com.h
../../../../../../pc686/lib/include/rpc/rpc_com.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/rpc_msg.h
../../../../../../pc686/lib/include/rpc/rpc_msg.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/svc.h
../../../../../../pc686/lib/include/rpc/svc.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/svc_auth.h
../../../../../../pc686/lib/include/rpc/svc_auth.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/types.h
../../../../../../pc686/lib/include/rpc/types.h
../../../../../../../rtems-4.5.0/c/src/librpc/include/rpc/xdr.h
../../../../../../pc686/lib/include/rpc/xdr.h
Making preinstall in rpcsvc
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/librpc/include/rpcsvc'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/librpc/src'
Making preinstall in xdr
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/librpc/src/xdr'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/librpc/src/rpc'
Making preinstall in PSD.doc
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/librpc/src/rpc/PSD.doc'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/wrapup'
make[4]: Nothing to be done for `preinstall'.
Making preinstall in tests
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/tools'
Making preinstall in generic
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/tools/generic'
/usr/bin/install -c  difftest ../../../../../.././pc686/tests/difftest
/usr/bin/install -c  sorttimes ../../../../../.././pc686/tests/sorttimes
Making preinstall in support
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/support'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/support/include'
Making preinstall in stubdr
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/support/stubdr'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/support/wrapup'
Making preinstall in samples
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/samples'
Making preinstall in hello
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/samples/hello'
Making preinstall in ticker
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/samples/ticker'
Making preinstall in base_sp
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/samples/base_sp'
Making preinstall in unlimited
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/samples/unlimited'
Making preinstall in minimum
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/samples/minimum'
Making preinstall in base_mp
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/samples/base_mp'
Making preinstall in node1
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/samples/base_mp/node1'
Making preinstall in node2
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/samples/base_mp/node2'
Making preinstall in cdtest
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/samples/cdtest'
Making preinstall in paranoia
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/tests/samples/paranoia'
make[5]: Leaving directory
make[5]: Entering directory
make[5]: Nothing to be done for `preinstall-am'.
make[4]: Leaving directory
make[4]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686'
make[4]: Nothing to be done for `preinstall-am'.
make[3]: Leaving directory
make[2]: Leaving directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c'
Making all in pc686
make[2]: Entering directory
Making all in make
make[3]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/make'
Making all in compilers
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/make/compilers'
make[4]: Nothing to be done for `all'.
Making all in custom
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/make/custom'
make[4]: Nothing to be done for `all-am'.
Making all in exec
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec'
Making all in score
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score'
Making all in include
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/include'
Making all in rtems
make[6]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/include/rtems'
Making all in score
make[7]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/include/rtems/score'
make[7]: Nothing to be done for `all'.
make[7]: Nothing to be done for `all-am'.
make[6]: Nothing to be done for `all-am'.
Making all in inline
Making all in rtems
Making all in score
Making all in macros
Making all in rtems
Making all in score
Making all in cpu
Making all in i386
Making all in rtems
Making all in score
make[8]: Entering directory
make[8]: Nothing to be done for `all'.
make[8]: Nothing to be done for `all-am'.
mkdir o-optimize
/opt/rtems/bin//i386-cc --pipe -B../../../../../../.././pc686/lib/
-specs bsp_specs -qrtems -g -Wall -ansi -fasm    -mcpu=i686     -c  -O4
-o o-optimize/cpu.o
../../../../../../../../rtems-4.5.0/c/src/exec/score/cpu/i386/cpu.c
-specs bsp_specs -qrtems     -mcpu=i686     -c  -DASM -o
o-optimize/cpu_asm.o
../../../../../../../../rtems-4.5.0/c/src/exec/score/cpu/i386/cpu_asm.S
-specs bsp_specs -qrtems -g -Wall -ansi -fasm    -mcpu=i686      -L
../../../../../../.././pc686/lib  -O4  -qnolinkcmds -nostdlib -Wl,-r  -o
o-optimize/rtems-cpu.rel o-optimize/cpu.o o-optimize/cpu_asm.o
o-optimize/rtems.o
../../../../../../../../rtems-4.5.0/c/src/exec/score/cpu/i386/rtems.S
/usr/bin/install -c -m 644 o-optimize/rtems.o
../../../../../../.././pc686/lib/rtems.o
Making all in src
mkdir o-optimize
/opt/rtems/bin//i386-cc --pipe -B../../../../../../pc686/lib/ -specs
-D__RTEMS_INSIDE__ -O4 -o o-optimize/apiext.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/apiext.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/chain.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/chain.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremsg.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremsg.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremsgbroadcast.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremsgbroadcast.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremsgclose.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremsgclose.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremsgflush.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremsgflush.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremsgflushwait.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremsgflushwait.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremsginsert.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremsginsert.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremsgflushsupp.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremsgflushsupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremsgseize.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremsgseize.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremsgsubmit.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremsgsubmit.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremutex.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremutex.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremutexflush.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremutexflush.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremutexseize.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremutexseize.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coremutexsurrender.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coremutexsurrender.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coresem.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coresem.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coresemflush.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coresemflush.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coresemseize.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coresemseize.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coresemsurrender.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coresemsurrender.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/heap.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/heap.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/heapallocate.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/heapallocate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/heapextend.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/heapextend.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/heapfree.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/heapfree.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/heapsizeofuserarea.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/heapsizeofuserarea.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/heapwalk.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/heapwalk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/interr.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/interr.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/isr.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/isr.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/object.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/object.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectallocate.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectallocate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectallocatebyindex.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectallocatebyindex.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectclearname.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectclearname.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectcomparenameraw.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectcomparenameraw.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectcomparenamestring.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectcomparenamestring.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectcopynameraw.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectcopynameraw.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectcopynamestring.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectcopynamestring.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectextendinformation.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectextendinformation.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectfree.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectfree.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectget.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectget.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectgetbyindex.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectgetbyindex.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectgetnext.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectgetnext.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectinitializeinformation.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectinitializeinformation.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectnametoid.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectnametoid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/objectshrinkinformation.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/objectshrinkinformation.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/thread.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/thread.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadchangepriority.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadchangepriority.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadclearstate.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadclearstate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadclose.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadclose.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadcreateidle.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadcreateidle.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threaddelayended.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threaddelayended.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threaddispatch.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threaddispatch.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadevaluatemode.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadevaluatemode.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadget.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadget.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadhandler.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadhandler.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadidlebody.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadidlebody.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadinitialize.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadinitialize.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadloadenv.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadloadenv.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadready.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadready.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadresettimeslice.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadresettimeslice.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadreset.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadreset.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadrestart.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadrestart.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadresume.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadresume.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadrotatequeue.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadrotatequeue.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadsetpriority.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadsetpriority.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadsetstate.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadsetstate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadsettransient.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadsettransient.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadstackallocate.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadstackallocate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadstackfree.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadstackfree.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadstart.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadstart.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadstartmultitasking.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadstartmultitasking.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadsuspend.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadsuspend.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadtickletimeslice.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadtickletimeslice.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadyieldprocessor.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadyieldprocessor.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadq.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadq.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqdequeue.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqdequeue.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqdequeuefifo.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqdequeuefifo.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqdequeuepriority.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqdequeuepriority.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqenqueue.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqenqueue.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqenqueuefifo.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqenqueuefifo.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqenqueuepriority.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqenqueuepriority.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqextract.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqextract.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqextractfifo.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqextractfifo.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqextractpriority.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqextractpriority.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqextractwithproxy.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqextractwithproxy.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqfirst.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqfirst.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqfirstfifo.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqfirstfifo.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqfirstpriority.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqfirstpriority.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqflush.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqflush.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/threadqtimeout.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/threadqtimeout.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coretod.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coretod.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coretodset.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coretodset.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coretodtickle.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coretodtickle.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coretodtoseconds.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coretodtoseconds.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/coretodvalidate.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/coretodvalidate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/userext.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/userext.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/watchdog.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/watchdog.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/watchdogadjust.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/watchdogadjust.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/watchdoginsert.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/watchdoginsert.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/watchdogremove.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/watchdogremove.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/watchdogtickle.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/watchdogtickle.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/wkspace.o
../../../../../../../rtems-4.5.0/c/src/exec/score/src/wkspace.c
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/score/src'
make[5]: Nothing to be done for `all-am'.
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/include'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/include/rtems'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/include/rtems/rtems'
make[7]: Leaving directory
make[6]: Leaving directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/inline'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/inline/rtems'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/inline/rtems/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/macros'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/macros/rtems'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/macros/rtems/rtems'
Making all in optman
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/optman'
mkdir o-optimize
bsp_specs -qrtems -g -Wall -ansi -fasm    -mcpu=i686     -c  -O4 -o
o-optimize/no-dpmem.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/optman/no-dpmem.c
../../../../../../pc686/lib  -O4  -qnolinkcmds -nostdlib -Wl,-r  -o
o-optimize/no-dpmem.rel o-optimize/no-dpmem.o
o-optimize/no-event.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/optman/no-event.c
o-optimize/no-event.rel o-optimize/no-event.o
o-optimize/no-msg.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/optman/no-msg.c
o-optimize/no-msg.rel o-optimize/no-msg.o
o-optimize/no-mp.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/optman/no-mp.c
o-optimize/no-mp.rel o-optimize/no-mp.o
o-optimize/no-part.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/optman/no-part.c
o-optimize/no-part.rel o-optimize/no-part.o
o-optimize/no-region.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/optman/no-region.c
o-optimize/no-region.rel o-optimize/no-region.o
o-optimize/no-rtmon.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/optman/no-rtmon.c
o-optimize/no-rtmon.rel o-optimize/no-rtmon.o
o-optimize/no-sem.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/optman/no-sem.c
o-optimize/no-sem.rel o-optimize/no-sem.o
o-optimize/no-signal.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/optman/no-signal.c
o-optimize/no-signal.rel o-optimize/no-signal.o
o-optimize/no-timer.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/optman/no-timer.c
o-optimize/no-timer.rel o-optimize/no-timer.o
/usr/bin/install -c -m 644 o-optimize/no-dpmem.rel
../../../../../../pc686/lib/no-dpmem.rel
/usr/bin/install -c -m 644 o-optimize/no-event.rel
../../../../../../pc686/lib/no-event.rel
/usr/bin/install -c -m 644 o-optimize/no-msg.rel
../../../../../../pc686/lib/no-msg.rel
/usr/bin/install -c -m 644 o-optimize/no-mp.rel
../../../../../../pc686/lib/no-mp.rel
/usr/bin/install -c -m 644 o-optimize/no-part.rel
../../../../../../pc686/lib/no-part.rel
/usr/bin/install -c -m 644 o-optimize/no-region.rel
../../../../../../pc686/lib/no-region.rel
/usr/bin/install -c -m 644 o-optimize/no-rtmon.rel
../../../../../../pc686/lib/no-rtmon.rel
/usr/bin/install -c -m 644 o-optimize/no-sem.rel
../../../../../../pc686/lib/no-sem.rel
/usr/bin/install -c -m 644 o-optimize/no-signal.rel
../../../../../../pc686/lib/no-signal.rel
/usr/bin/install -c -m 644 o-optimize/no-timer.rel
../../../../../../pc686/lib/no-timer.rel
rm o-optimize/no-mp.o o-optimize/no-timer.o o-optimize/no-event.o
o-optimize/no-sem.o o-optimize/no-signal.o o-optimize/no-rtmon.o
o-optimize/no-region.o o-optimize/no-dpmem.o o-optimize/no-part.o
o-optimize/no-msg.o
Making all in src
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/rtems/src'
mkdir o-optimize
-D__RTEMS_INSIDE__ -O4 -o o-optimize/attr.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/attr.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/tasks.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/tasks.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskcreate.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskcreate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskdelete.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskdelete.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskgetnote.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskgetnote.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskident.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskident.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskinitusers.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskinitusers.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskissuspended.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskissuspended.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskmode.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskmode.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskrestart.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskrestart.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskresume.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskresume.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/tasksetnote.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/tasksetnote.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/tasksetpriority.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/tasksetpriority.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskstart.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskstart.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/tasksuspend.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/tasksuspend.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskwakeafter.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskwakeafter.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskwakewhen.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskwakewhen.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskvariableadd.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskvariableadd.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskvariabledelete.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskvariabledelete.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/taskvariableget.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/taskvariableget.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ratemon.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/ratemon.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ratemoncancel.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/ratemoncancel.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ratemoncreate.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/ratemoncreate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ratemondelete.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/ratemondelete.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ratemongetstatus.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/ratemongetstatus.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ratemonident.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/ratemonident.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ratemonperiod.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/ratemonperiod.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ratemontimeout.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/ratemontimeout.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/intr.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/intr.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/intrbody.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/intrbody.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/intrcatch.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/intrcatch.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/rtclock.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/rtclock.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/clockget.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/clockget.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/clockset.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/clockset.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/clocktick.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/clocktick.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/rtemstimer.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/rtemstimer.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/timercancel.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/timercancel.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/timercreate.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/timercreate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/timerdelete.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/timerdelete.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/timerfireafter.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/timerfireafter.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/timerfirewhen.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/timerfirewhen.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/timerident.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/timerident.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/timerreset.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/timerreset.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sem.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/sem.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semcreate.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/semcreate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semdelete.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/semdelete.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semident.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/semident.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semobtain.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/semobtain.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semrelease.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/semrelease.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semflush.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/semflush.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semtranslatereturncode.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/semtranslatereturncode.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msg.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msg.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqallocate.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqallocate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqbroadcast.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqbroadcast.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqcreate.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqcreate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqdelete.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqdelete.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqflush.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqflush.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqgetnumberpending.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqgetnumberpending.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqident.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqident.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqreceive.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqreceive.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqsend.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqsend.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqsubmit.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqsubmit.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqtranslatereturncode.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqtranslatereturncode.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgqurgent.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/msgqurgent.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/event.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/event.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/eventreceive.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/eventreceive.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/eventseize.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/eventseize.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/eventsend.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/eventsend.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/eventsurrender.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/eventsurrender.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/eventtimeout.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/eventtimeout.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/signal.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/signal.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/signalcatch.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/signalcatch.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/signalsend.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/signalsend.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/part.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/part.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/partcreate.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/partcreate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/partdelete.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/partdelete.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/partgetbuffer.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/partgetbuffer.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/partident.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/partident.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/partreturnbuffer.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/partreturnbuffer.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/region.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/region.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/regioncreate.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/regioncreate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/regiondelete.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/regiondelete.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/regionextend.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/regionextend.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/regiongetsegment.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/regiongetsegment.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/regiongetsegmentsize.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/regiongetsegmentsize.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/regionident.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/regionident.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/regionreturnsegment.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/regionreturnsegment.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/dpmem.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/dpmem.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/dpmemcreate.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/dpmemcreate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/dpmemdelete.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/dpmemdelete.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/dpmemexternal2internal.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/dpmemexternal2internal.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/dpmemident.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/dpmemident.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/dpmeminternal2external.o
../../../../../../../rtems-4.5.0/c/src/exec/rtems/src/dpmeminternal2external.c
Making all in posix
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/include'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/include/rtems'
Making all in posix
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/include/rtems/posix'
Making all in sys
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/include/sys'
make[6]: Nothing to be done for `all'.
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/inline'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/inline/rtems'
Making all in posix
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/inline/rtems/posix'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/macros'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/macros/rtems'
Making all in posix
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/macros/rtems/posix'
Making all in src
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/src'
mkdir o-optimize
-D__RTEMS_INSIDE__ -O4 -o o-optimize/adasupp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/adasupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/cancel.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/cancel.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/cancelrun.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/cancelrun.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/cleanuppop.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/cleanuppop.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/cleanuppush.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/cleanuppush.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/setcancelstate.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/setcancelstate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/setcanceltype.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/setcanceltype.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/testcancel.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/testcancel.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/cond.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/cond.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condattrdestroy.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condattrdestroy.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condattrgetpshared.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condattrgetpshared.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condattrinit.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condattrinit.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condattrsetpshared.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condattrsetpshared.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condbroadcast.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condbroadcast.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/conddefaultattributes.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/conddefaultattributes.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/conddestroy.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/conddestroy.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condinit.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condinit.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condmp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condmp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condsignal.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condsignal.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condsignalsupp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condsignalsupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condtimedwait.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condtimedwait.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condwait.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condwait.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/condwaitsupp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/condwaitsupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/getegid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/getegid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/geteuid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/geteuid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/getgid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/getgid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/getgroups.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/getgroups.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/getlogin.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/getlogin.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/getpgrp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/getpgrp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/getpid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/getpid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/getppid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/getppid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/getuid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/getuid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/setpgid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/setpgid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/setsid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/setsid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/key.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/key.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/keycreate.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/keycreate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/keydelete.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/keydelete.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/keygetspecific.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/keygetspecific.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/keyrundestructors.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/keyrundestructors.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/keysetspecific.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/keysetspecific.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueue.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueue.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueueclose.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueueclose.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuecreatesupp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuecreatesupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuedeletesupp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuedeletesupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuegetattr.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuegetattr.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuenametoid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuenametoid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuenotify.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuenotify.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueueopen.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueueopen.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuereceive.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuereceive.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuerecvsupp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuerecvsupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuesend.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuesend.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuesendsupp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuesendsupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuesetattr.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuesetattr.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuetimedreceive.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuetimedreceive.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuetimedsend.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuetimedsend.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueuetranslatereturncode.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueuetranslatereturncode.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mqueueunlink.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mqueueunlink.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutex.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutex.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexattrdestroy.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexattrdestroy.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexattrgetprioceiling.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexattrgetprioceiling.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexattrgetprotocol.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexattrgetprotocol.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexattrgetpshared.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexattrgetpshared.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexattrinit.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexattrinit.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexattrsetprioceiling.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexattrsetprioceiling.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexattrsetprotocol.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexattrsetprotocol.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexattrsetpshared.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexattrsetpshared.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexdefaultattributes.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexdefaultattributes.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexdestroy.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexdestroy.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexfromcorestatus.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexfromcorestatus.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexgetprioceiling.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexgetprioceiling.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexinit.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexinit.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexlock.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexlock.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexlocksupp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexlocksupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexmp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexmp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexsetprioceiling.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexsetprioceiling.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutextimedlock.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutextimedlock.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutextrylock.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutextrylock.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mutexunlock.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/mutexunlock.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthread.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthread.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadsetcputime.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadsetcputime.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadgetcputime.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadgetcputime.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadgetcpuclockid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadgetcpuclockid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadonce.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadonce.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadequal.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadequal.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadself.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadself.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadexit.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadexit.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreaddetach.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreaddetach.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadjoin.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadjoin.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadcreate.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadcreate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrsetdetachstate.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrsetdetachstate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrgetdetachstate.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrgetdetachstate.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrgetstackaddr.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrgetstackaddr.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrsetstackaddr.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrsetstackaddr.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrgetstacksize.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrgetstacksize.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrsetstacksize.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrsetstacksize.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrinit.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrinit.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrdestroy.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrdestroy.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadsetschedparam.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadsetschedparam.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadgetschedparam.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadgetschedparam.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrsetschedparam.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrsetschedparam.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrgetschedparam.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrgetschedparam.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrgetschedpolicy.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrgetschedpolicy.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrsetschedpolicy.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrsetschedpolicy.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrgetinheritsched.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrgetinheritsched.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrsetinheritsched.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrsetinheritsched.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrgetscope.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrgetscope.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadattrsetscope.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadattrsetscope.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/psignal.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/psignal.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/alarm.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/alarm.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/kill.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/kill.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/killinfo.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/killinfo.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pause.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pause.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/psignalclearprocesssignals.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/psignalclearprocesssignals.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/psignalsetprocesssignals.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/psignalsetprocesssignals.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/psignalchecksignal.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/psignalchecksignal.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/psignalclearsignals.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/psignalclearsignals.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/psignalunblockthread.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/psignalunblockthread.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadkill.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadkill.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadsigmask.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadsigmask.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigaction.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigaction.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigaddset.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigaddset.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigdelset.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigdelset.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigemptyset.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigemptyset.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigfillset.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigfillset.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigismember.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigismember.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigpending.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigpending.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigprocmask.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigprocmask.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigqueue.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigqueue.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigsuspend.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigsuspend.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigtimedwait.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigtimedwait.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigwait.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigwait.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sigwaitinfo.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sigwaitinfo.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/signal_2.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/signal_2.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sched.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sched.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semaphore.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semaphore.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semaphorecreatesupp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semaphorecreatesupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semaphoredeletesupp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semaphoredeletesupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semaphoremp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semaphoremp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semaphorenametoid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semaphorenametoid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semaphorewaitsupp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semaphorewaitsupp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semclose.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semclose.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semdestroy.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semdestroy.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semgetvalue.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semgetvalue.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/seminit.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/seminit.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semopen.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semopen.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sempost.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sempost.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semtimedwait.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semtimedwait.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semtrywait.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semtrywait.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semunlink.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semunlink.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/semwait.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/semwait.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sysconf.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sysconf.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/time.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/time.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/posixtimespecsubtract.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/posixtimespecsubtract.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/posixtimespectointerval.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/posixtimespectointerval.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/posixintervaltotimespec.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/posixintervaltotimespec.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/clockgetcpuclockid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/clockgetcpuclockid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/clockgetenableattr.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/clockgetenableattr.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/clockgetres.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/clockgetres.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/clockgettime.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/clockgettime.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/clocksetenableattr.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/clocksetenableattr.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/clocksettime.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/clocksettime.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/nanosleep.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/nanosleep.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sleep.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/sleep.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ptimer.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/ptimer.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ptimer1.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/ptimer1.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/types.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/types.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/execl.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/execl.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/execle.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/execle.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/execlp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/execlp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/execv.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/execv.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/execve.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/execve.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/execvp.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/execvp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/fork.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/fork.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/pthreadatfork.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/pthreadatfork.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/wait.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/wait.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/waitpid.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/waitpid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/aio.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/aio.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/utsname.o
../../../../../../../rtems-4.5.0/c/src/exec/posix/src/utsname.c
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/posix/optman'
mkdir o-optimize
Making all in itron
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/include'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/include/rtems'
Making all in itron
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/include/rtems/itron'
Making all in itronsys
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/include/itronsys'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/inline'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/inline/rtems'
Making all in itron
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/inline/rtems/itron'
Making all in src
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/itron/src'
mkdir o-optimize
-D__RTEMS_INSIDE__ -O4 -o o-optimize/task.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/task.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/cre_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/cre_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/del_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/del_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sta_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/sta_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ext_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/ext_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/exd_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/exd_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ter_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/ter_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/dis_dsp.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/dis_dsp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ena_dsp.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/ena_dsp.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/chg_pri.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/chg_pri.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/rot_rdq.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/rot_rdq.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/rel_wai.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/rel_wai.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/get_tid.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/get_tid.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ref_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/ref_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sus_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/sus_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/rsm_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/rsm_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/frsm_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/frsm_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/slp_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/slp_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/tslp_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/tslp_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/wup_tsk.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/wup_tsk.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/can_wup.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/can_wup.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/itronsem.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/itronsem.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/cre_sem.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/cre_sem.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/del_sem.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/del_sem.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/preq_sem.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/preq_sem.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ref_sem.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/ref_sem.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/sig_sem.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/sig_sem.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/twai_sem.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/twai_sem.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/wai_sem.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/wai_sem.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/eventflags.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/eventflags.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/mbox.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/mbox.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgbuffer.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/msgbuffer.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/msgbuffertranslatereturncode.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/msgbuffertranslatereturncode.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/cre_mbf.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/cre_mbf.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/del_mbf.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/del_mbf.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/prcv_mbf.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/prcv_mbf.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/psnd_mbf.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/psnd_mbf.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/rcv_mbf.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/rcv_mbf.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/ref_mbf.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/ref_mbf.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/snd_mbf.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/snd_mbf.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/trcv_mbf.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/trcv_mbf.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/tsnd_mbf.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/tsnd_mbf.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/port.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/port.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/itronintr.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/itronintr.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/vmempool.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/vmempool.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/fmempool.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/fmempool.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/itrontime.o
../../../../../../../rtems-4.5.0/c/src/exec/itron/src/itrontime.c
Making all in sapi
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/include'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/include/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/inline'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/inline/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/macros'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/macros/rtems'
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/optman'
mkdir o-optimize
o-optimize/no-ext.o
../../../../../../../rtems-4.5.0/c/src/exec/sapi/optman/no-ext.c
o-optimize/no-ext.rel o-optimize/no-ext.o
o-optimize/no-io.o
../../../../../../../rtems-4.5.0/c/src/exec/sapi/optman/no-io.c
o-optimize/no-io.rel o-optimize/no-io.o
/usr/bin/install -c -m 644 o-optimize/no-ext.rel
../../../../../../pc686/lib/no-ext.rel
/usr/bin/install -c -m 644 o-optimize/no-io.rel
../../../../../../pc686/lib/no-io.rel
rm o-optimize/no-io.o o-optimize/no-ext.o
make[5]: Leaving directory
Making all in src
make[5]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/sapi/src'
mkdir o-optimize
-D__RTEMS_INSIDE__ -O4 -o o-optimize/debug.o
../../../../../../../rtems-4.5.0/c/src/exec/sapi/src/debug.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/entrytable.o
../../../../../../../rtems-4.5.0/c/src/exec/sapi/src/entrytable.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/extension.o
../../../../../../../rtems-4.5.0/c/src/exec/sapi/src/extension.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/fatal.o
../../../../../../../rtems-4.5.0/c/src/exec/sapi/src/fatal.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/exinit.o
../../../../../../../rtems-4.5.0/c/src/exec/sapi/src/exinit.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/io.o
../../../../../../../rtems-4.5.0/c/src/exec/sapi/src/io.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/itronapi.o
../../../../../../../rtems-4.5.0/c/src/exec/sapi/src/itronapi.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/posixapi.o
../../../../../../../rtems-4.5.0/c/src/exec/sapi/src/posixapi.c
-D__RTEMS_INSIDE__ -O4 -o o-optimize/rtemsapi.o
../../../../../../../rtems-4.5.0/c/src/exec/sapi/src/rtemsapi.c
make[4]: Leaving directory
Making all in wrapup
make[4]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/wrapup'
Making all in rtems
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/wrapup/rtems'
mkdir o-optimize
rm -f o-optimize/librtems.a
/opt/rtems/i386-rtems/bin/ar ruv o-optimize/librtems.a
../../score/cpu/i386/o-optimize/rtems-cpu.rel
../../score/src/o-optimize/apiext.o ../../score/src/o-optimize/chain.o
../../score/src/o-optimize/coremsgbroadcast.o
../../score/src/o-optimize/coremsgclose.o
../../score/src/o-optimize/coremsgflush.o
../../score/src/o-optimize/coremsgflushsupp.o
../../score/src/o-optimize/coremsgflushwait.o
../../score/src/o-optimize/coremsginsert.o
../../score/src/o-optimize/coremsg.o
../../score/src/o-optimize/coremsgseize.o
../../score/src/o-optimize/coremsgsubmit.o
../../score/src/o-optimize/coremutexflush.o
../../score/src/o-optimize/coremutex.o
../../score/src/o-optimize/coremutexseize.o
../../score/src/o-optimize/coremutexsurrender.o
../../score/src/o-optimize/coresemflush.o
../../score/src/o-optimize/coresem.o
../../score/src/o-optimize/coresemseize.o
../../score/src/o-optimize/coresemsurrender.o
../../score/src/o-optimize/coretod.o
../../score/src/o-optimize/coretodset.o
../../score/src/o-optimize/coretodtickle.o
../../score/src/o-optimize/coretodtoseconds.o
../../score/src/o-optimize/coretodvalidate.o
../../score/src/o-optimize/heapallocate.o
../../score/src/o-optimize/heapextend.o
../../score/src/o-optimize/heapfree.o ../../score/src/o-optimize/heap.o
../../score/src/o-optimize/heapsizeofuserarea.o
../../score/src/o-optimize/heapwalk.o
../../score/src/o-optimize/interr.o ../../score/src/o-optimize/isr.o
../../score/src/o-optimize/objectallocatebyindex.o
../../score/src/o-optimize/objectallocate.o
../../score/src/o-optimize/objectclearname.o
../../score/src/o-optimize/objectcomparenameraw.o
../../score/src/o-optimize/objectcomparenamestring.o
../../score/src/o-optimize/objectcopynameraw.o
../../score/src/o-optimize/objectcopynamestring.o
../../score/src/o-optimize/objectextendinformation.o
../../score/src/o-optimize/objectfree.o
../../score/src/o-optimize/objectgetbyindex.o
../../score/src/o-optimize/objectgetnext.o
../../score/src/o-optimize/objectget.o
../../score/src/o-optimize/objectinitializeinformation.o
../../score/src/o-optimize/objectnametoid.o
../../score/src/o-optimize/object.o
../../score/src/o-optimize/objectshrinkinformation.o
../../score/src/o-optimize/threadchangepriority.o
../../score/src/o-optimize/threadclearstate.o
../../score/src/o-optimize/threadclose.o
../../score/src/o-optimize/threadcreateidle.o
../../score/src/o-optimize/threaddelayended.o
../../score/src/o-optimize/threaddispatch.o
../../score/src/o-optimize/threadevaluatemode.o
../../score/src/o-optimize/threadget.o
../../score/src/o-optimize/threadhandler.o
../../score/src/o-optimize/threadidlebody.o
../../score/src/o-optimize/threadinitialize.o
../../score/src/o-optimize/threadloadenv.o
../../score/src/o-optimize/thread.o
../../score/src/o-optimize/threadqdequeuefifo.o
../../score/src/o-optimize/threadqdequeue.o
../../score/src/o-optimize/threadqdequeuepriority.o
../../score/src/o-optimize/threadqenqueuefifo.o
../../score/src/o-optimize/threadqenqueue.o
../../score/src/o-optimize/threadqenqueuepriority.o
../../score/src/o-optimize/threadqextractfifo.o
../../score/src/o-optimize/threadqextract.o
../../score/src/o-optimize/threadqextractpriority.o
../../score/src/o-optimize/threadqextractwithproxy.o
../../score/src/o-optimize/threadqfirstfifo.o
../../score/src/o-optimize/threadqfirst.o
../../score/src/o-optimize/threadqfirstpriority.o
../../score/src/o-optimize/threadqflush.o
../../score/src/o-optimize/threadq.o
../../score/src/o-optimize/threadqtimeout.o
../../score/src/o-optimize/threadready.o
../../score/src/o-optimize/threadreset.o
../../score/src/o-optimize/threadresettimeslice.o
../../score/src/o-optimize/threadrestart.o
../../score/src/o-optimize/threadresume.o
../../score/src/o-optimize/threadrotatequeue.o
../../score/src/o-optimize/threadsetpriority.o
../../score/src/o-optimize/threadsetstate.o
../../score/src/o-optimize/threadsettransient.o
../../score/src/o-optimize/threadstackallocate.o
../../score/src/o-optimize/threadstackfree.o
../../score/src/o-optimize/threadstartmultitasking.o
../../score/src/o-optimize/threadstart.o
../../score/src/o-optimize/threadsuspend.o
../../score/src/o-optimize/threadtickletimeslice.o
../../score/src/o-optimize/threadyieldprocessor.o
../../score/src/o-optimize/userext.o
../../score/src/o-optimize/watchdogadjust.o
../../score/src/o-optimize/watchdoginsert.o
../../score/src/o-optimize/watchdog.o
../../score/src/o-optimize/watchdogremove.o
../../score/src/o-optimize/watchdogtickle.o
../../score/src/o-optimize/wkspace.o ../../rtems/src/o-optimize/attr.o
../../rtems/src/o-optimize/clockget.o
../../rtems/src/o-optimize/clockset.o
../../rtems/src/o-optimize/clocktick.o
../../rtems/src/o-optimize/dpmemcreate.o
../../rtems/src/o-optimize/dpmemdelete.o
../../rtems/src/o-optimize/dpmemexternal2internal.o
../../rtems/src/o-optimize/dpmemident.o
../../rtems/src/o-optimize/dpmeminternal2external.o
../../rtems/src/o-optimize/dpmem.o ../../rtems/src/o-optimize/event.o
../../rtems/src/o-optimize/eventreceive.o
../../rtems/src/o-optimize/eventseize.o
../../rtems/src/o-optimize/eventsend.o
../../rtems/src/o-optimize/eventsurrender.o
../../rtems/src/o-optimize/eventtimeout.o
../../rtems/src/o-optimize/intrbody.o
../../rtems/src/o-optimize/intrcatch.o ../../rtems/src/o-optimize/intr.o
../../rtems/src/o-optimize/msg.o
../../rtems/src/o-optimize/msgqallocate.o
../../rtems/src/o-optimize/msgqbroadcast.o
../../rtems/src/o-optimize/msgqcreate.o
../../rtems/src/o-optimize/msgqdelete.o
../../rtems/src/o-optimize/msgqflush.o
../../rtems/src/o-optimize/msgqgetnumberpending.o
../../rtems/src/o-optimize/msgqident.o
../../rtems/src/o-optimize/msgqreceive.o
../../rtems/src/o-optimize/msgqsend.o
../../rtems/src/o-optimize/msgqsubmit.o
../../rtems/src/o-optimize/msgqtranslatereturncode.o
../../rtems/src/o-optimize/msgqurgent.o
../../rtems/src/o-optimize/partcreate.o
../../rtems/src/o-optimize/partdelete.o
../../rtems/src/o-optimize/partgetbuffer.o
../../rtems/src/o-optimize/partident.o ../../rtems/src/o-optimize/part.o
../../rtems/src/o-optimize/partreturnbuffer.o
../../rtems/src/o-optimize/ratemoncancel.o
../../rtems/src/o-optimize/ratemoncreate.o
../../rtems/src/o-optimize/ratemondelete.o
../../rtems/src/o-optimize/ratemongetstatus.o
../../rtems/src/o-optimize/ratemonident.o
../../rtems/src/o-optimize/ratemon.o
../../rtems/src/o-optimize/ratemonperiod.o
../../rtems/src/o-optimize/ratemontimeout.o
../../rtems/src/o-optimize/regioncreate.o
../../rtems/src/o-optimize/regiondelete.o
../../rtems/src/o-optimize/regionextend.o
../../rtems/src/o-optimize/regiongetsegment.o
../../rtems/src/o-optimize/regiongetsegmentsize.o
../../rtems/src/o-optimize/regionident.o
../../rtems/src/o-optimize/region.o
../../rtems/src/o-optimize/regionreturnsegment.o
../../rtems/src/o-optimize/rtclock.o
../../rtems/src/o-optimize/rtemstimer.o
../../rtems/src/o-optimize/semcreate.o
../../rtems/src/o-optimize/semdelete.o
../../rtems/src/o-optimize/semflush.o
../../rtems/src/o-optimize/semident.o ../../rtems/src/o-optimize/sem.o
../../rtems/src/o-optimize/semobtain.o
../../rtems/src/o-optimize/semrelease.o
../../rtems/src/o-optimize/semtranslatereturncode.o
../../rtems/src/o-optimize/signalcatch.o
../../rtems/src/o-optimize/signal.o
../../rtems/src/o-optimize/signalsend.o
../../rtems/src/o-optimize/taskcreate.o
../../rtems/src/o-optimize/taskdelete.o
../../rtems/src/o-optimize/taskgetnote.o
../../rtems/src/o-optimize/taskident.o
../../rtems/src/o-optimize/taskinitusers.o
../../rtems/src/o-optimize/taskissuspended.o
../../rtems/src/o-optimize/taskmode.o
../../rtems/src/o-optimize/taskrestart.o
../../rtems/src/o-optimize/taskresume.o
../../rtems/src/o-optimize/tasksetnote.o
../../rtems/src/o-optimize/tasksetpriority.o
../../rtems/src/o-optimize/tasks.o
../../rtems/src/o-optimize/taskstart.o
../../rtems/src/o-optimize/tasksuspend.o
../../rtems/src/o-optimize/taskvariableadd.o
../../rtems/src/o-optimize/taskvariabledelete.o
../../rtems/src/o-optimize/taskvariableget.o
../../rtems/src/o-optimize/taskwakeafter.o
../../rtems/src/o-optimize/taskwakewhen.o
../../rtems/src/o-optimize/timercancel.o
../../rtems/src/o-optimize/timercreate.o
../../rtems/src/o-optimize/timerdelete.o
../../rtems/src/o-optimize/timerfireafter.o
../../rtems/src/o-optimize/timerfirewhen.o
../../rtems/src/o-optimize/timerident.o
../../rtems/src/o-optimize/timerreset.o
../../sapi/src/o-optimize/debug.o ../../sapi/src/o-optimize/entrytable.o
../../sapi/src/o-optimize/exinit.o ../../sapi/src/o-optimize/extension.o
../../sapi/src/o-optimize/fatal.o ../../sapi/src/o-optimize/io.o
../../sapi/src/o-optimize/itronapi.o
../../sapi/src/o-optimize/posixapi.o
../../sapi/src/o-optimize/rtemsapi.o
a - ../../score/cpu/i386/o-optimize/rtems-cpu.rel
a - ../../score/src/o-optimize/apiext.o
a - ../../score/src/o-optimize/chain.o
a - ../../score/src/o-optimize/coremsgbroadcast.o
a - ../../score/src/o-optimize/coremsgclose.o
a - ../../score/src/o-optimize/coremsgflush.o
a - ../../score/src/o-optimize/coremsgflushsupp.o
a - ../../score/src/o-optimize/coremsgflushwait.o
a - ../../score/src/o-optimize/coremsginsert.o
a - ../../score/src/o-optimize/coremsg.o
a - ../../score/src/o-optimize/coremsgseize.o
a - ../../score/src/o-optimize/coremsgsubmit.o
a - ../../score/src/o-optimize/coremutexflush.o
a - ../../score/src/o-optimize/coremutex.o
a - ../../score/src/o-optimize/coremutexseize.o
a - ../../score/src/o-optimize/coremutexsurrender.o
a - ../../score/src/o-optimize/coresemflush.o
a - ../../score/src/o-optimize/coresem.o
a - ../../score/src/o-optimize/coresemseize.o
a - ../../score/src/o-optimize/coresemsurrender.o
a - ../../score/src/o-optimize/coretod.o
a - ../../score/src/o-optimize/coretodset.o
a - ../../score/src/o-optimize/coretodtickle.o
a - ../../score/src/o-optimize/coretodtoseconds.o
a - ../../score/src/o-optimize/coretodvalidate.o
a - ../../score/src/o-optimize/heapallocate.o
a - ../../score/src/o-optimize/heapextend.o
a - ../../score/src/o-optimize/heapfree.o
a - ../../score/src/o-optimize/heap.o
a - ../../score/src/o-optimize/heapsizeofuserarea.o
a - ../../score/src/o-optimize/heapwalk.o
a - ../../score/src/o-optimize/interr.o
a - ../../score/src/o-optimize/isr.o
a - ../../score/src/o-optimize/objectallocatebyindex.o
a - ../../score/src/o-optimize/objectallocate.o
a - ../../score/src/o-optimize/objectclearname.o
a - ../../score/src/o-optimize/objectcomparenameraw.o
a - ../../score/src/o-optimize/objectcomparenamestring.o
a - ../../score/src/o-optimize/objectcopynameraw.o
a - ../../score/src/o-optimize/objectcopynamestring.o
a - ../../score/src/o-optimize/objectextendinformation.o
a - ../../score/src/o-optimize/objectfree.o
a - ../../score/src/o-optimize/objectgetbyindex.o
a - ../../score/src/o-optimize/objectgetnext.o
a - ../../score/src/o-optimize/objectget.o
a - ../../score/src/o-optimize/objectinitializeinformation.o
a - ../../score/src/o-optimize/objectnametoid.o
a - ../../score/src/o-optimize/object.o
a - ../../score/src/o-optimize/objectshrinkinformation.o
a - ../../score/src/o-optimize/threadchangepriority.o
a - ../../score/src/o-optimize/threadclearstate.o
a - ../../score/src/o-optimize/threadclose.o
a - ../../score/src/o-optimize/threadcreateidle.o
a - ../../score/src/o-optimize/threaddelayended.o
a - ../../score/src/o-optimize/threaddispatch.o
a - ../../score/src/o-optimize/threadevaluatemode.o
a - ../../score/src/o-optimize/threadget.o
a - ../../score/src/o-optimize/threadhandler.o
a - ../../score/src/o-optimize/threadidlebody.o
a - ../../score/src/o-optimize/threadinitialize.o
a - ../../score/src/o-optimize/threadloadenv.o
a - ../../score/src/o-optimize/thread.o
a - ../../score/src/o-optimize/threadqdequeuefifo.o
a - ../../score/src/o-optimize/threadqdequeue.o
a - ../../score/src/o-optimize/threadqdequeuepriority.o
a - ../../score/src/o-optimize/threadqenqueuefifo.o
a - ../../score/src/o-optimize/threadqenqueue.o
a - ../../score/src/o-optimize/threadqenqueuepriority.o
a - ../../score/src/o-optimize/threadqextractfifo.o
a - ../../score/src/o-optimize/threadqextract.o
a - ../../score/src/o-optimize/threadqextractpriority.o
a - ../../score/src/o-optimize/threadqextractwithproxy.o
a - ../../score/src/o-optimize/threadqfirstfifo.o
a - ../../score/src/o-optimize/threadqfirst.o
a - ../../score/src/o-optimize/threadqfirstpriority.o
a - ../../score/src/o-optimize/threadqflush.o
a - ../../score/src/o-optimize/threadq.o
a - ../../score/src/o-optimize/threadqtimeout.o
a - ../../score/src/o-optimize/threadready.o
a - ../../score/src/o-optimize/threadreset.o
a - ../../score/src/o-optimize/threadresettimeslice.o
a - ../../score/src/o-optimize/threadrestart.o
a - ../../score/src/o-optimize/threadresume.o
a - ../../score/src/o-optimize/threadrotatequeue.o
a - ../../score/src/o-optimize/threadsetpriority.o
a - ../../score/src/o-optimize/threadsetstate.o
a - ../../score/src/o-optimize/threadsettransient.o
a - ../../score/src/o-optimize/threadstackallocate.o
a - ../../score/src/o-optimize/threadstackfree.o
a - ../../score/src/o-optimize/threadstartmultitasking.o
a - ../../score/src/o-optimize/threadstart.o
a - ../../score/src/o-optimize/threadsuspend.o
a - ../../score/src/o-optimize/threadtickletimeslice.o
a - ../../score/src/o-optimize/threadyieldprocessor.o
a - ../../score/src/o-optimize/userext.o
a - ../../score/src/o-optimize/watchdogadjust.o
a - ../../score/src/o-optimize/watchdoginsert.o
a - ../../score/src/o-optimize/watchdog.o
a - ../../score/src/o-optimize/watchdogremove.o
a - ../../score/src/o-optimize/watchdogtickle.o
a - ../../score/src/o-optimize/wkspace.o
a - ../../rtems/src/o-optimize/attr.o
a - ../../rtems/src/o-optimize/clockget.o
a - ../../rtems/src/o-optimize/clockset.o
a - ../../rtems/src/o-optimize/clocktick.o
a - ../../rtems/src/o-optimize/dpmemcreate.o
a - ../../rtems/src/o-optimize/dpmemdelete.o
a - ../../rtems/src/o-optimize/dpmemexternal2internal.o
a - ../../rtems/src/o-optimize/dpmemident.o
a - ../../rtems/src/o-optimize/dpmeminternal2external.o
a - ../../rtems/src/o-optimize/dpmem.o
a - ../../rtems/src/o-optimize/event.o
a - ../../rtems/src/o-optimize/eventreceive.o
a - ../../rtems/src/o-optimize/eventseize.o
a - ../../rtems/src/o-optimize/eventsend.o
a - ../../rtems/src/o-optimize/eventsurrender.o
a - ../../rtems/src/o-optimize/eventtimeout.o
a - ../../rtems/src/o-optimize/intrbody.o
a - ../../rtems/src/o-optimize/intrcatch.o
a - ../../rtems/src/o-optimize/intr.o
a - ../../rtems/src/o-optimize/msg.o
a - ../../rtems/src/o-optimize/msgqallocate.o
a - ../../rtems/src/o-optimize/msgqbroadcast.o
a - ../../rtems/src/o-optimize/msgqcreate.o
a - ../../rtems/src/o-optimize/msgqdelete.o
a - ../../rtems/src/o-optimize/msgqflush.o
a - ../../rtems/src/o-optimize/msgqgetnumberpending.o
a - ../../rtems/src/o-optimize/msgqident.o
a - ../../rtems/src/o-optimize/msgqreceive.o
a - ../../rtems/src/o-optimize/msgqsend.o
a - ../../rtems/src/o-optimize/msgqsubmit.o
a - ../../rtems/src/o-optimize/msgqtranslatereturncode.o
a - ../../rtems/src/o-optimize/msgqurgent.o
a - ../../rtems/src/o-optimize/partcreate.o
a - ../../rtems/src/o-optimize/partdelete.o
a - ../../rtems/src/o-optimize/partgetbuffer.o
a - ../../rtems/src/o-optimize/partident.o
a - ../../rtems/src/o-optimize/part.o
a - ../../rtems/src/o-optimize/partreturnbuffer.o
a - ../../rtems/src/o-optimize/ratemoncancel.o
a - ../../rtems/src/o-optimize/ratemoncreate.o
a - ../../rtems/src/o-optimize/ratemondelete.o
a - ../../rtems/src/o-optimize/ratemongetstatus.o
a - ../../rtems/src/o-optimize/ratemonident.o
a - ../../rtems/src/o-optimize/ratemon.o
a - ../../rtems/src/o-optimize/ratemonperiod.o
a - ../../rtems/src/o-optimize/ratemontimeout.o
a - ../../rtems/src/o-optimize/regioncreate.o
a - ../../rtems/src/o-optimize/regiondelete.o
a - ../../rtems/src/o-optimize/regionextend.o
a - ../../rtems/src/o-optimize/regiongetsegment.o
a - ../../rtems/src/o-optimize/regiongetsegmentsize.o
a - ../../rtems/src/o-optimize/regionident.o
a - ../../rtems/src/o-optimize/region.o
a - ../../rtems/src/o-optimize/regionreturnsegment.o
a - ../../rtems/src/o-optimize/rtclock.o
a - ../../rtems/src/o-optimize/rtemstimer.o
a - ../../rtems/src/o-optimize/semcreate.o
a - ../../rtems/src/o-optimize/semdelete.o
a - ../../rtems/src/o-optimize/semflush.o
a - ../../rtems/src/o-optimize/semident.o
a - ../../rtems/src/o-optimize/sem.o
a - ../../rtems/src/o-optimize/semobtain.o
a - ../../rtems/src/o-optimize/semrelease.o
a - ../../rtems/src/o-optimize/semtranslatereturncode.o
a - ../../rtems/src/o-optimize/signalcatch.o
a - ../../rtems/src/o-optimize/signal.o
a - ../../rtems/src/o-optimize/signalsend.o
a - ../../rtems/src/o-optimize/taskcreate.o
a - ../../rtems/src/o-optimize/taskdelete.o
a - ../../rtems/src/o-optimize/taskgetnote.o
a - ../../rtems/src/o-optimize/taskident.o
a - ../../rtems/src/o-optimize/taskinitusers.o
a - ../../rtems/src/o-optimize/taskissuspended.o
a - ../../rtems/src/o-optimize/taskmode.o
a - ../../rtems/src/o-optimize/taskrestart.o
a - ../../rtems/src/o-optimize/taskresume.o
a - ../../rtems/src/o-optimize/tasksetnote.o
a - ../../rtems/src/o-optimize/tasksetpriority.o
a - ../../rtems/src/o-optimize/tasks.o
a - ../../rtems/src/o-optimize/taskstart.o
a - ../../rtems/src/o-optimize/tasksuspend.o
a - ../../rtems/src/o-optimize/taskvariableadd.o
a - ../../rtems/src/o-optimize/taskvariabledelete.o
a - ../../rtems/src/o-optimize/taskvariableget.o
a - ../../rtems/src/o-optimize/taskwakeafter.o
a - ../../rtems/src/o-optimize/taskwakewhen.o
a - ../../rtems/src/o-optimize/timercancel.o
a - ../../rtems/src/o-optimize/timercreate.o
a - ../../rtems/src/o-optimize/timerdelete.o
a - ../../rtems/src/o-optimize/timerfireafter.o
a - ../../rtems/src/o-optimize/timerfirewhen.o
a - ../../rtems/src/o-optimize/timerident.o
a - ../../rtems/src/o-optimize/timerreset.o
a - ../../sapi/src/o-optimize/debug.o
a - ../../sapi/src/o-optimize/entrytable.o
a - ../../sapi/src/o-optimize/exinit.o
a - ../../sapi/src/o-optimize/extension.o
a - ../../sapi/src/o-optimize/fatal.o
a - ../../sapi/src/o-optimize/io.o
a - ../../sapi/src/o-optimize/itronapi.o
a - ../../sapi/src/o-optimize/posixapi.o
a - ../../sapi/src/o-optimize/rtemsapi.o
/opt/rtems/i386-rtems/bin/ranlib o-optimize/librtems.a
# cd ../../../../../.. ; \
 /bin/sh ../../../../../../tools/cpu/generic/size_rtems pc686 o-optimize
 >../../../../../../pc686/lib/sizeinfo.txt
/usr/bin/install -c -m 644 o-optimize/librtems.a
../../../../../../pc686/lib/librtems.a
Making all in posix
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/wrapup/posix'
mkdir o-optimize
rm -f o-optimize/libposix.a
/opt/rtems/i386-rtems/bin/ar ruv o-optimize/libposix.a
../../posix/src/o-optimize/adasupp.o ../../posix/src/o-optimize/aio.o
../../posix/src/o-optimize/alarm.o ../../posix/src/o-optimize/cancel.o
../../posix/src/o-optimize/cancelrun.o
../../posix/src/o-optimize/cleanuppop.o
../../posix/src/o-optimize/cleanuppush.o
../../posix/src/o-optimize/clockgetcpuclockid.o
../../posix/src/o-optimize/clockgetenableattr.o
../../posix/src/o-optimize/clockgetres.o
../../posix/src/o-optimize/clockgettime.o
../../posix/src/o-optimize/clocksetenableattr.o
../../posix/src/o-optimize/clocksettime.o
../../posix/src/o-optimize/condattrdestroy.o
../../posix/src/o-optimize/condattrgetpshared.o
../../posix/src/o-optimize/condattrinit.o
../../posix/src/o-optimize/condattrsetpshared.o
../../posix/src/o-optimize/condbroadcast.o
../../posix/src/o-optimize/conddefaultattributes.o
../../posix/src/o-optimize/conddestroy.o
../../posix/src/o-optimize/condinit.o
../../posix/src/o-optimize/condmp.o ../../posix/src/o-optimize/cond.o
../../posix/src/o-optimize/condsignal.o
../../posix/src/o-optimize/condsignalsupp.o
../../posix/src/o-optimize/condtimedwait.o
../../posix/src/o-optimize/condwait.o
../../posix/src/o-optimize/condwaitsupp.o
../../posix/src/o-optimize/execle.o ../../posix/src/o-optimize/execl.o
../../posix/src/o-optimize/execlp.o ../../posix/src/o-optimize/execve.o
../../posix/src/o-optimize/execv.o ../../posix/src/o-optimize/execvp.o
../../posix/src/o-optimize/fork.o ../../posix/src/o-optimize/getegid.o
../../posix/src/o-optimize/geteuid.o ../../posix/src/o-optimize/getgid.o
../../posix/src/o-optimize/getgroups.o
../../posix/src/o-optimize/getlogin.o
../../posix/src/o-optimize/getpgrp.o ../../posix/src/o-optimize/getpid.o
../../posix/src/o-optimize/getppid.o ../../posix/src/o-optimize/getuid.o
../../posix/src/o-optimize/keycreate.o
../../posix/src/o-optimize/keydelete.o
../../posix/src/o-optimize/keygetspecific.o
../../posix/src/o-optimize/key.o
../../posix/src/o-optimize/keyrundestructors.o
../../posix/src/o-optimize/keysetspecific.o
../../posix/src/o-optimize/killinfo.o ../../posix/src/o-optimize/kill.o
../../posix/src/o-optimize/mqueueclose.o
../../posix/src/o-optimize/mqueuecreatesupp.o
../../posix/src/o-optimize/mqueuedeletesupp.o
../../posix/src/o-optimize/mqueuegetattr.o
../../posix/src/o-optimize/mqueuenametoid.o
../../posix/src/o-optimize/mqueuenotify.o
../../posix/src/o-optimize/mqueue.o
../../posix/src/o-optimize/mqueueopen.o
../../posix/src/o-optimize/mqueuereceive.o
../../posix/src/o-optimize/mqueuerecvsupp.o
../../posix/src/o-optimize/mqueuesend.o
../../posix/src/o-optimize/mqueuesendsupp.o
../../posix/src/o-optimize/mqueuesetattr.o
../../posix/src/o-optimize/mqueuetimedreceive.o
../../posix/src/o-optimize/mqueuetimedsend.o
../../posix/src/o-optimize/mqueuetranslatereturncode.o
../../posix/src/o-optimize/mqueueunlink.o
../../posix/src/o-optimize/mutexattrdestroy.o
../../posix/src/o-optimize/mutexattrgetprioceiling.o
../../posix/src/o-optimize/mutexattrgetprotocol.o
../../posix/src/o-optimize/mutexattrgetpshared.o
../../posix/src/o-optimize/mutexattrinit.o
../../posix/src/o-optimize/mutexattrsetprioceiling.o
../../posix/src/o-optimize/mutexattrsetprotocol.o
../../posix/src/o-optimize/mutexattrsetpshared.o
../../posix/src/o-optimize/mutexdefaultattributes.o
../../posix/src/o-optimize/mutexdestroy.o
../../posix/src/o-optimize/mutexfromcorestatus.o
../../posix/src/o-optimize/mutexgetprioceiling.o
../../posix/src/o-optimize/mutexinit.o
../../posix/src/o-optimize/mutexlock.o
../../posix/src/o-optimize/mutexlocksupp.o
../../posix/src/o-optimize/mutexmp.o ../../posix/src/o-optimize/mutex.o
../../posix/src/o-optimize/mutexsetprioceiling.o
../../posix/src/o-optimize/mutextimedlock.o
../../posix/src/o-optimize/mutextrylock.o
../../posix/src/o-optimize/mutexunlock.o
../../posix/src/o-optimize/nanosleep.o
../../posix/src/o-optimize/pause.o
../../posix/src/o-optimize/posixintervaltotimespec.o
../../posix/src/o-optimize/posixtimespecsubtract.o
../../posix/src/o-optimize/posixtimespectointerval.o
../../posix/src/o-optimize/psignalchecksignal.o
../../posix/src/o-optimize/psignalclearprocesssignals.o
../../posix/src/o-optimize/psignalclearsignals.o
../../posix/src/o-optimize/psignal.o
../../posix/src/o-optimize/psignalsetprocesssignals.o
../../posix/src/o-optimize/psignalunblockthread.o
../../posix/src/o-optimize/pthreadatfork.o
../../posix/src/o-optimize/pthreadattrdestroy.o
../../posix/src/o-optimize/pthreadattrgetdetachstate.o
../../posix/src/o-optimize/pthreadattrgetinheritsched.o
../../posix/src/o-optimize/pthreadattrgetschedparam.o
../../posix/src/o-optimize/pthreadattrgetschedpolicy.o
../../posix/src/o-optimize/pthreadattrgetscope.o
../../posix/src/o-optimize/pthreadattrgetstackaddr.o
../../posix/src/o-optimize/pthreadattrgetstacksize.o
../../posix/src/o-optimize/pthreadattrinit.o
../../posix/src/o-optimize/pthreadattrsetdetachstate.o
../../posix/src/o-optimize/pthreadattrsetinheritsched.o
../../posix/src/o-optimize/pthreadattrsetschedparam.o
../../posix/src/o-optimize/pthreadattrsetschedpolicy.o
../../posix/src/o-optimize/pthreadattrsetscope.o
../../posix/src/o-optimize/pthreadattrsetstackaddr.o
../../posix/src/o-optimize/pthreadattrsetstacksize.o
../../posix/src/o-optimize/pthreadcreate.o
../../posix/src/o-optimize/pthreaddetach.o
../../posix/src/o-optimize/pthreadequal.o
../../posix/src/o-optimize/pthreadexit.o
../../posix/src/o-optimize/pthreadgetcpuclockid.o
../../posix/src/o-optimize/pthreadgetcputime.o
../../posix/src/o-optimize/pthreadgetschedparam.o
../../posix/src/o-optimize/pthreadjoin.o
../../posix/src/o-optimize/pthreadkill.o
../../posix/src/o-optimize/pthread.o
../../posix/src/o-optimize/pthreadonce.o
../../posix/src/o-optimize/pthreadself.o
../../posix/src/o-optimize/pthreadsetcputime.o
../../posix/src/o-optimize/pthreadsetschedparam.o
../../posix/src/o-optimize/pthreadsigmask.o
../../posix/src/o-optimize/ptimer1.o ../../posix/src/o-optimize/ptimer.o
../../posix/src/o-optimize/sched.o
../../posix/src/o-optimize/semaphorecreatesupp.o
../../posix/src/o-optimize/semaphoredeletesupp.o
../../posix/src/o-optimize/semaphoremp.o
../../posix/src/o-optimize/semaphorenametoid.o
../../posix/src/o-optimize/semaphore.o
../../posix/src/o-optimize/semaphorewaitsupp.o
../../posix/src/o-optimize/semclose.o
../../posix/src/o-optimize/semdestroy.o
../../posix/src/o-optimize/semgetvalue.o
../../posix/src/o-optimize/seminit.o
../../posix/src/o-optimize/semopen.o
../../posix/src/o-optimize/sempost.o
../../posix/src/o-optimize/semtimedwait.o
../../posix/src/o-optimize/semtrywait.o
../../posix/src/o-optimize/semunlink.o
../../posix/src/o-optimize/semwait.o
../../posix/src/o-optimize/setcancelstate.o
../../posix/src/o-optimize/setcanceltype.o
../../posix/src/o-optimize/setpgid.o ../../posix/src/o-optimize/setsid.o
../../posix/src/o-optimize/sigaction.o
../../posix/src/o-optimize/sigaddset.o
../../posix/src/o-optimize/sigdelset.o
../../posix/src/o-optimize/sigemptyset.o
../../posix/src/o-optimize/sigfillset.o
../../posix/src/o-optimize/sigismember.o
../../posix/src/o-optimize/signal_2.o
../../posix/src/o-optimize/sigpending.o
../../posix/src/o-optimize/sigprocmask.o
../../posix/src/o-optimize/sigqueue.o
../../posix/src/o-optimize/sigsuspend.o
../../posix/src/o-optimize/sigtimedwait.o
../../posix/src/o-optimize/sigwaitinfo.o
../../posix/src/o-optimize/sigwait.o ../../posix/src/o-optimize/sleep.o
../../posix/src/o-optimize/sysconf.o
../../posix/src/o-optimize/testcancel.o
../../posix/src/o-optimize/time.o ../../posix/src/o-optimize/types.o
../../posix/src/o-optimize/utsname.o ../../posix/src/o-optimize/wait.o
../../posix/src/o-optimize/waitpid.o
a - ../../posix/src/o-optimize/adasupp.o
a - ../../posix/src/o-optimize/aio.o
a - ../../posix/src/o-optimize/alarm.o
a - ../../posix/src/o-optimize/cancel.o
a - ../../posix/src/o-optimize/cancelrun.o
a - ../../posix/src/o-optimize/cleanuppop.o
a - ../../posix/src/o-optimize/cleanuppush.o
a - ../../posix/src/o-optimize/clockgetcpuclockid.o
a - ../../posix/src/o-optimize/clockgetenableattr.o
a - ../../posix/src/o-optimize/clockgetres.o
a - ../../posix/src/o-optimize/clockgettime.o
a - ../../posix/src/o-optimize/clocksetenableattr.o
a - ../../posix/src/o-optimize/clocksettime.o
a - ../../posix/src/o-optimize/condattrdestroy.o
a - ../../posix/src/o-optimize/condattrgetpshared.o
a - ../../posix/src/o-optimize/condattrinit.o
a - ../../posix/src/o-optimize/condattrsetpshared.o
a - ../../posix/src/o-optimize/condbroadcast.o
a - ../../posix/src/o-optimize/conddefaultattributes.o
a - ../../posix/src/o-optimize/conddestroy.o
a - ../../posix/src/o-optimize/condinit.o
a - ../../posix/src/o-optimize/condmp.o
a - ../../posix/src/o-optimize/cond.o
a - ../../posix/src/o-optimize/condsignal.o
a - ../../posix/src/o-optimize/condsignalsupp.o
a - ../../posix/src/o-optimize/condtimedwait.o
a - ../../posix/src/o-optimize/condwait.o
a - ../../posix/src/o-optimize/condwaitsupp.o
a - ../../posix/src/o-optimize/execle.o
a - ../../posix/src/o-optimize/execl.o
a - ../../posix/src/o-optimize/execlp.o
a - ../../posix/src/o-optimize/execve.o
a - ../../posix/src/o-optimize/execv.o
a - ../../posix/src/o-optimize/execvp.o
a - ../../posix/src/o-optimize/fork.o
a - ../../posix/src/o-optimize/getegid.o
a - ../../posix/src/o-optimize/geteuid.o
a - ../../posix/src/o-optimize/getgid.o
a - ../../posix/src/o-optimize/getgroups.o
a - ../../posix/src/o-optimize/getlogin.o
a - ../../posix/src/o-optimize/getpgrp.o
a - ../../posix/src/o-optimize/getpid.o
a - ../../posix/src/o-optimize/getppid.o
a - ../../posix/src/o-optimize/getuid.o
a - ../../posix/src/o-optimize/keycreate.o
a - ../../posix/src/o-optimize/keydelete.o
a - ../../posix/src/o-optimize/keygetspecific.o
a - ../../posix/src/o-optimize/key.o
a - ../../posix/src/o-optimize/keyrundestructors.o
a - ../../posix/src/o-optimize/keysetspecific.o
a - ../../posix/src/o-optimize/killinfo.o
a - ../../posix/src/o-optimize/kill.o
a - ../../posix/src/o-optimize/mqueueclose.o
a - ../../posix/src/o-optimize/mqueuecreatesupp.o
a - ../../posix/src/o-optimize/mqueuedeletesupp.o
a - ../../posix/src/o-optimize/mqueuegetattr.o
a - ../../posix/src/o-optimize/mqueuenametoid.o
a - ../../posix/src/o-optimize/mqueuenotify.o
a - ../../posix/src/o-optimize/mqueue.o
a - ../../posix/src/o-optimize/mqueueopen.o
a - ../../posix/src/o-optimize/mqueuereceive.o
a - ../../posix/src/o-optimize/mqueuerecvsupp.o
a - ../../posix/src/o-optimize/mqueuesend.o
a - ../../posix/src/o-optimize/mqueuesendsupp.o
a - ../../posix/src/o-optimize/mqueuesetattr.o
a - ../../posix/src/o-optimize/mqueuetimedreceive.o
a - ../../posix/src/o-optimize/mqueuetimedsend.o
a - ../../posix/src/o-optimize/mqueuetranslatereturncode.o
a - ../../posix/src/o-optimize/mqueueunlink.o
a - ../../posix/src/o-optimize/mutexattrdestroy.o
a - ../../posix/src/o-optimize/mutexattrgetprioceiling.o
a - ../../posix/src/o-optimize/mutexattrgetprotocol.o
a - ../../posix/src/o-optimize/mutexattrgetpshared.o
a - ../../posix/src/o-optimize/mutexattrinit.o
a - ../../posix/src/o-optimize/mutexattrsetprioceiling.o
a - ../../posix/src/o-optimize/mutexattrsetprotocol.o
a - ../../posix/src/o-optimize/mutexattrsetpshared.o
a - ../../posix/src/o-optimize/mutexdefaultattributes.o
a - ../../posix/src/o-optimize/mutexdestroy.o
a - ../../posix/src/o-optimize/mutexfromcorestatus.o
a - ../../posix/src/o-optimize/mutexgetprioceiling.o
a - ../../posix/src/o-optimize/mutexinit.o
a - ../../posix/src/o-optimize/mutexlock.o
a - ../../posix/src/o-optimize/mutexlocksupp.o
a - ../../posix/src/o-optimize/mutexmp.o
a - ../../posix/src/o-optimize/mutex.o
a - ../../posix/src/o-optimize/mutexsetprioceiling.o
a - ../../posix/src/o-optimize/mutextimedlock.o
a - ../../posix/src/o-optimize/mutextrylock.o
a - ../../posix/src/o-optimize/mutexunlock.o
a - ../../posix/src/o-optimize/nanosleep.o
a - ../../posix/src/o-optimize/pause.o
a - ../../posix/src/o-optimize/posixintervaltotimespec.o
a - ../../posix/src/o-optimize/posixtimespecsubtract.o
a - ../../posix/src/o-optimize/posixtimespectointerval.o
a - ../../posix/src/o-optimize/psignalchecksignal.o
a - ../../posix/src/o-optimize/psignalclearprocesssignals.o
a - ../../posix/src/o-optimize/psignalclearsignals.o
a - ../../posix/src/o-optimize/psignal.o
a - ../../posix/src/o-optimize/psignalsetprocesssignals.o
a - ../../posix/src/o-optimize/psignalunblockthread.o
a - ../../posix/src/o-optimize/pthreadatfork.o
a - ../../posix/src/o-optimize/pthreadattrdestroy.o
a - ../../posix/src/o-optimize/pthreadattrgetdetachstate.o
a - ../../posix/src/o-optimize/pthreadattrgetinheritsched.o
a - ../../posix/src/o-optimize/pthreadattrgetschedparam.o
a - ../../posix/src/o-optimize/pthreadattrgetschedpolicy.o
a - ../../posix/src/o-optimize/pthreadattrgetscope.o
a - ../../posix/src/o-optimize/pthreadattrgetstackaddr.o
a - ../../posix/src/o-optimize/pthreadattrgetstacksize.o
a - ../../posix/src/o-optimize/pthreadattrinit.o
a - ../../posix/src/o-optimize/pthreadattrsetdetachstate.o
a - ../../posix/src/o-optimize/pthreadattrsetinheritsched.o
a - ../../posix/src/o-optimize/pthreadattrsetschedparam.o
a - ../../posix/src/o-optimize/pthreadattrsetschedpolicy.o
a - ../../posix/src/o-optimize/pthreadattrsetscope.o
a - ../../posix/src/o-optimize/pthreadattrsetstackaddr.o
a - ../../posix/src/o-optimize/pthreadattrsetstacksize.o
a - ../../posix/src/o-optimize/pthreadcreate.o
a - ../../posix/src/o-optimize/pthreaddetach.o
a - ../../posix/src/o-optimize/pthreadequal.o
a - ../../posix/src/o-optimize/pthreadexit.o
a - ../../posix/src/o-optimize/pthreadgetcpuclockid.o
a - ../../posix/src/o-optimize/pthreadgetcputime.o
a - ../../posix/src/o-optimize/pthreadgetschedparam.o
a - ../../posix/src/o-optimize/pthreadjoin.o
a - ../../posix/src/o-optimize/pthreadkill.o
a - ../../posix/src/o-optimize/pthread.o
a - ../../posix/src/o-optimize/pthreadonce.o
a - ../../posix/src/o-optimize/pthreadself.o
a - ../../posix/src/o-optimize/pthreadsetcputime.o
a - ../../posix/src/o-optimize/pthreadsetschedparam.o
a - ../../posix/src/o-optimize/pthreadsigmask.o
a - ../../posix/src/o-optimize/ptimer1.o
a - ../../posix/src/o-optimize/ptimer.o
a - ../../posix/src/o-optimize/sched.o
a - ../../posix/src/o-optimize/semaphorecreatesupp.o
a - ../../posix/src/o-optimize/semaphoredeletesupp.o
a - ../../posix/src/o-optimize/semaphoremp.o
a - ../../posix/src/o-optimize/semaphorenametoid.o
a - ../../posix/src/o-optimize/semaphore.o
a - ../../posix/src/o-optimize/semaphorewaitsupp.o
a - ../../posix/src/o-optimize/semclose.o
a - ../../posix/src/o-optimize/semdestroy.o
a - ../../posix/src/o-optimize/semgetvalue.o
a - ../../posix/src/o-optimize/seminit.o
a - ../../posix/src/o-optimize/semopen.o
a - ../../posix/src/o-optimize/sempost.o
a - ../../posix/src/o-optimize/semtimedwait.o
a - ../../posix/src/o-optimize/semtrywait.o
a - ../../posix/src/o-optimize/semunlink.o
a - ../../posix/src/o-optimize/semwait.o
a - ../../posix/src/o-optimize/setcancelstate.o
a - ../../posix/src/o-optimize/setcanceltype.o
a - ../../posix/src/o-optimize/setpgid.o
a - ../../posix/src/o-optimize/setsid.o
a - ../../posix/src/o-optimize/sigaction.o
a - ../../posix/src/o-optimize/sigaddset.o
a - ../../posix/src/o-optimize/sigdelset.o
a - ../../posix/src/o-optimize/sigemptyset.o
a - ../../posix/src/o-optimize/sigfillset.o
a - ../../posix/src/o-optimize/sigismember.o
a - ../../posix/src/o-optimize/signal_2.o
a - ../../posix/src/o-optimize/sigpending.o
a - ../../posix/src/o-optimize/sigprocmask.o
a - ../../posix/src/o-optimize/sigqueue.o
a - ../../posix/src/o-optimize/sigsuspend.o
a - ../../posix/src/o-optimize/sigtimedwait.o
a - ../../posix/src/o-optimize/sigwaitinfo.o
a - ../../posix/src/o-optimize/sigwait.o
a - ../../posix/src/o-optimize/sleep.o
a - ../../posix/src/o-optimize/sysconf.o
a - ../../posix/src/o-optimize/testcancel.o
a - ../../posix/src/o-optimize/time.o
a - ../../posix/src/o-optimize/types.o
a - ../../posix/src/o-optimize/utsname.o
a - ../../posix/src/o-optimize/wait.o
a - ../../posix/src/o-optimize/waitpid.o
/opt/rtems/i386-rtems/bin/ranlib o-optimize/libposix.a
/usr/bin/install -c -m 644 o-optimize/libposix.a
../../../../../../pc686/lib/libposix.a
Making all in itron
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec/wrapup/itron'
mkdir o-optimize
rm -f o-optimize/libitron.a
/opt/rtems/i386-rtems/bin/ar ruv o-optimize/libitron.a
../../itron/src/o-optimize/can_wup.o
../../itron/src/o-optimize/chg_pri.o
../../itron/src/o-optimize/cre_mbf.o
../../itron/src/o-optimize/cre_sem.o
../../itron/src/o-optimize/cre_tsk.o
../../itron/src/o-optimize/del_mbf.o
../../itron/src/o-optimize/del_sem.o
../../itron/src/o-optimize/del_tsk.o
../../itron/src/o-optimize/dis_dsp.o
../../itron/src/o-optimize/ena_dsp.o
../../itron/src/o-optimize/eventflags.o
../../itron/src/o-optimize/exd_tsk.o
../../itron/src/o-optimize/ext_tsk.o
../../itron/src/o-optimize/fmempool.o
../../itron/src/o-optimize/frsm_tsk.o
../../itron/src/o-optimize/get_tid.o
../../itron/src/o-optimize/itronintr.o
../../itron/src/o-optimize/itronsem.o
../../itron/src/o-optimize/itrontime.o ../../itron/src/o-optimize/mbox.o
../../itron/src/o-optimize/msgbuffer.o
../../itron/src/o-optimize/msgbuffertranslatereturncode.o
../../itron/src/o-optimize/port.o ../../itron/src/o-optimize/prcv_mbf.o
../../itron/src/o-optimize/preq_sem.o
../../itron/src/o-optimize/psnd_mbf.o
../../itron/src/o-optimize/rcv_mbf.o
../../itron/src/o-optimize/ref_mbf.o
../../itron/src/o-optimize/ref_sem.o
../../itron/src/o-optimize/ref_tsk.o
../../itron/src/o-optimize/rel_wai.o
../../itron/src/o-optimize/rot_rdq.o
../../itron/src/o-optimize/rsm_tsk.o
../../itron/src/o-optimize/sig_sem.o
../../itron/src/o-optimize/slp_tsk.o
../../itron/src/o-optimize/snd_mbf.o
../../itron/src/o-optimize/sta_tsk.o
../../itron/src/o-optimize/sus_tsk.o ../../itron/src/o-optimize/task.o
../../itron/src/o-optimize/ter_tsk.o
../../itron/src/o-optimize/trcv_mbf.o
../../itron/src/o-optimize/tslp_tsk.o
../../itron/src/o-optimize/tsnd_mbf.o
../../itron/src/o-optimize/twai_sem.o
../../itron/src/o-optimize/vmempool.o
../../itron/src/o-optimize/wai_sem.o
../../itron/src/o-optimize/wup_tsk.o
a - ../../itron/src/o-optimize/can_wup.o
a - ../../itron/src/o-optimize/chg_pri.o
a - ../../itron/src/o-optimize/cre_mbf.o
a - ../../itron/src/o-optimize/cre_sem.o
a - ../../itron/src/o-optimize/cre_tsk.o
a - ../../itron/src/o-optimize/del_mbf.o
a - ../../itron/src/o-optimize/del_sem.o
a - ../../itron/src/o-optimize/del_tsk.o
a - ../../itron/src/o-optimize/dis_dsp.o
a - ../../itron/src/o-optimize/ena_dsp.o
a - ../../itron/src/o-optimize/eventflags.o
a - ../../itron/src/o-optimize/exd_tsk.o
a - ../../itron/src/o-optimize/ext_tsk.o
a - ../../itron/src/o-optimize/fmempool.o
a - ../../itron/src/o-optimize/frsm_tsk.o
a - ../../itron/src/o-optimize/get_tid.o
a - ../../itron/src/o-optimize/itronintr.o
a - ../../itron/src/o-optimize/itronsem.o
a - ../../itron/src/o-optimize/itrontime.o
a - ../../itron/src/o-optimize/mbox.o
a - ../../itron/src/o-optimize/msgbuffer.o
a - ../../itron/src/o-optimize/msgbuffertranslatereturncode.o
a - ../../itron/src/o-optimize/port.o
a - ../../itron/src/o-optimize/prcv_mbf.o
a - ../../itron/src/o-optimize/preq_sem.o
a - ../../itron/src/o-optimize/psnd_mbf.o
a - ../../itron/src/o-optimize/rcv_mbf.o
a - ../../itron/src/o-optimize/ref_mbf.o
a - ../../itron/src/o-optimize/ref_sem.o
a - ../../itron/src/o-optimize/ref_tsk.o
a - ../../itron/src/o-optimize/rel_wai.o
a - ../../itron/src/o-optimize/rot_rdq.o
a - ../../itron/src/o-optimize/rsm_tsk.o
a - ../../itron/src/o-optimize/sig_sem.o
a - ../../itron/src/o-optimize/slp_tsk.o
a - ../../itron/src/o-optimize/snd_mbf.o
a - ../../itron/src/o-optimize/sta_tsk.o
a - ../../itron/src/o-optimize/sus_tsk.o
a - ../../itron/src/o-optimize/task.o
a - ../../itron/src/o-optimize/ter_tsk.o
a - ../../itron/src/o-optimize/trcv_mbf.o
a - ../../itron/src/o-optimize/tslp_tsk.o
a - ../../itron/src/o-optimize/tsnd_mbf.o
a - ../../itron/src/o-optimize/twai_sem.o
a - ../../itron/src/o-optimize/vmempool.o
a - ../../itron/src/o-optimize/wai_sem.o
a - ../../itron/src/o-optimize/wup_tsk.o
/opt/rtems/i386-rtems/bin/ranlib o-optimize/libitron.a
/usr/bin/install -c -m 644 o-optimize/libitron.a
../../../../../../pc686/lib/libitron.a
make[5]: Nothing to be done for `all-am'.
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/exec'
make[4]: Nothing to be done for `all-am'.
make[3]: Leaving directory
Making all in lib
make[3]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib'
Making all in include
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/include'
Making all in sys
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/include/sys'
make[5]: Nothing to be done for `all'.
Making all in motorola
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/include/motorola'
Making all in zilog
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/include/zilog'
Making all in libc
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libc'
mkdir o-optimize
/opt/rtems/bin//i386-cc --pipe -B../../../../../pc686/lib/ -specs
bsp_specs -qrtems -g -Wall -ansi -fasm    -mcpu=i686     -c   -O4 -o
o-optimize/gxx_wrappers.o
../../../../../../rtems-4.5.0/c/src/lib/libc/gxx_wrappers.c
o-optimize/base_fs.o
../../../../../../rtems-4.5.0/c/src/lib/libc/base_fs.c
o-optimize/mount.o ../../../../../../rtems-4.5.0/c/src/lib/libc/mount.c
o-optimize/unmount.o
../../../../../../rtems-4.5.0/c/src/lib/libc/unmount.c
o-optimize/ioman.o ../../../../../../rtems-4.5.0/c/src/lib/libc/ioman.c
o-optimize/libio.o ../../../../../../rtems-4.5.0/c/src/lib/libc/libio.c
o-optimize/libio_sockets.o
../../../../../../rtems-4.5.0/c/src/lib/libc/libio_sockets.c
o-optimize/eval.o ../../../../../../rtems-4.5.0/c/src/lib/libc/eval.c
o-optimize/fs_null_handlers.o
../../../../../../rtems-4.5.0/c/src/lib/libc/fs_null_handlers.c
o-optimize/malloc.o
../../../../../../rtems-4.5.0/c/src/lib/libc/malloc.c
o-optimize/__brk.o ../../../../../../rtems-4.5.0/c/src/lib/libc/__brk.c
o-optimize/__sbrk.o
../../../../../../rtems-4.5.0/c/src/lib/libc/__sbrk.c
o-optimize/cfgetispeed.o
../../../../../../rtems-4.5.0/c/src/lib/libc/cfgetispeed.c
o-optimize/cfgetospeed.o
../../../../../../rtems-4.5.0/c/src/lib/libc/cfgetospeed.c
o-optimize/cfsetispeed.o
../../../../../../rtems-4.5.0/c/src/lib/libc/cfsetispeed.c
o-optimize/cfsetospeed.o
../../../../../../rtems-4.5.0/c/src/lib/libc/cfsetospeed.c
o-optimize/tcgetattr.o
../../../../../../rtems-4.5.0/c/src/lib/libc/tcgetattr.c
o-optimize/tcsetattr.o
../../../../../../rtems-4.5.0/c/src/lib/libc/tcsetattr.c
o-optimize/tcdrain.o
../../../../../../rtems-4.5.0/c/src/lib/libc/tcdrain.c
o-optimize/tcflow.o
../../../../../../rtems-4.5.0/c/src/lib/libc/tcflow.c
o-optimize/tcflush.o
../../../../../../rtems-4.5.0/c/src/lib/libc/tcflush.c
o-optimize/tcgetprgrp.o
../../../../../../rtems-4.5.0/c/src/lib/libc/tcgetprgrp.c
o-optimize/tcsendbreak.o
../../../../../../rtems-4.5.0/c/src/lib/libc/tcsendbreak.c
o-optimize/tcsetpgrp.o
../../../../../../rtems-4.5.0/c/src/lib/libc/tcsetpgrp.c
o-optimize/termios.o
../../../../../../rtems-4.5.0/c/src/lib/libc/termios.c
o-optimize/termiosinitialize.o
../../../../../../rtems-4.5.0/c/src/lib/libc/termiosinitialize.c
o-optimize/termiosreserveresources.o
../../../../../../rtems-4.5.0/c/src/lib/libc/termiosreserveresources.c
o-optimize/error.o ../../../../../../rtems-4.5.0/c/src/lib/libc/error.c
o-optimize/assoc.o ../../../../../../rtems-4.5.0/c/src/lib/libc/assoc.c
o-optimize/assocnamebad.o
../../../../../../rtems-4.5.0/c/src/lib/libc/assocnamebad.c
o-optimize/__getpid.o
../../../../../../rtems-4.5.0/c/src/lib/libc/__getpid.c
o-optimize/__gettod.o
../../../../../../rtems-4.5.0/c/src/lib/libc/__gettod.c
o-optimize/__times.o
../../../../../../rtems-4.5.0/c/src/lib/libc/__times.c
o-optimize/truncate.o
../../../../../../rtems-4.5.0/c/src/lib/libc/truncate.c
o-optimize/access.o
../../../../../../rtems-4.5.0/c/src/lib/libc/access.c
o-optimize/stat.o ../../../../../../rtems-4.5.0/c/src/lib/libc/stat.c
o-optimize/lstat.o ../../../../../../rtems-4.5.0/c/src/lib/libc/lstat.c
o-optimize/pathconf.o
../../../../../../rtems-4.5.0/c/src/lib/libc/pathconf.c
o-optimize/newlibc.o
../../../../../../rtems-4.5.0/c/src/lib/libc/newlibc.c
o-optimize/no_posix.o
../../../../../../rtems-4.5.0/c/src/lib/libc/no_posix.c
o-optimize/no_libc.o
../../../../../../rtems-4.5.0/c/src/lib/libc/no_libc.c
o-optimize/getpwent.o
../../../../../../rtems-4.5.0/c/src/lib/libc/getpwent.c
o-optimize/getgrent.o
../../../../../../rtems-4.5.0/c/src/lib/libc/getgrent.c
o-optimize/ctermid.o
../../../../../../rtems-4.5.0/c/src/lib/libc/ctermid.c
o-optimize/isatty.o
../../../../../../rtems-4.5.0/c/src/lib/libc/isatty.c
o-optimize/ttyname.o
../../../../../../rtems-4.5.0/c/src/lib/libc/ttyname.c
o-optimize/ttyname_r.o
../../../../../../rtems-4.5.0/c/src/lib/libc/ttyname_r.c
o-optimize/open.o ../../../../../../rtems-4.5.0/c/src/lib/libc/open.c
o-optimize/close.o ../../../../../../rtems-4.5.0/c/src/lib/libc/close.c
o-optimize/read.o ../../../../../../rtems-4.5.0/c/src/lib/libc/read.c
o-optimize/write.o ../../../../../../rtems-4.5.0/c/src/lib/libc/write.c
o-optimize/lseek.o ../../../../../../rtems-4.5.0/c/src/lib/libc/lseek.c
o-optimize/ioctl.o ../../../../../../rtems-4.5.0/c/src/lib/libc/ioctl.c
o-optimize/mkdir.o ../../../../../../rtems-4.5.0/c/src/lib/libc/mkdir.c
o-optimize/mknod.o ../../../../../../rtems-4.5.0/c/src/lib/libc/mknod.c
o-optimize/mkfifo.o
../../../../../../rtems-4.5.0/c/src/lib/libc/mkfifo.c
o-optimize/rmdir.o ../../../../../../rtems-4.5.0/c/src/lib/libc/rmdir.c
o-optimize/chdir.o ../../../../../../rtems-4.5.0/c/src/lib/libc/chdir.c
o-optimize/chmod.o ../../../../../../rtems-4.5.0/c/src/lib/libc/chmod.c
o-optimize/fchmod.o
../../../../../../rtems-4.5.0/c/src/lib/libc/fchmod.c
o-optimize/chown.o ../../../../../../rtems-4.5.0/c/src/lib/libc/chown.c
o-optimize/link.o ../../../../../../rtems-4.5.0/c/src/lib/libc/link.c
o-optimize/unlink.o
../../../../../../rtems-4.5.0/c/src/lib/libc/unlink.c
o-optimize/umask.o ../../../../../../rtems-4.5.0/c/src/lib/libc/umask.c
o-optimize/ftruncate.o
../../../../../../rtems-4.5.0/c/src/lib/libc/ftruncate.c
o-optimize/utime.o ../../../../../../rtems-4.5.0/c/src/lib/libc/utime.c
o-optimize/fstat.o ../../../../../../rtems-4.5.0/c/src/lib/libc/fstat.c
o-optimize/fcntl.o ../../../../../../rtems-4.5.0/c/src/lib/libc/fcntl.c
o-optimize/fpathconf.o
../../../../../../rtems-4.5.0/c/src/lib/libc/fpathconf.c
o-optimize/getdents.o
../../../../../../rtems-4.5.0/c/src/lib/libc/getdents.c
o-optimize/fsync.o ../../../../../../rtems-4.5.0/c/src/lib/libc/fsync.c
o-optimize/fdatasync.o
../../../../../../rtems-4.5.0/c/src/lib/libc/fdatasync.c
o-optimize/pipe.o ../../../../../../rtems-4.5.0/c/src/lib/libc/pipe.c
o-optimize/dup.o ../../../../../../rtems-4.5.0/c/src/lib/libc/dup.c
o-optimize/dup2.o ../../../../../../rtems-4.5.0/c/src/lib/libc/dup2.c
o-optimize/symlink.o
../../../../../../rtems-4.5.0/c/src/lib/libc/symlink.c
o-optimize/readlink.o
../../../../../../rtems-4.5.0/c/src/lib/libc/readlink.c
o-optimize/creat.o ../../../../../../rtems-4.5.0/c/src/lib/libc/creat.c
o-optimize/opendir.o
../../../../../../rtems-4.5.0/c/src/lib/libc/opendir.c
o-optimize/closedir.o
../../../../../../rtems-4.5.0/c/src/lib/libc/closedir.c
o-optimize/readdir.o
../../../../../../rtems-4.5.0/c/src/lib/libc/readdir.c
o-optimize/rewinddir.o
../../../../../../rtems-4.5.0/c/src/lib/libc/rewinddir.c
o-optimize/scandir.o
../../../../../../rtems-4.5.0/c/src/lib/libc/scandir.c
o-optimize/seekdir.o
../../../../../../rtems-4.5.0/c/src/lib/libc/seekdir.c
o-optimize/telldir.o
../../../../../../rtems-4.5.0/c/src/lib/libc/telldir.c
o-optimize/getcwd.o
../../../../../../rtems-4.5.0/c/src/lib/libc/getcwd.c
o-optimize/imfs_chown.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_chown.c
o-optimize/imfs_creat.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_creat.c
o-optimize/imfs_directory.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_directory.c
o-optimize/imfs_eval.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_eval.c
o-optimize/imfs_free.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_free.c
o-optimize/imfs_fsunmount.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_fsunmount.c
o-optimize/imfs_gtkn.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_gtkn.c
o-optimize/imfs_init.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_init.c
o-optimize/imfs_initsupp.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_initsupp.c
o-optimize/imfs_link.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_link.c
o-optimize/imfs_mknod.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_mknod.c
o-optimize/imfs_mount.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_mount.c
o-optimize/imfs_fchmod.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_fchmod.c
o-optimize/imfs_unlink.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_unlink.c
o-optimize/imfs_unmount.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_unmount.c
o-optimize/imfs_utime.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_utime.c
o-optimize/imfs_ntype.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_ntype.c
o-optimize/imfs_stat.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_stat.c
o-optimize/imfs_getchild.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_getchild.c
o-optimize/memfile.o
../../../../../../rtems-4.5.0/c/src/lib/libc/memfile.c
o-optimize/deviceio.o
../../../../../../rtems-4.5.0/c/src/lib/libc/deviceio.c
o-optimize/imfs_handlers_device.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_handlers_device.c
o-optimize/imfs_handlers_directory.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_handlers_directory.c
o-optimize/imfs_handlers_link.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_handlers_link.c
o-optimize/imfs_handlers_memfile.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_handlers_memfile.c
o-optimize/imfs_debug.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_debug.c
o-optimize/imfs_rmnod.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_rmnod.c
o-optimize/imfs_symlink.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_symlink.c
o-optimize/imfs_readlink.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_readlink.c
o-optimize/imfs_fdatasync.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_fdatasync.c
o-optimize/imfs_fcntl.o
../../../../../../rtems-4.5.0/c/src/lib/libc/imfs_fcntl.c
o-optimize/miniimfs_init.o
../../../../../../rtems-4.5.0/c/src/lib/libc/miniimfs_init.c
rm -f o-optimize/libcsupport.a
/opt/rtems/i386-rtems/bin/ar ruv o-optimize/libcsupport.a
o-optimize/gxx_wrappers.o o-optimize/base_fs.o o-optimize/mount.o
o-optimize/unmount.o o-optimize/ioman.o o-optimize/libio.o
o-optimize/libio_sockets.o o-optimize/eval.o
o-optimize/fs_null_handlers.o o-optimize/malloc.o o-optimize/__brk.o
o-optimize/__sbrk.o o-optimize/cfgetispeed.o o-optimize/cfgetospeed.o
o-optimize/cfsetispeed.o o-optimize/cfsetospeed.o o-optimize/tcgetattr.o
o-optimize/tcsetattr.o o-optimize/tcdrain.o o-optimize/tcflow.o
o-optimize/tcflush.o o-optimize/tcgetprgrp.o o-optimize/tcsendbreak.o
o-optimize/tcsetpgrp.o o-optimize/termios.o
o-optimize/termiosinitialize.o o-optimize/termiosreserveresources.o
o-optimize/error.o o-optimize/assoc.o o-optimize/assocnamebad.o
o-optimize/__getpid.o o-optimize/__gettod.o o-optimize/__times.o
o-optimize/truncate.o o-optimize/access.o o-optimize/stat.o
o-optimize/lstat.o o-optimize/pathconf.o o-optimize/newlibc.o
o-optimize/no_posix.o o-optimize/no_libc.o o-optimize/getpwent.o
o-optimize/getgrent.o o-optimize/ctermid.o o-optimize/isatty.o
o-optimize/ttyname.o o-optimize/ttyname_r.o o-optimize/open.o
o-optimize/close.o o-optimize/read.o o-optimize/write.o
o-optimize/lseek.o o-optimize/ioctl.o o-optimize/mkdir.o
o-optimize/mknod.o o-optimize/mkfifo.o o-optimize/rmdir.o
o-optimize/chdir.o o-optimize/chmod.o o-optimize/fchmod.o
o-optimize/chown.o o-optimize/link.o o-optimize/unlink.o
o-optimize/umask.o o-optimize/ftruncate.o o-optimize/utime.o
o-optimize/fstat.o o-optimize/fcntl.o o-optimize/fpathconf.o
o-optimize/getdents.o o-optimize/fsync.o o-optimize/fdatasync.o
o-optimize/pipe.o o-optimize/dup.o o-optimize/dup2.o
o-optimize/symlink.o o-optimize/readlink.o o-optimize/creat.o
o-optimize/opendir.o o-optimize/closedir.o o-optimize/readdir.o
o-optimize/rewinddir.o o-optimize/scandir.o o-optimize/seekdir.o
o-optimize/telldir.o o-optimize/getcwd.o o-optimize/imfs_chown.o
o-optimize/imfs_creat.o o-optimize/imfs_directory.o
o-optimize/imfs_eval.o o-optimize/imfs_free.o
o-optimize/imfs_fsunmount.o o-optimize/imfs_gtkn.o
o-optimize/imfs_init.o o-optimize/imfs_initsupp.o o-optimize/imfs_link.o
o-optimize/imfs_mknod.o o-optimize/imfs_mount.o o-optimize/imfs_fchmod.o
o-optimize/imfs_unlink.o o-optimize/imfs_unmount.o
o-optimize/imfs_utime.o o-optimize/imfs_ntype.o o-optimize/imfs_stat.o
o-optimize/imfs_getchild.o o-optimize/memfile.o o-optimize/deviceio.o
o-optimize/imfs_handlers_device.o o-optimize/imfs_handlers_directory.o
o-optimize/imfs_handlers_link.o o-optimize/imfs_handlers_memfile.o
o-optimize/imfs_debug.o o-optimize/imfs_rmnod.o
o-optimize/imfs_symlink.o o-optimize/imfs_readlink.o
o-optimize/imfs_fdatasync.o o-optimize/imfs_fcntl.o
a - o-optimize/gxx_wrappers.o
a - o-optimize/base_fs.o
a - o-optimize/mount.o
a - o-optimize/unmount.o
a - o-optimize/ioman.o
a - o-optimize/libio.o
a - o-optimize/libio_sockets.o
a - o-optimize/eval.o
a - o-optimize/fs_null_handlers.o
a - o-optimize/malloc.o
a - o-optimize/__brk.o
a - o-optimize/__sbrk.o
a - o-optimize/cfgetispeed.o
a - o-optimize/cfgetospeed.o
a - o-optimize/cfsetispeed.o
a - o-optimize/cfsetospeed.o
a - o-optimize/tcgetattr.o
a - o-optimize/tcsetattr.o
a - o-optimize/tcdrain.o
a - o-optimize/tcflow.o
a - o-optimize/tcflush.o
a - o-optimize/tcgetprgrp.o
a - o-optimize/tcsendbreak.o
a - o-optimize/tcsetpgrp.o
a - o-optimize/termios.o
a - o-optimize/termiosinitialize.o
a - o-optimize/termiosreserveresources.o
a - o-optimize/error.o
a - o-optimize/assoc.o
a - o-optimize/assocnamebad.o
a - o-optimize/__getpid.o
a - o-optimize/__gettod.o
a - o-optimize/__times.o
a - o-optimize/truncate.o
a - o-optimize/access.o
a - o-optimize/stat.o
a - o-optimize/lstat.o
a - o-optimize/pathconf.o
a - o-optimize/newlibc.o
a - o-optimize/no_posix.o
a - o-optimize/no_libc.o
a - o-optimize/getpwent.o
a - o-optimize/getgrent.o
a - o-optimize/ctermid.o
a - o-optimize/isatty.o
a - o-optimize/ttyname.o
a - o-optimize/ttyname_r.o
a - o-optimize/open.o
a - o-optimize/close.o
a - o-optimize/read.o
a - o-optimize/write.o
a - o-optimize/lseek.o
a - o-optimize/ioctl.o
a - o-optimize/mkdir.o
a - o-optimize/mknod.o
a - o-optimize/mkfifo.o
a - o-optimize/rmdir.o
a - o-optimize/chdir.o
a - o-optimize/chmod.o
a - o-optimize/fchmod.o
a - o-optimize/chown.o
a - o-optimize/link.o
a - o-optimize/unlink.o
a - o-optimize/umask.o
a - o-optimize/ftruncate.o
a - o-optimize/utime.o
a - o-optimize/fstat.o
a - o-optimize/fcntl.o
a - o-optimize/fpathconf.o
a - o-optimize/getdents.o
a - o-optimize/fsync.o
a - o-optimize/fdatasync.o
a - o-optimize/pipe.o
a - o-optimize/dup.o
a - o-optimize/dup2.o
a - o-optimize/symlink.o
a - o-optimize/readlink.o
a - o-optimize/creat.o
a - o-optimize/opendir.o
a - o-optimize/closedir.o
a - o-optimize/readdir.o
a - o-optimize/rewinddir.o
a - o-optimize/scandir.o
a - o-optimize/seekdir.o
a - o-optimize/telldir.o
a - o-optimize/getcwd.o
a - o-optimize/imfs_chown.o
a - o-optimize/imfs_creat.o
a - o-optimize/imfs_directory.o
a - o-optimize/imfs_eval.o
a - o-optimize/imfs_free.o
a - o-optimize/imfs_fsunmount.o
a - o-optimize/imfs_gtkn.o
a - o-optimize/imfs_init.o
a - o-optimize/imfs_initsupp.o
a - o-optimize/imfs_link.o
a - o-optimize/imfs_mknod.o
a - o-optimize/imfs_mount.o
a - o-optimize/imfs_fchmod.o
a - o-optimize/imfs_unlink.o
a - o-optimize/imfs_unmount.o
a - o-optimize/imfs_utime.o
a - o-optimize/imfs_ntype.o
a - o-optimize/imfs_stat.o
a - o-optimize/imfs_getchild.o
a - o-optimize/memfile.o
a - o-optimize/deviceio.o
a - o-optimize/imfs_handlers_device.o
a - o-optimize/imfs_handlers_directory.o
a - o-optimize/imfs_handlers_link.o
a - o-optimize/imfs_handlers_memfile.o
a - o-optimize/imfs_debug.o
a - o-optimize/imfs_rmnod.o
a - o-optimize/imfs_symlink.o
a - o-optimize/imfs_readlink.o
a - o-optimize/imfs_fdatasync.o
a - o-optimize/imfs_fcntl.o
a - o-optimize/miniimfs_init.o
/opt/rtems/i386-rtems/bin/ranlib o-optimize/libcsupport.a
/usr/bin/install -c -m 644 o-optimize/libcsupport.a
../../../../../pc686/lib/libcsupport.a
Making all in libcpu
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libcpu'
Making all in i386
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libcpu/i386'
mkdir o-optimize
/opt/rtems/bin//i386-cc --pipe -B../../../../../.././pc686/lib/ -specs
o-optimize/cpu.o
../../../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/cpu.c
o-optimize/displayCpu.o
../../../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/displayCpu.c
o-optimize/page.o
../../../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/page.c
bsp_specs -qrtems     -mcpu=i686     -c  -DASM -o o-optimize/cpu_asm.o
../../../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/cpu_asm.S
bsp_specs -qrtems     -mcpu=i686     -c  -DASM -o o-optimize/cpuModel.o
../../../../../../../rtems-4.5.0/c/src/lib/libcpu/i386/cpuModel.S
rm -f o-optimize/libcpu.a
/opt/rtems/i386-rtems/bin/ar ruv o-optimize/libcpu.a o-optimize/cpu.o
o-optimize/displayCpu.o o-optimize/page.o o-optimize/cpu_asm.o
a - o-optimize/cpu.o
a - o-optimize/displayCpu.o
a - o-optimize/page.o
a - o-optimize/cpu_asm.o
a - o-optimize/cpuModel.o
/opt/rtems/i386-rtems/bin/ranlib o-optimize/libcpu.a
/usr/bin/install -c -m 644 o-optimize/libcpu.a
../../../../../.././pc686/lib/libcpu.a
Making all in libbsp
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp'
Making all in shmdr
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/shmdr'
Making all in i386
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386'
Making all in shared
make[6]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/shared'
Making all in irq
make[7]: Entering directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/shared/irq'
make[7]: Nothing to be done for `all'.
make[7]: Leaving directory
Making all in io
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/shared/io'
Making all in comm
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/shared/comm'
Making all in pci
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/shared/pci'
make[7]: Nothing to be done for `all-am'.
make[6]: Leaving directory
Making all in pc386
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386'
Making all in .
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/include'
Making all in tools
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/tools'
Making all in start
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686/lib/libbsp/i386/pc386/start'
mkdir o-optimize
/opt/rtems/bin//i386-cc --pipe -B../../../../../../../../pc686/lib/
-specs bsp_specs -qrtems     -mcpu=i686     -c -DNEW_GAS
-DHEADERADDR=0x00097E00 -o o-optimize/start16.o
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/start/start16.S
-specs bsp_specs -qrtems     -mcpu=i686     -c -DNEW_GAS -DASM -o
o-optimize/start.o
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/start/start.S
/opt/rtems/i386-rtems/bin/ld -N -T
../../../../../../../../../rtems-4.5.0/c/src/lib/libbsp/i386/pc386/startup/linkcmds
-Ttext 0x00097C00 -e start16 -nostdlib   --oformat=elf32-i386 -o
o-optimize/start16.obj o-optimize/start16.o
no -O binary o-optimize/start16.obj o-optimize/start16.bin
make[2]: Leaving directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c/pc686'
make[1]: Leaving directory
`/home/pdtroyer/RTEMS/tools/build-rtems/i386/c'
