Posix test suite
Stephan Merker merker at decrc.abb.de
Mon Nov 13 15:08:27 UTC 2000
Can anybody give me a hint how to get the POSIX test suite configured.
I'm using the following configure options:
../rtems-ss-20001103/configure --enable-posix --enable-networking --enable-c
xx --disable-itron --enable-rtemsbsp= --enable-tests --prefix=/usr/local/rte
ms
So, both posix and tests are enabled, but the posix tests are not copied
into the build directory (neither under Cygwin nor under Linux).
Stephan
