virus attached was Re: 4.5.0-beta3a build problems
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Nov 14 13:39:35 UTC 2000
The navidad.exe virus is attached to this email. This
is a Win32/MAPI virus. More information on this is at:
http://vil.mcafee.com/dispVirus.asp?virus_k=98881&
Please react accordingly.
--joel
chao wrote:
> Martti Kuparinen wrote:
> > Hi!
> > I'm running FreeBSD 4.1-STABLE with the following packages installed:
> > i386-rtems-binutils-2.9.5.0.24
> > i386-rtems-gcc-2.95.2
> > i386-rtems-gdb-4.18
> > The cross-compilation tools are located in /usr/local/bin/ and they are:
> First, I am glad to see you are using them. Second, I use the m68k
> tools all the time to do the building without problems. I haven't tried
> the i386 tools to build RTEMS since I verified it would compile the unix
> target for FBSD 4.0-STABLE.
> I am just verfying the last the new versions of the tools just
> commited. While that is doing I will try doing it "your" way and see if
> I get the same results.
> Jim
> Artificial intelligence is no match for natural stupidity.
> Navidad.exe Type: unspecified type (application/octet-stream)
> Encoding: base64
> Download Status: Not downloaded with message
joel at OARcorp.com On-Line Applications Research
