tick timing
mcollins at hawkeye.sps.mot.com
Wed Nov 8 23:23:33 UTC 2000
Joel wrote:
> You don't have to circumvent the macros if this is simply an application
> configuration. Set the CONFIGURATION_MICROSECONDS_PER_TICK to whatever
> you want. The problem is the construction of the clock tick driver.
> THe powerpc decrementer based clock tick driver does it better. See
> c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c and notice that it
> takes a BSP supplied value for an arbitrary clock tick. Basically
> you just have to program the tick source based on the value configured.
This is the info I needed. I changed the tick driver to do nothing
more than increment Clock_driver_ticks and call rtems_clock_tick(),
and now things work as expected.
I'm currently experimenting with an algorithm which should improve
the average accuracy of the time-of-day functions despite the wierd
tick rate offered by the 68331 with a 32.768kHz oscillator. If my
concept proves to be sound, I'll post an update.
Thanks for the help.
-- MC --
mcollins at wdc.sps.mot.com
