FS: problems and patches
OUTWATER ~ KEITH J /5G3110
vac4050 at cae597.rsc.raytheon.com
Thu Nov 30 19:36:30 UTC 2000
Dmitry -
You mentioned a JFFS port to RTEMS. Can you provide any details?
1. How are you interfacing to the flash memory hardware? MTD?
2. Will you be releasing the port?
3. If (#2), when do you expect to be completed?
Keith
Keith Outwater
Principal Engineer
Raytheon Missile Systems
Tucson, AZ
(520) 794-2518
> Hello All.
> I have solved the problem with path evaluation of the
> directory entry that is mounting point for other
> file system. This problem was discussed in previous
> messages by Sergei Organov and rtems society.
> Look at the patch imfs_eval.c.diff.
> It works properly in my tasks. (For testing my
> own FS mounted to IMFS directory I use ported
> from Midnight Commander mcserver).
> Also it seems to me that when open a directory,
> search permissions must be tested.
> that's why I offer to consider the patchs open.c.diff
> and opendir.c.diff.
> (the idea of using flag _O_DIRECTORY come from the linux)
> Important Note: I use rtems-ss-20000802.
> (the reason was: GoAhead web-server in latest
> snapshots has a few bad surprises - it works
> slowly, and cuts off eigth bit. May be I have
> to do some tuning - I don't know yet...)
> There is another problem in RTEMS filesystem.
> There is not rename() implementation. So libc does it via
> two FS calls: link() and unlink().
> It is bad for two reasons. Firstly not all filesystems
> have hard links, for example JFFS at the moment.
> (I'm porting JFFS to RTEMS now).
> Secondly, rename() is not monolithic. What will happen
> when system will crash right after link()?
> JFFS is filesystem with one-step implementation
> of all fs operations. And rename() too.
> I think it would be useful to add "rename"
> to the list of the filesystem's operations
> (type rtems_filesystem_operations_table in libio.h)
> and to remake newlib with new rename() function
> (see newlib configure flag -DHAVE_RENAME)
> the type of new operations table element may
> be like this:
> typedef int (*rtems_filesystem_rename_t)(
> rtems_filesystem_location_info_t *old_file, /* IN */
> rtems_filesystem_location_info_t *new_dir, /* IN */
> const char *new_name /* IN */
> attached file rename_example.c contains my version
> of the possible future rename() implementation
> sincerely,
> Dmitry Kargapolov void at dr.com
