$(RTEMS_ROOT)/make/target.cfg
Aaron J. Grier
aaron at frye.com
Wed Oct 4 18:34:30 UTC 2000
running rtems-4.5.0beta3a.
is there any compelling reason why $(RTEMS_ROOT)/make/target.cfg (and
all references to it) couldn't or shouldn't be moved to
$(RTEMS_ROOT)/$(RTEMS_BSP_FAMILY)/make/target.cfg ?
the $(RTEMS_ROOT)/make/README states that
Switching between RTEMS BSPs is accomplished via setting
the environment variable "RTEMS_MAKEFILE_PATH."
unfortunately the various BSPs clobber $(RTEMS_ROOT)/make/target.cfg on
a make install, so the above statement only holds when all BSPs used
share the same target.cfg.
any thoughts?
Aaron J. Grier | Frye Electronics, Tigard, OR | aaron at frye.com
"Add [Windows] ME to an old PC with a `mere' 32 MB of memory, and your
hard disk will be busier than a one-armed man juggling knives."
-- Winn L. Rosch
