$(RTEMS_ROOT)/make/target.cfg
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Wed Oct 4 20:16:02 UTC 2000
"Aaron J. Grier" wrote:
> running rtems-4.5.0beta3a.
> is there any compelling reason why $(RTEMS_ROOT)/make/target.cfg (and
> all references to it) couldn't or shouldn't be moved to
> $(RTEMS_ROOT)/$(RTEMS_BSP_FAMILY)/make/target.cfg ?
Yes. target.cfg is supposed to take make variables to be shared
between all Makefiles of a target and not to contain any setting
valid only for an individual bsp.
> the $(RTEMS_ROOT)/make/README states that
> Switching between RTEMS BSPs is accomplished via setting
> the environment variable "RTEMS_MAKEFILE_PATH."
> unfortunately the various BSPs clobber $(RTEMS_ROOT)/make/target.cfg on
> a make install, so the above statement only holds when all BSPs used
> share the same target.cfg.
Yes, this is a known issue, I am working on cleaning this up.
> any thoughts?
The docs deserve a little brush up :)
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
(FAW)
Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de FAX: +49/731/501-999
http://www.faw.uni-ulm.de
