Interrupt catch
Alejandro Villanueva
190921 at cepsz.unizar.es
Wed Oct 18 12:30:32 UTC 2000
Joel Sherrill wrote:
> Alejandro Villanueva wrote:
> > Hello,
> > I'm trying to catch IRQ7 in the pc386 BSP both under C and under Ada.
> > Could anyone tell me how to catch it, please?
> Everyone has given you the C answer without providing the
> "Ada" answer. If you are using Ada interrupts in the
> Ada language sense, then you still have to have a real
> hardware interrupt handler. Then it is propagated with
> POSIX signals to the Ada run-time to be presented to the
> Ada application as an Ada interrupt.
> The only function version of this included in the source
> tree is for the sparc/erc32. See gnatsupp.c. It provides
> a real body for __gnat_install_handler().
Joel, I'm working on a i386, so the only hardware interrupt handler is the
PIC, so this is my new question: Will it be easier to implement the
interrupt handler in C using irq.h and then importing the handler into Ada
via pragma Import or to implement it directly in Ada not knowing how to do
it?
Thanks,
Alejandro.
> > Thanks,
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
¿Quieres Cobrar por Navegar en Internet?
Visita: http://www.navegana.com/dinero/flintstone.html
URL: <http://lists.rtems.org/pipermail/users/attachments/20001018/146c2c8e/attachment.html>
