68302 IMR init
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Oct 18 18:23:16 UTC 2000
Was there ever any feedback on this? I am curious if it is needed
or not.
--joel
Antti P Miettinen wrote:
> Is there a reason for the clock driver just setting IMR, not ORing the
> TIMER1 bit into IMR? I'm trying to make ^C work for the debugger stub
> so I have to enable interrupts for a SCC but the clock driver as it is
> now masks the SCC interrupt.
> --- c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c~ Tue Jan 11 19:34:20 2000
> +++ c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c Mon Aug 7 23:52:17 2000
> @@ -93,7 +93,7 @@
> * Enable TIMER1 interrupts only.
> - m302.reg.imr = RBIT_IMR_TIMER1; /* set 68302 int-mask to allow ints */
> + m302.reg.imr |= RBIT_IMR_TIMER1; /* set 68302 int-mask to allow ints */
> atexit( Clock_exit );
> --- c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c~ Tue Jan 11 19:34:20 2000
> +++ c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c Mon Aug 7 23:54:08 2000
> @@ -94,7 +94,7 @@
joel at OARcorp.com On-Line Applications Research
