68302 IMR init
russ
russ at embedit.com.au
Thu Oct 19 00:44:55 UTC 2000
I had the same problem. I also OR the bit.
It would probably be better that way. Only when this is the first
interrupt configured is it not a problem.
Joel Sherrill wrote:
> Was there ever any feedback on this? I am curious if it is needed
> or not.
> --joel
> Antti P Miettinen wrote:
> > Is there a reason for the clock driver just setting IMR, not ORing the
> > TIMER1 bit into IMR? I'm trying to make ^C work for the debugger stub
> > so I have to enable interrupts for a SCC but the clock driver as it is
> > now masks the SCC interrupt.
> > --- c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c~ Tue Jan 11 19:34:20 2000
> > +++ c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c Mon Aug 7 23:52:17 2000
> > @@ -93,7 +93,7 @@
> > * Enable TIMER1 interrupts only.
> > - m302.reg.imr = RBIT_IMR_TIMER1; /* set 68302 int-mask to allow ints */
> > + m302.reg.imr |= RBIT_IMR_TIMER1; /* set 68302 int-mask to allow ints */
> > atexit( Clock_exit );
> > --- c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c~ Tue Jan 11 19:34:20 2000
> > +++ c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c Mon Aug 7 23:54:08 2000
> > @@ -94,7 +94,7 @@
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
