Remote debugging
Tue Oct 24 12:53:15 UTC 2000
The prebuilt binaries don't have the remote debugging
enabled -- you have to build from source with the
target powerpc-RTEMS (capital).
Hmmm... this is reaching the point where it needs to
be part of the started configuration and we just fight the
autoconf problems as needed.
Emmanuel Raguet wrote:
> Gregory.D.Menke.1 at gsfc.nasa.gov wrote:
> > I've been having a bit of trouble getting ethernet remote debugging
> > rolling on our MCP750 target.  We have the prebuilt powerpc-rtems tool
> > suite installed, --enable-rdbg set on the RTEMS configure, a binary
> > built & operating on the target with an operational network interface
> > running the RTEMS ftp daemon.
> > The setrpcmode and associated commands are not recognized by the
> > powerpc-rtems-gdb.  When compiling it from source, the .c files
> > implementing the remote debug commands do not appear to be compiled
> > in.  Our host OS is Linux.
> > Also, a portscan of the target binary does not show any tcp/udp ports
> > open at all (beyond the ftp daemon..)
> > I've gone thru the RTEMS gdb docs, having followed all the steps- am I
> > missing something?
> Do you have added the call to rtems_rdbg_initialize() in your Init task
> It is mandatory to enable debugger.
> Hope this helps...
> Emmanuel
>        |        Emmanuel RAGUET          |
>      _ | CANON CRF - Communication Dept. | _
>     / )|    Tel: +33(0)2 99 87 96 47     |( \
>    / / |    Fax: +33(0)2 99 84 11 30     | \ \
>  _( (_ |  _  http://www.crf.canon.fr  _  | _) )_
> (((\ \>|_/ )_________________________( \_|</ /)))
> (\\\\ \_/ /                           \ \_/ ////)
>   \    _/                               \_    /
