prooblem building rtems-ss-20000929
OUTWATER vac4050 at cae597.rsc.raytheon.com
Thu Oct 26 15:06:38 UTC 2000
Greetings all -
I'm trying to build rtems-ss-20000929 on HP-UX 10.2 and the build is failing here:
gmake[3]: Leaving directory
`/local/users/vac4050/projects/rtems/tools/build-m68k-rtems/m68k-rtems/c/gen68360/librtems
Making all in wrapup
/users/cae597/vac4050/projects/rtems/tools/build-m68k-rtems/m68k-rtems/c/gen68360/wrapup
gmake[3]: Entering directory
`/local/users/vac4050/projects/rtems/tools/build-m68k-rtems/m68k-rtems/c/gen68360/wrapup'
rm -f ../../../../gen68360/lib/librtemsall.a
rm -rf o-optimize/*
/bin/sh: /users/cae597/vac4050/usr/local/bin/rm: The parameter list is too long.
gmake[3]: *** [../../../../gen68360/lib/librtemsall.a] Error 126
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory
`/local/users/vac4050/projects/rtems/tools/build-m68k-rtems/m68k-rtems/c/gen68360'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
`/local/users/vac4050/projects/rtems/tools/build-m68k-rtems/m68k-rtems/c'
make: *** [all-recursive] Error 1
I hacked things to get past this only to have the build fail later on a chmod command.
BTW, I'm using rm and chmod from fileutils-4.0.  I also tries the build using bash.
Has anyone else seen this problem?
Thanks!
Keith
