Starting with a SH1 7032
fernando.ruiz at ctv.es fernando.ruiz at ctv.es
Sun Oct 29 23:12:58 UTC 2000
I am starting with RTEMS and a sh7032 BSP
Hitachi 7032 (512K ROM,512 KB Flash,512K Ram,2k E2Prom, 20 Mhz)
I have a little O.S. multiuser (Not multitask)
that I have used like loader of the samples for a gensh1 BSP
All the test run ok.
(The serial input polled very bad but
with intr's I think to resolve it)
I have flash memory, e2prom memory, rtc & more...
I need a NEW BSP BOARD.
I have copied gensh1 bsp directory into a new VIS211 directory.
I have runned ./bit_rtems sh vis211 (After setup all files)
I have got a /usr/local/rtems/vis211 BSP (Copy of gensh1)
All runs ok.
BUT...
I have copied STUBDRV like point of start for add a new driver LCD (dummy)
into ../lib/libbsp/sh/vis211/stubdrv
after I have rename to lcd for a LCD driver.
Inside the files of stubdrv all has been renamed to Lcd_open,Lcd_close,...
The Makefile.am & Makefile.in of
../libbsp/sh/vis211
../libbsp/sh/vis211/lcd
../libbsp/sh/vis211/wrapup
have been touched adding a new driver (directory & sources)
The problem is:
After build a new ./bit_rtems sh vis211 (with a new LCD driver dummy)
the process crash (missing lcd directory)
Is it possible known the recipe for a new driver(DUMMY) to add a my bsp?
Where is it necessary to touch to setup a new driver?
Sorry, but my english is not so good.
I am Spanish and I speak spanish but not english.
Thanks
Vielen dank Ralph Corsepius. Ein sehr gut Arbeit.
Ich arbeit auch mit SH1.
