more cache manager issues
Till Straumann strauman at SLAC.Stanford.EDU
Tue Oct 31 00:43:28 UTC 2000
Browsing through the cache manager implementation of
`rtems-ss-20000929' caused me having some more questions
/ suggestions:
 - cache_aligned_malloc() (currently not called by any piece of code)
must not
     be used. Calling `free' on memory allocated by
cache_aligned_malloc() results
     in heap corruption.
All the other issues apply to the POWERPC architecture:
 - rtems_cache_flush_multiple_data_lines() etc: after repeatedly
     flushing/invalidating single cache lines (`dcbst', `dcbi', `dcbf')
     a `SYNC' instruction _must_ be issued to guarantee that the
operations
     have completed before returning from the
rtems_cache_xxx_multiple_data_lines()
     etc. routines. (To enhance performance, the CPU dependent single
line operations
     should probably be inlined).
 - At least the MPC8xx implementation (didn't look too close at the
other powerpc cpus)
     of _CPU_cache_enable_data() etc. is incorrect. Note that
enabling/disabling the cache
     does not invalidate / flush the cache (consult the MPC-860 user
manual).
     The correct way to enable the data cache is as follows:
        1)  invalidate the complete data cache
        2)  `sync' to make sure the operation has completed
        3) enable the data cache
     Disabling the data cache should consist of the following steps
       1) flush (write back and invalidate) the entire data cache
       2) `sync'
       3) disable the data cache
      Well, there's no clue whether steps 2) are really necessary.
Theoretically,
      the cache could perform the posted write backs after it has been
disabled.
      However, I feel that it is safer doing the `sync'. Note that
1) are definitively
       required. (On the other hand, I can't really see the benefits of
the currently
       used `isync' as step 4.)
Comments?
-- Till.
