more cache manager issues
Charles-Antoine Gauthier
charles.gauthier at nrc.ca
Tue Oct 31 14:17:33 UTC 2000
Till Straumann wrote:
> Browsing through the cache manager implementation of
> `rtems-ss-20000929' caused me having some more questions
> / suggestions:
> - cache_aligned_malloc() (currently not called by any piece of code)
> must not
> be used. Calling `free' on memory allocated by
> cache_aligned_malloc() results
> in heap corruption.
> All the other issues apply to the POWERPC architecture:
> - rtems_cache_flush_multiple_data_lines() etc: after repeatedly
> flushing/invalidating single cache lines (`dcbst', `dcbi', `dcbf')
> a `SYNC' instruction _must_ be issued to guarantee that the
> operations
> have completed before returning from the
> rtems_cache_xxx_multiple_data_lines()
> etc. routines. (To enhance performance, the CPU dependent single
> line operations
> should probably be inlined).
> - At least the MPC8xx implementation (didn't look too close at the
> other powerpc cpus)
> of _CPU_cache_enable_data() etc. is incorrect. Note that
> enabling/disabling the cache
> does not invalidate / flush the cache (consult the MPC-860 user
> manual).
> The correct way to enable the data cache is as follows:
> 1) invalidate the complete data cache
> 2) `sync' to make sure the operation has completed
> 3) enable the data cache
> Disabling the data cache should consist of the following steps
> 1) flush (write back and invalidate) the entire data cache
> 2) `sync'
> 3) disable the data cache
> Well, there's no clue whether steps 2) are really necessary.
> Theoretically,
> the cache could perform the posted write backs after it has been
> disabled.
> However, I feel that it is safer doing the `sync'. Note that
> 1) are definitively
> required. (On the other hand, I can't really see the benefits of
> the currently
> used `isync' as step 4.)
> Comments?
> -- Till.
We might want to consider changing the heap manager to return blocks
that are already cache line aligned. The cache_aligned_malloc() was the
result of realizing the need for this feature. However, as Eric pointed
out, it was never used so it was never thought through carefully.
I would however point out that doing this only makes sense when the
cache lines are small. Otherwise, there can be a lot of wasted space.
For large cache lines (machines with second level caches), we should
consider allocating DMA buffers out of non-cachable memory. This now
requires a VM manager and the ability to place heaps in various regions.
Not much of a problem, I think. Ah, if only hardware designers knew
something about software...
WRT sync, if memory if marked as coherent (haven't looked at my 860
manual, so I don't know if this applies to that processor), then an
eieio might be better?
Synchronization should be required whether 1 or multiple lines are
flushed. The synchronization only needs to be done once. Consequently,
the multiple line version of a function should not call the single line
version.
I thought the single line functions were inline. If they are not, they
should be.
Institute for Information Technology Institut de technologie de
l'information
National Research Council of Canada Conseil national de recherches du
Canada
