Errors building GCC for m68k in Beta3a
DeanNelson at aol.com
Tue Oct 31 12:32:21 UTC 2000
Hello,
I'm using CYGWIN and following the directions in the "Getting Started with
RTEMS for C/C++ Users" manual. I have all of the components listed and when I
run the "bit" script to build the tools binutils builds correctly, but gcc
errors out in the "elfos.h" file. I have looked at it and it looks all right.
I have POSIX, ITron, and MP turned off. I have tried these but to no avail:
./bit m68k
./bit m68k-coff
./bit m68k-elf
What am I doing wrong? Any help you can offer would be appreciated!
Thanks,
Dean Nelson
--------------------------------ERRORS
FOLLOW---------------------------------------------------------
Building a cross GNU C/C++ toolset with the following configuration:
BINUTILS --> binutils-2.9.5.0.24
GCC --> gcc-2.95.2
NEWLIB --> newlib-1.8.2
TARGET --> m68k-rtems
INSTALL POINT --> /opt/rtems
BUILD DOCS --> no
make[2]: Leaving directory `/gcctools/tools/build-m68k-tools/texinfo'
make[1]: Leaving directory `/gcctools/tools/build-m68k-tools/texinfo'
make[1]: Entering directory `/gcctools/tools/build-m68k-tools/etc'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/gcctools/tools/build-m68k-tools/etc'
make[1]: Entering directory `/gcctools/tools/build-m68k-tools/gcc'
gcc -DCROSS_COMPILE -DIN_GCC -O2 -g -DHAVE_CONFIG_H -I.
-I../../gcc-2.95.2/gcc -I../../gcc-2.95.2/gcc/config
-I../../gcc-2.95.2/gcc/../include \
-DGCC_INCLUDE_DIR=\"/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/include\" \
-DGPLUSPLUS_INCLUDE_DIR=\"/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../..
`echo /opt/rtems | sed -e 's|^/opt/rtems||' -e
's|/[^/]*|/..|g'`/include/g++-3\" \
-DLOCAL_INCLUDE_DIR=\"/opt/rtems/include\" \
-DCROSS_INCLUDE_DIR=\"/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../m68
k-rtems/sys-include\" \
-DTOOL_INCLUDE_DIR=\"/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../m68k
-rtems/include\" \
-c `echo ../../gcc-2.95.2/gcc/cccp.c | sed 's,^\./,,'`
In file included from ../../gcc-2.95.2/gcc/config/m68k/m68020-elf.h:26,
from ../../gcc-2.95.2/gcc/config/m68k/rtemself.h:25,
from tm.h:5,
from ../../gcc-2.95.2/gcc/config/i386/xm-i386.h:43,
from config.h:8,
from ../../gcc-2.95.2/gcc/cccp.c:21:
../../gcc-2.95.2/gcc/config/elfos.h:43: parse error before `do'
../../gcc-2.95.2/gcc/config/elfos.h:43: stray '\' in program
../../gcc-2.95.2/gcc/config/elfos.h:44: stray '\' in program
../../gcc-2.95.2/gcc/config/elfos.h:45: stray '\' in program
../../gcc-2.95.2/gcc/config/elfos.h:46: stray '\' in program
from tm.h:5,
from config.h:8,
../../gcc-2.95.2/gcc/config/elfos.h:108: parse error before `('
../../gcc-2.95.2/gcc/config/elfos.h:108: parse error before `)'
../../gcc-2.95.2/gcc/config/elfos.h:136: stray '\' in program
../../gcc-2.95.2/gcc/config/elfos.h:137: stray '\' in program
../../gcc-2.95.2/gcc/config/elfos.h:150: stray '\' in program
../../gcc-2.95.2/gcc/cccp.c:9548: parse error before `__builtin_next_arg'
../../gcc-2.95.2/gcc/cccp.c: In function `pedwarn_with_file_and_line':
../../gcc-2.95.2/gcc/cccp.c:9575: `va_list' undeclared (first use in this
function)
../../gcc-2.95.2/gcc/cccp.c:9575: parse error before `args'
../../gcc-2.95.2/gcc/cccp.c:9580: `args' undeclared (first use in this
function)
../../gcc-2.95.2/gcc/cccp.c:9580: `__gnuc_va_list' undeclared (first use in
this function)
../../gcc-2.95.2/gcc/cccp.c:9580: parse error before `__builtin_next_arg'
../../gcc-2.95.2/gcc/cccp.c: In function `fatal':
../../gcc-2.95.2/gcc/cccp.c:10614: `va_list' undeclared (first use in this
function)
../../gcc-2.95.2/gcc/cccp.c:10614: parse error before `args'
../../gcc-2.95.2/gcc/cccp.c:10617: `args' undeclared (first use in this
function)
../../gcc-2.95.2/gcc/cccp.c:10617: `__gnuc_va_list' undeclared (first use in
this function)
../../gcc-2.95.2/gcc/cccp.c:10617: parse error before `__builtin_next_arg'
make[1]: *** [cccp.o] Error 1
make[1]: Leaving directory `/gcctools/tools/build-m68k-tools/gcc'
make: *** [all-gcc] Error 2
ERROR: **** FAILED **** base build (step 1)
Started: Mon Oct 30 23:26:46 2000
Finished: Mon Oct 30 23:44:25 2000
Directory size information:
2285 build-m68k-tools
95606 /opt/rtems
The src and build-m68k-tools subdirectory have NOT been removed.
