no-io
Nick.SIMON at syntegra.bt.co.uk
Tue Oct 31 08:58:02 UTC 2000
You need to specify io (and any other managers you need) in your app
Makefile. If you have several makefiles in a tree, it's the one that does
the link. Mine contains:
MANAGERS=io event semaphore timer
Best Wishes,
-- Nick Simon
> -----Original Message-----
> From: russ [mailto:russ at embedit.com.au]
> Sent: 31 October 2000 08:47
> To: rtems
> Subject: no-io
> Hi,
> Does anybody know why my app would be linking in the no-io library? Is
> there a flag which needs to be set/unset?
> I suspect this is why my device driver initialisations are not being
> called and the app crashes at the first task switch.
> This is using 4.5 beta3a.
> Thanks
> russ
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they
are addressed. If you have received this email in error please notify
the system manager.
This footnote also confirms that this email message has been swept by
MIMEsweeper for the presence of computer viruses.
www.mimesweeper.com
