rpm doesn't like my OS
Alfredo Macias
jamacias at quintron.com
Mon Oct 2 15:33:06 UTC 2000
Hi Joel.
> Did this work? Another (hack) alternative is to do something
Yes, It did. Thank you very much for your hint.
Alfredo
> like this:
> cd /
> rpm2cpio XXX.rpm | cpio -idvum
> This ignores EVERYTHING since it just extracts the files and
> puts them in place. This is not equivalent to installing an
> RPM and the RPM database is not updated to reflect this.
> So you remove them with a simple "rm -rf /opt/rtems.
> Jay Kulpinski wrote:
> > jamacias wrote:
> > > Hi.
> > > I am trying to install the rpm packages like:
> > > rpm -i rtems-base-binutils-2.9.5.0.24-1.i386.rpm
> > > but I get a message:
> > > package rtems-base-binutils-2.9.5.0.24-1.i386.rpm is for
> a different
> > > operating system.
> > > I'm running Gentus Linux (I guess similar to RedHat) on
> a celeron
> > > machine, I was under the impression that these rpm
> packages would work
> > > with any flavor of Linux. Is this correct?.
> > > Any help will be much appreciated.
> > > Alfredo
> > Try this:
> > rpm -i --ignoreos rtems-base-binutils-2.9.5.0.24-1.i386.rpm
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
