PowerPC FP handling weakness.
Duncan Smith dds at flavors.com
Wed Oct 11 08:40:42 UTC 2000
At 2:31 PM +0400 10/2/00, Sergei Organov wrote:
>Eric Valette <valette at crf.canon.fr> writes:
> > > Yes. RTEMS doesn't have "on-demand" FP context switch. Only "deferred" context
>> > switch. I.e. switch context only when new task is marked to be "floating
>> > point" and doesn't already own the FP context.
>> Yes but on-demand FP context switch is rather easy to implement since we
>> now can handle the FP unavail exception. We just need to know to wich
>> thread the current FP context belong and store/restore it.
>Your are right, but on-demand switch has its own drawbacks. One unfortunate
>thing is that FP bit and interrupt enable bit are in the same MSR on PowerPC,
>and this brings troubles with _ISR_Disable/Enable when on-demand FP context
>switch is used (see my previous mail for details).
>BR,
>Sergei Organov.
Here is "on-demand" FP context switch for OUR environment.  You can adapt it as you see fit.  It is Copyright Flavors so be sure to hack it up real good so it looks different.
N.B.:
1) I have ripped out some proprietary stuff of no general interest.  The holes are marked:
<<<<<<<<<<<<<<<<<<< STUFF REMOVED >>>>>>>>>>>>>>>>>>>>>>>
Because of this there may be dangling pointers/ missing labels.
2) The comments and header are way out of date.
3) I think the only thing left (c) OAR is the copyright notice itself.
4) MPW hasn't been used for years to compile this.  CodeWarrior builtin ASM is used.
5) I have removed a few bogus comments, but many probably remain...
6) Many old fragments of code remain, commented out...  Some are really out of context, so it is best to ignore them.
Here is h.s:
#  rtems/cpu_asm.i
#  Equates etc.
#  Copyright (c) 1995 Flavors Technology, Inc.
# 1995/08/22 dds Created. Names from linux.
# SPRs
DMISS		equ		976
DCMP		equ		977
HASH1		equ		978
HASH2		equ		979
IMISS		equ		980
ICMP		equ		981
RPA			equ		982
#/* Bit encodings for Machine State Register (MSR) */
MSRS_POW	equ     (1<<2)		#/* Enable Power Management */
MSRS_TGPR	equ     (1<<1)		#/* TLB Update registers in use */
MSRS_ILE	equ     (1<<0)		#/* Interrupt Little-Endian enable */
MSR_POW		equ     (1<<18)		#/* Enable Power Management */
MSR_TGPR	equ     (1<<17)		#/* TLB Update registers in use */
MSR_ILE		equ     (1<<16)		#/* Interrupt Little-Endian enable */
MSR_EE		equ     (1<<15)		#/* External Interrupt enable */
MSR_PR		equ     (1<<14)		#/* Supervisor/User privelege */
MSR_FP		equ     (1<<13)		#/* Floating Point enable */
MSR_ME		equ     (1<<12)		#/* Machine Check enable */
MSR_FE0		equ     (1<<11)		#/* Floating Exception mode 0 */
MSR_SE		equ     (1<<10)		#/* Single Step */
MSR_BE		equ     (1<<9)		#/* Branch Trace */
MSR_FE1		equ     (1<<8)		#/* Floating Exception mode 1 */
MSR_IP		equ     (1<<6)		#/* Exception prefix 0x000/0xFFF */
MSR_IR		equ     (1<<5)		#/* Instruction MMU enable */
MSR_DR		equ     (1<<4)		#/* Data MMU enable */
MSR_RI		equ     (1<<1)		#/* Recoverable Exception */
MSR_LE		equ     (1<<0)		#/* Little-Endian enable */
MSR_FPx		equ		MSR_FP|MSR_FE0|MSR_FE1
MSR_USER	equ		MSR_ME|MSR_PR|MSR_EE|MSR_IR|MSR_DR
# dds Equates
MSR_L1		equ		MSR_ME|MSR_IR|MSR_DR|MSR_RI	#Reenable translation and take Machine Checks
#/* Bit encodings for Hardware Implementation Register (HID0) */
HID0_EMCP	equ     (1<<31)		#/* Enable Machine Check pin */
HID0_EBA	equ     (1<<29)		#/* Enable Bus Address Parity */
HID0_EBD	equ     (1<<28)		#/* Enable Bus Data Parity */
HID0_SBCLK	equ     (1<<27)
HID0_EICE	equ     (1<<26)
HID0_ECLK	equ     (1<<25)
HID0_PAR	equ     (1<<24)
HID0_DOZE	equ     (1<<23)
HID0_NAP	equ     (1<<22)
HID0_SLEEP	equ     (1<<21)
HID0_DPM	equ     (1<<20)
HID0_ICE	equ     (1<<15)		#/* Instruction Cache Enable */
HID0_DCE	equ     (1<<14)		#/* Data Cache Enable */
HID0_ILOCK	equ     (1<<13)		#/* Instruction Cache Lock */
HID0_DLOCK	equ     (1<<12)		#/* Data Cache Lock */
HID0_ICFI	equ     (1<<11)		#/* Instruction Cache Flash Invalidate */
HID0_DCI	equ     (1<<10)		#/* Data Cache Invalidate */
bootData		record
clientHandler	ds.l	1
iStack			ds.l	1
iStart			ds.l	1
iSize			ds.l	1
dStart			ds.l	1
dSize			ds.l	1
fpSaveOffset	ds.l	1
				endr
timebaseData	record
nextTickH		ds.l	1
nextTickL		ds.l	1
tickCount		ds.l	1
				endr
saveArea		record
SavedSP			ds.l	1
SavedCR			ds.l	1
SavedLR			ds.l	1
				ds.l	2
SavedRTOC		ds.l	1
				endr
RschedControl	record
<<<<<<<<<<<<<<<<<<< STUFF REMOVED >>>>>>>>>>>>>>>>>>>>>>>				endr
RtileRegs		record
# end
Here is rtems/cpu_asm.s
#  rtems/cpu_asm.s
#  This file contains all assembly code for the Flavors PPC 604 implementation
#  of RTEMS.
#  based on: cpu_asm.s (for m68k) which is...
#  COPYRIGHT (c) 1989, 1990, 1991, 1992, 1993, 1994.
#  On-Line Applications Research Corporation (OAR).
#  All rights assigned to U.S. Government, 1994.
#  This material may be reproduced by or for the U.S. Government pursuant
#  to the copyright license under the clause at DFARS 252.227-7013.  This
#  notice must appear in all copies of this file and its derivatives.
#  rtems/cpu_asm.s,v 1.3 1995/08/07 e
		include	'h.s'
#	Externs Data
		import	_ISR_Nest_level{RW}
		import	_Context_Switch_necessary{RW}
		import	_ISR_Signals_to_thread_executing{RW}
		import	_Thread_Dispatch_disable_level{RW}
		import	_ISR_Vector_table{RW}
		import	._Thread_Dispatch{PR}
		import	_Thread_Executing{RW}
		import	_Thread_Allocated_fp{RW}
		import	_bootData{RW}
		import	.i8042g_isr{PR}
		import	.rtems_clock_tick{PR}
#	Data
		csect	_timebaseData{RW}
		export	_timebaseData{RW}
		dc.l	0
		dc.l	0
		dc.l	0
#	TOC Data
		csect	__ISR_Root{TD}
		export	__ISR_Root{TD}
		dc.l	0
		csect	__ISR_FPU_Owner{TD}
		export	__ISR_FPU_Owner{TD}
		dc.l	0
#	TOC entries
		toc
#		tc		__ISR_Root{TC},0
#		tc		__ISR_FPU_Owner{TC},0
		tc		_ISR_Nest_level{TC},_ISR_Nest_level{RW}
		tc		_Context_Switch_necessary{TC},_Context_Switch_necessary{RW}
		tc		_ISR_Signals_to_thread_executing{TC},_ISR_Signals_to_thread_executing{RW}
		tc		_Thread_Dispatch_disable_level{TC},_Thread_Dispatch_disable_level{RW}
		tc		_ISR_Vector_table{TC},_ISR_Vector_table{RW}
		tc		_Thread_Executing{TC},_Thread_Executing{RW}
		tc		_Thread_Allocated_fp{TC},_Thread_Allocated_fp{RW}
		tc		_bootData{TC},_bootData{RW}
		tc		_Context_Enter{TC},_Context_Enter{PR}
		tc		_timebaseData{TC},_timebaseData{RW}
#	Constants
# Interrupt Handler Conventions
#  This routine provides the RTEMS interrupt management.
#  It assumes the interrupt handlers do their own FPU save/restore if needed.  NOT! -dds 20001011
# SPRG0 -- Register save area
# SPRG1 -- <<<<<<<<<<<<<<<<<<< STUFF REMOVED >>>>>>>>>>>>>>>>>>>>>>>
# SPRG2 -- RTOC of this code
# SPRG3 -- Register save area
# Interrupt Request Frame
#  00: SP at entry
#  20: RTOC at entry
#  24: R0,R3-R12 at entry
#  68: CR at entry
#  72: LR at entry
#  76: CTR at entry
#  80: XER at entry
#  84: SRR0 at entry
#  88: SRR1 at entry
#  92: R27-R31
# 112: end of irq stack frame, start of red zone, 224 bytes
IRQ_FSIZE	equ		336			#IRQ Frame Size
IRQ_RTOC	equ		20
IRQ_R0		equ		24
IRQ_R3		equ		(IRQ_R0+4)
IRQ_R4		equ		(IRQ_R0+8)
IRQ_R5		equ		(IRQ_R0+12)
IRQ_R6		equ		(IRQ_R0+16)
IRQ_R7		equ		(IRQ_R0+20)
IRQ_R8		equ		(IRQ_R0+24)
IRQ_R9		equ		(IRQ_R0+28)
IRQ_R10		equ		(IRQ_R0+32)
IRQ_R11		equ		(IRQ_R0+36)
IRQ_R12		equ		(IRQ_R0+40)
IRQ_CR		equ		(IRQ_R0+44)
IRQ_LR		equ		(IRQ_R0+48)
IRQ_CTR		equ		(IRQ_R0+52)
IRQ_XER		equ		(IRQ_R0+56)
IRQ_SRR0	equ		(IRQ_R0+60)
IRQ_SRR1	equ		(IRQ_R0+64)
IRQ_R27		equ		(IRQ_R0+68)
# Interrupt Service Frame
#  00: Saved SP
#  24: Parameter area for 2 args
#  32: Saved IRQ Root frame pointer
#  36: Frame valid flag
#  40: Saved FPSCR
#  48: FPR0-FPR13
# FPSCR Initial Value
FPSCR_INIT	equ		0
ISR_FSIZE	equ		160			#ISR Frame Size
ISR_RTOC	equ		20
ISR_ROOT	equ		32
ISR_FRVALID	equ		36
ISR_FPSCR	equ		40
ISR_FPSCRW	equ		(ISR_FPSCR+4)
ISR_FRBASE	equ		48
ISR_FR0		equ		0
ISR_FR1		equ		8
ISR_FR2		equ		16
ISR_FR3		equ		24
ISR_FR4		equ		32
ISR_FR5		equ		40
ISR_FR6		equ		48
ISR_FR7		equ		56
ISR_FR8		equ		64
ISR_FR9		equ		72
ISR_FR10	equ		80
ISR_FR11	equ		88
ISR_FR12	equ		96
ISR_FR13	equ		104
#	External Interrupt Handler (0x500) Level 0
#	We invoke the ISR with Interrupts Disabled since the EOI has NOT been issued
#	to the Interrupt Controller(s).  If the interrupt is secondary then the EOI
#	should be issued to the primary controller ASAP, though not absolutely required.
#	(It is OK to be interrupted by higher priority primaries before enabling
#	necessarily lower priority secondaries.)
		csect	_EE_Handler{RW}
		export	_EE_Handler{RW}
		# EE Handler
		dc.l	_L0_EE_Handler{PR}
		dc.l	(_L0_EE_Handler_End - _L0_EE_Handler{PR}) >> 2
		dc.l	0x0500
		dc.l	1
		dc.l	(_L0_EE_Handler_LISORI - _L0_EE_Handler{PR}) >> 1
		dc.l	_L1_EE_Handler{PR}
		csect	_L0_EE_Handler{PR}
		export	_L0_EE_Handler{PR}
		# Save R2 and establish addressability
		mtsprg	3,r2
		mtsprg	0,r0
		mfcr	r0
		mfsprg	r2,1			#<<<<<<<<<<<<<<<<<<< STUFF REMOVED >>>>>>>>>>>>>>>>>>>>>>>
		cmplwi	r2,0
		bne-	_L0_EE_Handler_Spurious
		#mfmsr	r2
		#ori		r2,r2,MSR_ME #Don't |MSR_DR	#Go virtual on Data
		#mtmsr	r2
		#isync
		mfsprg	r2,2			#Get RTOC
		# Save Volatile Registers
		stwu    SP,-IRQ_FSIZE(SP)	#Make a new IRQ frame
		stw		r0,IRQ_CR(SP)
		stw		r3,IRQ_R3(SP)
		stw		r4,IRQ_R4(SP)
		stw		r5,IRQ_R5(SP)
		stw		r6,IRQ_R6(SP)
		stw		r7,IRQ_R7(SP)
		stw		r8,IRQ_R8(SP)
		mfsprg	r3,3
		stw		r9,IRQ_R9(SP)
		mfsprg	r0,0
		stw		r10,IRQ_R10(SP)
		mflr	r4
		stw		r11,IRQ_R11(SP)
		mfctr	r5
		stw		r12,IRQ_R12(SP)
		mfxer   r6
		stw		r3,IRQ_RTOC(SP)
 		mfsrr0	r7
		stw		r0,IRQ_R0(SP)
		mfsrr1	r8
		stw		r4,IRQ_LR(SP)
		stw		r5,IRQ_CTR(SP)
		ori		r8,r8,MSR_FP
		stw		r6,IRQ_XER(SP)
		xori	r8,r8,MSR_FP
		stw		r7,IRQ_SRR0(SP)
		stw		r8,IRQ_SRR1(SP)
		stmw	r27,IRQ_R27(SP)
		# Make Int Frame
        lwz     r31,_bootData{TC}(RTOC)
		with	bootData
		lwz		r3,__ISR_Root{TD}(RTOC)	#Get IRQ Root frame pointer
		mr		r4,SP
		cmplwi	r3,0
		bne		@0
		lwz		r4,iStack(r31)		#Get IRQ stack pointer
@0:		stwu    SP,-ISR_FSIZE(r4)	#Make a new ISR frame
		mr		SP,r4
		li		r0,0
		li		r4,FPSCR_INIT
		stw		r3,ISR_ROOT(SP)		#Link ISR roots
		stw		SP,__ISR_Root{TD}(RTOC)
		stw		r0,ISR_FRVALID(SP)	#Mark FPR save area invalid
		stw		r4,ISR_FPSCRW(SP)	# and init FPSCR word
		# Return up to L1
		mfmsr	r0				#Get Int MSR
		ori		r0,r0,MSR_L1	#Level 1 MSR
_L0_EE_Handler_LISORI:
		lis		r3,0
		ori		r3,r3,0
		mtsrr1	r0
		mtsrr0	r3
		rfi						#Transfer to Level 1
_L0_EE_Handler_Spurious:
		mtcr	r0
		mfsprg	r0,0
		mfsprg	r2,3			#Restore R2
		rfi						#Ignore
_L0_EE_Handler_End:
		endwith
#	External Interrupt Handler (0x500) Level 1
		csect	_L1_EE_Handler{PR}
		export	_L1_EE_Handler{PR}
		# Establish addressability
		lis		r3,0xbfff		#Intack Space
		ori		r3,r3,0xfff0
		lwz		r31,_Thread_Dispatch_disable_level{TC}(RTOC)
		lwz		r30,_ISR_Nest_level{TC}(RTOC)
		lwz		r5,_ISR_Vector_table{TC}(RTOC)
		# Get Interrupt Vector
		lbz		r3,0(r3)
		# mfmsr	r0
		lwz		r29,0(r31)
		slwi	r4,r3,2			#Scale interrupt vector
		addi	r7,r29,1
		lwz		r28,0(r30)
		# ori		r0,r0,MSR_EE
		addi	r6,r28,1
		stw		r7,0(r31)		#++_Thread_Dispatch_disable_level
		stw		r6,0(r30)		#++_ISR_Nest_level
		# Enable Interrupts NOT
		# mtmsr	r0
		# Index through vector and call
		lwzx	r12,r4,r5		# the fcn ptr
		lwz		r0,0(r12)		# the code ptr
		stw		RTOC,ISR_RTOC(SP)	# save TOC
		mtctr	r0				# code ptr to CTR
		lwz		RTOC,4(r12)		# new TOC
		bctrl					# BRANCH and LINK to ISR
		lwz		RTOC,ISR_RTOC(SP)	# restore TOC
		# Returned from ISR, Disable Interrupts
		mfmsr	r0
		ori		r0,r0,MSR_EE|MSR_FP
		xori	r0,r0,MSR_EE|MSR_FP
		mtmsr	r0
		# Unlink ISR_ROOT, and invalidate if FPU owner
DECend:		lwz		r3,ISR_ROOT(SP)
		#mfsprg	r4,0
		lwz		r4,__ISR_Root{TD}(RTOC)			#Get ISR Root frame pointer
		lwz		r5,__ISR_FPU_Owner{TD}(RTOC)
		#mfsprg	r5,1
		#mtsprg	0,r3
		stw		r3,__ISR_Root{TD}(RTOC)			#Set ISR Root frame pointer
		cmplw	r4,r5
		bne		@0
		li		r5,0
		stw		r5,__ISR_FPU_Owner{TD}(RTOC)
		#mtsprg	1,r5
		# Check nest level, and Pop Int Stack
@0:		cmplwi	r28,0			#(_ISR_Nest_level == 0) ?
		lwz		SP,0(SP)		#Pop Int stack
		stw		r29,0(r31)		#--_Thread_Dispatch_disable_level
		stw		r28,0(r30)		#--_ISR_Nest_level
		lwz		r27,IRQ_SRR1(SP)
		bne		Return_from_Nested
		cmplwi	r29,0			#(_Thread_Dispatch_disable_level == 0) ?
		lwz		r28,_Thread_Allocated_fp{TC}(RTOC)
		lwz		r29,_Thread_Executing{TC}(RTOC)
		bne		Return_from_First
		# Now how much will you pay!?
		lwz		r30,_ISR_Signals_to_thread_executing{TC}(RTOC)
		lwz		r31,_Context_Switch_necessary{TC}(RTOC)
		li		r0,0
		lwz		r3,0(r30)
		lwz		r4,0(r31)
		cmplw	r3,r0
		cmplw	cr5,r4,r0
		crand	cr0_EQ,cr0_EQ,cr5_EQ
		beq		Return_from_First
		# Need to call _Thread_Dispatch
		stw		r0,0(r30)		#N.B. RTEMS never seems to clear this!
		bl		._Thread_Dispatch{PR}
		nop
Return_from_First:
		lwz		r3,0(r28)
		lwz		r5,0(r29)
		cmplw	r3,r5
		ori		r27,r27,MSR_FP
Return_from_Nested:
		mfmsr	r28
		ori		r28,r28,MSR_RI|MSR_IR|MSR_DR
		xori	r28,r28,MSR_RI|MSR_IR|MSR_DR
		lwz		r29,IRQ_SRR0(SP)
		lwz		r6,IRQ_XER(SP)
		lwz		r5,IRQ_CTR(SP)
		lwz		r4,IRQ_LR(SP)
		lwz		r3,IRQ_CR(SP)
		lwz		r2,IRQ_RTOC(SP)
		mtxer   r6
		lwz		r12,IRQ_R12(SP)
		mtctr	r5
		lwz		r11,IRQ_R11(SP)
		mtlr	r4
		lwz		r10,IRQ_R10(SP)
		mtcr	r3
		lwz		r9,IRQ_R9(SP)
		lwz		r8,IRQ_R8(SP)
		lwz		r7,IRQ_R7(SP)
		lwz		r6,IRQ_R6(SP)
		lwz		r5,IRQ_R5(SP)
		lwz		r4,IRQ_R4(SP)
		lwz		r3,IRQ_R3(SP)
		lwz		r0,IRQ_R0(SP)
		# Now go real and load
		mtmsr	r28
		mtsrr1	r27
 		mtsrr0	r29
		lmw		r27,IRQ_R27(SP)
		lwz		SP,0(SP)
		rfi
#	FP Unavailable Handler (0x800) Level 0
#	N.B. ASR's MAY NOT safely use FP, due to limitations imposed by the
#	EE Handler, and related elements of asynchronous calls to the ASR.
#	One solution to this is to link FP_Contexts in EE frames.
#	If ( <In_an_ISR> )
#		if ( <ISR_doesn't_own_FP> )
#			if ( <Some_Other_ISR_Owns_FP> )
#				Save_ISR_Context( <Other_ISR_Context> );
#			else If (_Thread_Allocated_fp != NULL)
#				Save_Context( _Thread_Allocated_fp );
#				_Thread_Allocated_fp = NULL;
#			Restore_ISR_Context( <This_ISR_Context> );
#			<ISR_owns_FP>
#	else If (_Thread_Allocated_fp != _Thread_Executing)
#		If (_Thread_Allocated_fp != NULL)
#		_Thread_Allocated_fp = _Thread_Executing;
#		Restore_Context( _Thread_Allocated_fp );
		# Handle <ISR_owns_FP> at Level 0 (Total Instruction budget 61)
		# 21 instructions budgeted for the <ISR_owns_FP> case.
		csect	_FPU_Handler{RW}
		export	_FPU_Handler{RW}
		dc.l	_L0_FPU_Handler{PR}
		dc.l	(_L0_FPU_Handler_End - _L0_FPU_Handler{PR}) >> 2
		dc.l	0x0800
		dc.l	2
		dc.l	(_L0_FPU_Thread - _L0_FPU_Handler{PR}) >> 1
		dc.l	_L1_FPU_Thread
		dc.l	(_L0_FPU_ISR - _L0_FPU_Handler{PR}) >> 1
		dc.l	_L1_FPU_ISR
		# FPU Handler
		csect	_L0_FPU_Handler{PR}
		export	_L0_FPU_Handler{PR}
		mtsprg	3,r2
		mfsrr1	r2				#Get MSR
		ori		r2,r2,MSR_FP
		mtsrr1	r2				# and mark FPAvailable
		#li		r2,0x8f4		#Our temp save area
		mfsprg	r2,2			#RTOC
		stw		r0,0x8f4(0)
		stw		r3,0x8f8(0)
		mfcr	r0
		stw		r4,0x8fc(0)
		# See how we got here
		mfsprg	RTOC,2
		lwz		r3,__ISR_Root{TD}(RTOC)			#Get ISR Root frame pointer
		cmplwi	r3,0
		beq		_L0_FPU_Thread
		lwz		r4,__ISR_FPU_Owner{TD}(RTOC)	#FPU Owner
		cmplw	r3,r4
		bne		_L0_FPU_ISR
		# Done
_L0_FPU_Done:
		mtcrf	255,r0			#Restore CR
		lwz		r0,0x8f4(0)
		lwz		r3,0x8f8(0)
		lwz		r4,0x8fc(0)
		mfsprg	r2,3
		rfi
		# Bail out to L1 (Instruction budget 40)
		# Go virtual on Data (NOT), enable FP, and move saved regs to virtual
_L0_FPU_Thread:
		lis		r4,0
		ori		r4,r4,0
		b		_L0_FPU_Crawlout
		# Bail out to L1
_L0_FPU_ISR:
		lis		r4,0
		ori		r4,r4,0
_L0_FPU_Crawlout:
		lwz		r0,0x8f4(0)		# and regs
		lwz		r3,0x8f8(0)
		mfmsr	r2
		#ori		r2,r2,MSR_ME #|MSR_DR
		#mtmsr	r2				#Go virtual
		#isync
		stw		r0,IRQ_R0(SP)	#Save Volatile Registers
		lwz		r0,0x8fc(0)
		stw		r3,IRQ_R3(SP)
		stw		r0,IRQ_R4(SP)
		mfsrr0	r0
		mfsrr1	r3
		stw		r0,IRQ_SRR0(SP)
		stw		r3,IRQ_SRR1(SP)
		ori		r0,r2,MSR_L1|MSR_FP
		mtsrr0	r4
		mfsprg	r2,3
		mtsrr1	r0
_L0_FPU_Handler_End:
#	FP Unavailable Handler (0x800) Level 1
#	On entry:
#		IRQ frame is allocated and linked in SP
#		R0, R3, R4, SRR0, and SRR1 are saved
		csect	_L1_FPU_Handler{PR}
		export	_L1_FPU_Handler{PR}
_L1_FPU_ISR:
		mfsprg	r4,2			#TOC
		stw		r5,IRQ_R5(SP)
		mfcr	r0
		mflr	r3
		lwz		r5,__ISR_Root{TD}(r4)			#Get ISR Root frame pointer
		lwz		r4,__ISR_FPU_Owner{TD}(r4)
		#mfsprg	r4,1			#FP Owner
		#mfsprg	r5,0			#IRQ Root
		cmplwi	r4,0
		bne		@3
		bl		_L1_FPU_UnAllocated_P
		beq		@2
		# Save Thread FP Context
		bl		_L1__FPU_Save
		li		r8,0			#NULL
		stw		r8,0(r7)		#=>_Thread_Allocated_fp
		# Restore registers and go to load
@2:		lwz		r6,IRQ_R6(SP)
		lwz		r7,IRQ_R7(SP)
		lwz		r8,IRQ_R8(SP)
		lwz		RTOC,IRQ_RTOC(SP)
		b		@4
		# Save ISR FP Context
@3:		addi	r4,r4,ISR_FRBASE
		bl		_L1__FPU_Save_Volatile
		mffs	fp0				#Get FPSCR
		stfd	fp0,ISR_FPSCR-ISR_FRBASE(r4)	# and save
		stw		r4,ISR_FRVALID-ISR_FRBASE(r4)	# and mark FPR's valid
		# Restore ISR FP Context
@4:		mfsprg	r4,2			#TOC
		#mtsprg	1,r5			#IRQ Root is now FPU Owner
		stw		r5,__ISR_FPU_Owner{TD}(r4)	#IRQ Root is now FPU Owner
		lwz		r4,ISR_FRVALID(r5)	#Get FPR valid flag
		lfd		fp13,ISR_FPSCR(r5)
		cmplwi	r4,0			#Test valid flag
		mtfsf	255,fp13		#Restore FPSCR
		beq		_L1_FPU_Done	#Done
		addi	r4,r5,ISR_FRBASE
		bl		_L1__FPU_Restore_Volatile
		b		_L1_FPU_Done
_L1_FPU_Thread:
		stw		r5,IRQ_R5(SP)
		mfcr	r0
		mflr	r3
		lwz		r5,_Thread_Executing{TC}(RTOC)
		lwz		r5,0(r5)
		beq		@6
		bl		_L1__FPU_Save
		# Restore Thread FP Context
@6:		lwzx	r4,r5,r6
		bl		_L1__FPU_Restore
		stw		r5,0(r7)		#=>_Thread_Allocated_fp
		lwz		r6,IRQ_R6(SP)
		lwz		r7,IRQ_R7(SP)
		lwz		r8,IRQ_R8(SP)
		# Done
_L1_FPU_Done:
		mtlr	r3				# and LR
		mfmsr	r0
		lwz		r4,IRQ_SRR0(SP)
		lwz		r5,IRQ_SRR1(SP)
		ori		r0,r0,MSR_RI|MSR_IR|MSR_DR
		xori	r0,r0,MSR_RI|MSR_IR|MSR_DR
		lwz		r3,IRQ_R3(SP)
		mtmsr	r0
		mtsrr0	r4
		mtsrr1	r5
		lwz		r0,IRQ_R0(SP)
		lwz		r4,IRQ_R4(SP)
		lwz		r5,IRQ_R5(SP)
		lwz		SP,0(SP)
		rfi
		# Save RTOC, R6-R8
		#  Init RTOC
		#  Get fpSaveOffset -> R6
		#  Get &_Thread_Allocated_fp -> R7
		#  Get  _Thread_Allocated_fp -> R8
		#  Get (_Thread_Allocated_fp == NULL) -> CR
_L1_FPU_UnAllocated_P:
		stw		RTOC,IRQ_RTOC(SP)
		stw		r6,IRQ_R6(SP)
		stw		r7,IRQ_R7(SP)
		mfsprg	RTOC,2
		stw		r8,IRQ_R8(SP)
        lwz     r6,_bootData{TC}(RTOC)
		lwz		r7,_Thread_Allocated_fp{TC}(RTOC)
		with	bootData
		lwz		r6,fpSaveOffset(r6)
		endwith
		lwz		r8,0(r7)
		cmplwi	r8,0
		blr
		# Store full FP Context at r6(r8)
_L1__FPU_Save:
		lwzx	r4,r8,r6
_FPU_Save_Context:
		stfd	fp14,112(r4)	#Save fp14-fp31
		stfd	fp15,120(r4)
		stfd	fp16,128(r4)
		stfd	fp17,136(r4)
		stfd	fp18,144(r4)
		stfd	fp19,152(r4)
		stfd	fp20,160(r4)
		stfd	fp21,168(r4)
		stfd	fp22,176(r4)
		mffs	fp14			#Get FPSCR FP14 Munged!
		stfd	fp23,184(r4)
		stfd	fp24,192(r4)
		stfd	fp25,200(r4)
		stfd	fp26,208(r4)
		stfd	fp27,216(r4)
		stfd	fp28,224(r4)
		stfd	fp29,232(r4)
		stfd	fp30,240(r4)
		stfd	fp31,248(r4)
		stfd	fp14,256(r4)	#Save FPSCR
		# Store volatile FP Context at r4
_L1__FPU_Save_Volatile:
		stfd	fp0,0(r4)		#Save fp0-fp13
		stfd	fp1,8(r4)
		stfd	fp2,16(r4)
		stfd	fp3,24(r4)
		stfd	fp4,32(r4)
		stfd	fp5,40(r4)
		stfd	fp6,48(r4)
		stfd	fp7,56(r4)
		stfd	fp8,64(r4)
		stfd	fp9,72(r4)
		stfd	fp10,80(r4)
		stfd	fp11,88(r4)
		stfd	fp12,96(r4)
		stfd	fp13,104(r4)
		blr
		# Restore full FP Context from r4
_L1__FPU_Restore:
_FPU_Restore_Context:
		lfd		fp31,256(r4)	#Get FPSCR
		lfd		fp14,112(r4)	#Restore fp14-fp31
		lfd		fp15,120(r4)
		lfd		fp16,128(r4)
		lfd		fp17,136(r4)
		lfd		fp18,144(r4)
		lfd		fp19,152(r4)
		lfd		fp20,160(r4)
		lfd		fp21,168(r4)
		lfd		fp22,176(r4)
		mtfsf	255,fp31		#Restore FPSCR
		lfd		fp23,184(r4)
		lfd		fp24,192(r4)
		lfd		fp25,200(r4)
		lfd		fp26,208(r4)
		lfd		fp27,216(r4)
		lfd		fp28,224(r4)
		lfd		fp29,232(r4)
		lfd		fp30,240(r4)
		lfd		fp31,248(r4)
		# Restore volatile FP Context from r4
_L1__FPU_Restore_Volatile:
		lfd		fp0,0(r4)		#Restore fp0-fp13
		lfd		fp1,8(r4)
		lfd		fp2,16(r4)
		lfd		fp3,24(r4)
		lfd		fp4,32(r4)
		lfd		fp5,40(r4)
		lfd		fp6,48(r4)
		lfd		fp7,56(r4)
		lfd		fp8,64(r4)
		lfd		fp9,72(r4)
		lfd		fp10,80(r4)
		lfd		fp11,88(r4)
		lfd		fp12,96(r4)
		lfd		fp13,104(r4)
		blr
#	Decrementer Interrupt Handler (0x900) Level 0
#	We invoke the ISR with Interrupts Enabled but the EOI has NOT been issued
		csect	_DEC_Handler{RW}
		export	_DEC_Handler{RW}
		# DEC Handler
		dc.l	_L0_DEC_Handler{PR}
		dc.l	(_L0_DEC_Handler_End - _L0_DEC_Handler{PR}) >> 2
		dc.l	0x0900
		dc.l	1
		dc.l	(_L0_DEC_Handler_LISORI - _L0_DEC_Handler{PR}) >> 1
		dc.l	_L1_DEC_Handler{PR}
		csect	_L0_DEC_Handler{PR}
		export	_L0_DEC_Handler{PR}
		mtsprg	3,r2
		mtsprg	0,r0
		mfcr	r0
		mfdec	r2
		cmpwi	r2,0
		bgt-	_L0_DEC_Handler_Spurious
		mfsprg	r2,1			#Get Sched reg
		cmplwi	r2,0
		bnea+	(_L0_SC_Cell_Timeout-_L0_SC_Handler{PR})+0xc00
		#mfmsr	r2
		#mtmsr	r2
		#isync Used to Isync after going virtual
		stw		r0,IRQ_CR(SP)
		stw		r3,IRQ_R3(SP)
		stw		r4,IRQ_R4(SP)
		stw		r5,IRQ_R5(SP)
		stw		r6,IRQ_R6(SP)
		stw		r7,IRQ_R7(SP)
		stw		r8,IRQ_R8(SP)
		mfsprg	r3,3
		stw		r9,IRQ_R9(SP)
		mfsprg	r0,0
		stw		r10,IRQ_R10(SP)
		mflr	r4
		stw		r11,IRQ_R11(SP)
		mfctr	r5
		stw		r12,IRQ_R12(SP)
		mfxer   r6
		stw		r3,IRQ_RTOC(SP)
 		mfsrr0	r7
		stw		r0,IRQ_R0(SP)
		mfsrr1	r8
		stw		r4,IRQ_LR(SP)
		stw		r5,IRQ_CTR(SP)
		ori		r8,r8,MSR_FP
		stw		r6,IRQ_XER(SP)
		xori	r8,r8,MSR_FP
		stw		r7,IRQ_SRR0(SP)
		stw		r8,IRQ_SRR1(SP)
		# Make Int Frame
		with	bootData
		mr		r4,SP
		cmplwi	r3,0
		bne		@1
@1:		stwu    SP,-ISR_FSIZE(r4)	#Make a new ISR frame
		mr		SP,r4
		li		r0,0
		li		r4,FPSCR_INIT
		# Return up to L1
_L0_DEC_Handler_LISORI:
		lis		r3,0
		ori		r3,r3,0
		mtsrr1	r0
		mtsrr0	r3
_L0_DEC_Handler_Spurious:
		mtcr	r0
		mfsprg	r0,0
		rfi						#Ignore
_L0_DEC_Handler_End:
		endwith
#	Decrementer Interrupt Handler (0x900) Level 1
		csect	_L1_DEC_Handler{PR}
		export	_L1_DEC_Handler{PR}
        lwz     r27,_timebaseData{TC}(RTOC)
		with	timebaseData
		mfmsr	r0
		lwz		r29,0(r31)
		lwz		r28,0(r30)
		addi	r7,r29,1
		addi	r6,r28,1
		ori		r0,r0,MSR_EE
		# Enable Interrupts and call rtems_clock_tick()
@0:		mtmsr	r0
		bl		.i8042g_isr{PR}
		bl		.rtems_clock_tick{PR}
		mfmsr	r0
		mtmsr	r0
		# Update _timebaseData
		lwz		r3,tickCount(r27)	#Get data
		lwz		r8,nextTickL(r27)
		lwz		r7,nextTickH(r27)
		ori		r0,r0,MSR_EE
@1:		mftbu	r4				#Get current TB value
		mftb	r5
		mftbu	r6
		cmpw	r4,r6
		bne-	@1
		addc	r8,r8,r3		#Compute time of next tick
		addze	r7,r7
		stw		r8,nextTickL(r27)	# and save it
		cmplw	r7,r4
		stw		r7,nextTickH(r27)
		blt-	@0				#Next tick has passed
		bne-	@2
		cmplw	r8,r5
		ble-	@0				#Next tick has passed
@2:		subf	r6,r5,r8		#Count to next tick
		cmplwi	r6,250			#1000-1500 instructions
		blt		@0				#Tick early
		mtdec	r6
		b		DECend
		endwith
#	System Call (0xc00) Level 0
#   Exactly 64 words (max.) -dds 96-02-15
#	Because the FP bit can be modified at any time due to an enabled
#	External Exception, it is necessary that MFMSR/MTMSR used to clear
#	the EE bit be atomic. To satisfy this we use the System Call Exception
#	The protocol is:
#		Bit 31 of R3 is inserted into MSR( EE ), Bits 0-30 of R3 must be zero.
#		Previous MSR( EE ) is returned in Bit 31 of R3, Bits 0-30 of R3 are cleared.
#		R4 and R5 are destroyed.
#  0,1 - Bit to EE
		csect	_SC_Handler{RW}
		export	_SC_Handler{RW}
		# SC Handler
		dc.l	_L0_SC_Handler{PR}
		dc.l	(_L0_SC_Handler_End - _L0_SC_Handler{PR}) >> 2
		dc.l	0x0c00
		dc.l	2
		dc.l	(_L0_SC_Cell_Done_LISORI - _L0_SC_Handler{PR}) >> 1
		dc.l	_L1_CS_Done
		dc.l	(_L0_SC_Cell_Timeout_LISORI - _L0_SC_Handler{PR}) >> 1
		dc.l	_L1_CS_Timeout
		csect	_L0_SC_Handler{PR}
		export	_L0_SC_Handler{PR}
		cmplwi	r3,1
		bgt-	_L0_SC_Cell
		mfsrr1	r4				#Get MSR
		extrwi	r5,r4,1,16		#Extract EE bit
		insrwi	r4,r3,1,16		#Insert new EE bit
		mtsrr1	r4				#Put MSR
		mr		r3,r5			#Copy result
		rfi						#Get done
#	Cell Scheduler (0xc00) Level 0
#	Cell Scheduler Level 1
		csect	_L1_CS_Handler{PR}
		export	_L1_CS_Handler{PR}
#	ITLB Miss Handler (0x1000) Level 0
#Not used
# void _CPU_Context_save_fp( void **fp_context_ptr );
# save the FP context
		csect	._CPU_Context_save_fp{PR}
		export	._CPU_Context_save_fp{PR}
		lwz     r4,0(r3)        # r3 now points to save area
		b		_FPU_Save_Context
# void _CPU_Context_restore_fp( void **fp_context_ptr );
# restore the FP context
		csect	._CPU_Context_restore_fp{PR}
		export	._CPU_Context_restore_fp{PR}
		b		_FPU_Restore_Context
# void _CPU_Context_save_nvfp( void **fp_context_ptr );
# save the non-volatile FP context
		csect	._CPU_Context_save_nvfp{PR}
		export	._CPU_Context_save_nvfp{PR}
		stfd	fp14,112(r3)	#Save fp14-fp31
		stfd	fp15,120(r3)
		stfd	fp16,128(r3)
		stfd	fp17,136(r3)
		stfd	fp18,144(r3)
		stfd	fp19,152(r3)
		stfd	fp20,160(r3)
		stfd	fp21,168(r3)
		stfd	fp22,176(r3)
		stfd	fp23,184(r3)
		stfd	fp24,192(r3)
		stfd	fp25,200(r3)
		stfd	fp26,208(r3)
		stfd	fp27,216(r3)
		stfd	fp28,224(r3)
		stfd	fp29,232(r3)
		stfd	fp30,240(r3)
		stfd	fp31,248(r3)
		stfd	fp14,256(r3)	#Save FPSCR
		blr
# void _CPU_initTimebase( milliseconds, ftimebase, mu_s_per_tick );
#	milliseconds	-- ... since OF startup
#	ftimebase		-- timebase frequency in Hz
#	mu_s_per_tick	-- microseconds per tick
# It is probable that the TB has been initialized by OF, but we
# redo it here.
# Initialize the Decrementer and _timebaseData.
# First tick is usually pending.
# To compute counts_per_tick, with minimal roundoff error
# we use: floor((ftimebase * mu_s_per_tick) / 1000000)
# We use 48 bits for the intermediate results. -dds
		csect	._CPU_initTimebase{PR}
		export	._CPU_initTimebase{PR}
		li		r7,1000
		li		r6,2
		divwu	r9,r4,r7		#Counts per millisecond
		li		r8,0
		mulhwu	r10,r9,r3		#High time
		mullw	r11,r9,r3		#Low time
		mttb	r8				#Init TB
		mtctr	r6
        lwz     r3,_timebaseData{TC}(RTOC)
		with	timebaseData
		mttbu	r10
		mttb	r11
		lis		r9,0x7fff		#Nearly most positive count
		mulhwu	r10,r4,r5		#f*p high
		mullw	r11,r4,r5		#f*p low
@0:		slwi	r6,r10,16		#Get the high 32 bits of 48
		inslwi	r6,r11,16,16	# into r6
		divwu	r10,r6,r7		#r10 = Q
		mullw	r8,r10,r7
		subf	r8,r8,r6		#r8 = R
		insrwi	r11,r8,16,0		#Insert remainder
		divwu	r11,r11,r7
		insrwi	r11,r10,16,0
		srwi	r10,r10,16
		bdnz	@0
		stw		r11,tickCount(r3)
@1:		mftbu	r4
		mftb	r5
		mftbu	r6
		cmpw	r4,r6
		mtdec	r11
		bne-	@1
		addc	r5,r5,r11
		addze	r4,r4
		stw		r5,nextTickL(r3)
		stw		r4,nextTickH(r3)
		endwith
		blr
# void _CPU_Context_switch( Context_Control *run, Context_Control *heir );
#	This routine performs a normal non-FP context switch.
# void _CPU_Context_restore( Context_Control *new_context );
#	This routine is generally used only to restart self in an efficient manner.
#	It is very similar to the second half of _CPU_Context_switch
#	It IS the second half of _CPU_Context_switch -dds
		csect	._CPU_Context_switch{PR}
		export	._CPU_Context_switch{PR}
		mr		r6,r3
		mr		r7,r4
		li		r3,0
		sc
		stw		r3,92(r6)
		mflr	r8
		mfcr	r4
		stw		SP,0(r6)		#	save SP
		stw		r4,4(r6)		#	save CR
		stw		r8,8(r6)		#	save LR
		stw		RTOC,12(r6)		#	save RTOC
		stmw	r13,16(r6)		#	save r13-r31
		b		_rest
._CPU_Context_restore:
		mr		r7,r3
		li		r3,0
		sc
_rest:	lwarx	SP,0,r7			#	restore SP
		stwcx.	SP,0,r7
		lwz		r6,4(r7)
		lwz		r5,8(r7)
		lwz		r3,92(r7)
		mfmsr	r4
		mtcrf	255,r6			#	restore CR
		mtlr	r5				#	restore LR
		mtmsr	r4				#Put MSR
		lwz		RTOC,12(r7)		#	restore RTOC
		lmw		r13,16(r7)		#	restore r13-r31
		lwz		r3,_Thread_Allocated_fp{TC}(RTOC)
		lwz		r4,_Thread_Executing{TC}(RTOC)
		lwz		r3,0(r3)
		lwz		r4,0(r4)
		cmplw	r3,r4
		beq		@1
		blr
@1:		mfmsr	r0
		ori		r0,r0,MSR_FP
		mtmsr	r0
		blr
# void _CPU_Context_Initialize( _the_context, _stack_base, _size, _isr, _entry_point )
		csect	._CPU_Context_Initialize{PR}
		export	._CPU_Context_Initialize{PR}
		lwz		r8,_Context_Enter{TC}(RTOC)
		add		r4,r4,r5
		li		r5,0
		stw		r5,4(r3)		#Init CR
		subi	r4,r4,32
		stw		r8,8(r3)		#Init LR
		stw		RTOC,12(r3)
		stw		r4,0(r3)
		subfic	r5,r6,1			#_isr -> EE
		stw		r5,92(r3)		#EE
		stw		r7,16(r3)
		blr
		csect	_Context_Enter{PR}
		li		r4,0
		lwz		r0,0(r13)		#_entry_point code ptr
		mtlr	r4				#Never come back
		lwz		RTOC,4(r13)		# new TOC
		bctr					# BRANCH to ISR
# end of rtems/cpu_asm.c
