Gnu debugger does not recognise the commands "setrpcmode sun" ...
Antti P Miettinen
antti.p.miettinen at nokia.com
Thu Oct 12 13:12:43 UTC 2000
> I tried now to build the gdb by using the patch (according to the rtems
> manual: bit_gdb i386).
> But the debugger that was build (the name of the exec file is
> i386-rtemsgdb and not i386-RTEMS-gdb) is still not recognising the
> setrpcmode, setdaemontype, target rtems.. commands.
> Do I have to build the debugger with a special option (-rtc or
> similar???).
Again, I dunno about the bit* scripts - I've just used the normal
configure scripts to configure the packages. You should be able to
configure gdb with --target=i386-RTEMS for using rdbg.
