Q powerpc new exception processing.
Eric Valette valette at crf.canon.fr
Tue Oct 24 15:00:13 UTC 2000
Sergei Organov wrote:
> > As the author of the code, I think it is time to jump in. My credo about
> > the way Exception/Interrupt handling must be coded is :
> >       - Exception are processor dependent (CPU common),
> >       - Interrupt handling is board dependent (BSP),
> Until processor is actually microcontroller that has its own PIC. In which
> case interrupt handling (at least interrupts dispatching) could be considered
> processor dependent.
Note quite true : take example of MPC860, you can physically route
interrupt on the SIU.
> Also, decrementer seems to be common to most (all?) of PowerPC processors,
> so what's the reason to mix its handling with external interrupts that indeed
> are different between processors/boards?
Because anyway interrupt are a state machine that require sharing :
	- Interrupt nesting level (in the case of PPC SRR0, SRR1),
	- not enabling interrupts in the meedle of another interrupt path were
they are disabled...
   __
  /  `                   	Eric Valette - Canon CRF
 /--   __  o _.          	Canon Development Europe Team Leader
(___, / (_(_(__         	Rue de la touche lambert
				35517 Cesson-Sevigne  Cedex
				FRANCE
Tel: +33 (0)2 99 87 68 91	Fax: +33 (0)2 99 84 11 30
E-mail: valette at crf.canon.fr	http://www.crf.canon.fr
