FW: PPP & TCP/IP networking
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Oct 25 14:58:56 UTC 2000
Nick.SIMON at syntegra.bt.co.uk wrote:
> You are enabling networking, obviously. With --enable-networking in
> configure. You'll
> also need --enable-posix.
This is dead on correct. The webserver requires the POSIX interface
to be enabled. Also if you don't enable POSIX, then you will be
missing some header files that would likely give you the undefineds.
> -- Nick Simon
> > -----Original Message-----
> > From: Matthew J Fletcher [mailto:mfletcher at serck-controls.co.uk]
> > Sent: 25 October 2000 12:52
> > To: Nick.SIMON at syntegra.bt.co.uk
> > Subject: Re: PPP & TCP/IP networking
> > > To get your webserver in, you have to call
> > rtems_initialize_webserver.
> > > Lacking that won't stop ping working though - it's done in
> > the network
> > > stack.
> > the problem its that i get an undefined reference to
> > 'rtems_initialize_webserver'
> > at link, i expected this because when i build rtmes the
> > webserver directory
> > is empty,
> > i.e it has not been linked into librtemsall.a.
> > I was hoping i had broken the config, ... is there a
> > spesific option to
> > enable the websever to be built into rtems ?
> > regards
> > Matthew J Fletcher
> > NPD Firmware
> > Serck Controls Ltd
> > Serck Controls Ltd, Rowley Drive, Coventry, CV3 4FH, UK
> > Tel: 44 (0) 24 7630 5050 Fax: 44 (0) 24 7630 2437
> > Web: www.serck-controls.co.uk Admin: post at serck-controls.co.uk
> > This email and any files transmitted with it are confidential and
> > intended solely for the use of the individual or entity to whom they
> > are addressed. If you have received this email in error please notify
> > the above. Any views or opinions presented are solely those of the
> > author and do not necessarily represent those of Serck Controls Ltd.
> > Please note that Serck Controls Ltd is able to, and reserves
> > the right
> > to, monitor e-mail communications passing through its network.
> > This email has been checked for viruses. Serck Controls Ltd
> > shall not
> > be responsible for damage caused by any undetected virus.
> the system manager.
> This footnote also confirms that this email message has been swept by
> MIMEsweeper for the presence of computer viruses.
> www.mimesweeper.com
joel at OARcorp.com On-Line Applications Research
