PPP & TCP/IP networking
Matthew J Fletcher
mfletcher at serck-controls.co.uk
Wed Oct 25 15:54:22 UTC 2000
Joel Sherrill wrote:
> It is not broken but there is a transition issue he needs to deal with.
> These constants are actually in pthread.h which has moved packages.
> pthread.h is now included in the RPMs since it is required to build
> multi-thread aware gcc support libraries. Previously it was in the
> RTEMS
> source code. You need to be on beta3a with the RPMs or tool sources
> from there. The cancel constants are there and pthread_cancel() works.
there seems to be a full version of pthread.h in my --prefix dir, i
presume i should be using that istead of the one in the posix/ dir in
rtems.
regards
Matthew J Fletcher
NPD Firmware
Serck Controls Ltd, Rowley Drive, Coventry, CV3 4FH, UK
Tel: 44 (0) 24 7630 5050 Fax: 44 (0) 24 7630 2437
Web: www.serck-controls.co.uk Admin: post at serck-controls.co.uk
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they
are addressed. If you have received this email in error please notify
the above. Any views or opinions presented are solely those of the
author and do not necessarily represent those of Serck Controls Ltd.
Please note that Serck Controls Ltd is able to, and reserves the right
to, monitor e-mail communications passing through its network.
This email has been checked for viruses. Serck Controls Ltd shall not
be responsible for damage caused by any undetected virus.
