4.0 -> 4.5
russ
russ at embedit.com.au
Tue Sep 19 01:18:19 UTC 2000
Hi,
First I'd like to say you've done a great job with the rpm's. I'm just converting from 4.0 to 4.5
and it only took me a day to get 4.5 up and running. That includes download time. Thanks!
My question has to do with building for the bare m68k. I'm sure this has been discussed previously
on the list. But I believe rtems is defaulting to 68020 command set, not 68000.
Is there a switch or parameter of the bit_rtems script or a specific makefile where the 68000
command set can be forced?
Thanks
russ
