4.0 -> 4.5
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Sep 19 13:27:39 UTC 2000
russ wrote:
> Hi,
> First I'd like to say you've done a great job with the rpm's. I'm just converting from 4.0 to 4.5
> and it only took me a day to get 4.5 up and running. That includes download time. Thanks!
> My question has to do with building for the bare m68k. I'm sure this has been discussed previously
> on the list. But I believe rtems is defaulting to 68020 command set, not 68000.
> Is there a switch or parameter of the bit_rtems script or a specific makefile where the 68000
> command set can be forced?
Are you building the bare BSP something like this?
..../rtems/configure --target=m68k-rtems \
'--enable-bare-cpu-cflags= -m68000' \
--enable-rtemsbsp="bare" \
--enable-bare-cpu-model=m68000
If you left out bare-cpu-cflags, then it would default to the
68020 as that is gcc's default.
> Thanks
> russ
joel at OARcorp.com On-Line Applications Research
