Linking application and BSP
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Sep 20 19:13:20 UTC 2000
"Michael P. Collins on korat" wrote:
> I'm trying to determine how I should link my application with my
> BSPs now that they've been updated for 4.5. All the "tests/samples"
> tasks link successfully[1], which implies that my BSPs are more-or-less
> complete.
> Using the Makefiles I created for 4.0.0 as a starting point, I've
> gotten the bugs out to the point where the final link step takes place.
> Then I see the problems described below.
> - The linker complains about "start.o" not being found. I've
> tried adding "$INSTALL_POINT/<bsp>/lib/start.o" to the list
> of linked objects, but this doesn't work. A symlink from that
> file to the local directory does work; I haven't been able to
> determine where the reference to a local "start.o" is coming
> from.
Did you do a "make install"? And did you set RTEMS_MAKEFILE_PATH to
point to the install point. If you are using RPMs, then it would
likely be something like /opt/rtems/MYBSP.
Another possibility is that you built the debug variant of
RTEMS but your bsp_specs does not quite have -qrtems_debug support.
> - With that symlink in place, the linker complains about undefined
> references to `Configuration' in bootcard.c. Using the sample
> tasks as a reference, I don't understand why this error doesn't
> occur any time the BSP is linked with an application. Conversely,
> if there isn't an unresolved reference when linking with a sample
> application, why do I see one when linking with mine? Where is
> this structure supposed to be allocated? I don't have any
> references to this structure in any of my application files.
> - There are undefined references to the following variables:
> filename undefined reference
> c/src/lib/libc/base_fs.c rtems_filesystem_mount_table_size
> c/src/lib/libc/libio.c rtems_libio_number_iops
> I presume the the last item in the list pertains to the lack of
> filesystem support for my BSP. How should I go about linking so I
> don't see those errors?
NO problem with your BSP. You are not using confdefs.h to
instantiate the configuration information. Look at the way
hello uses confdefs.h.
> As always, any suggestions are appreciated.
> -- MC --
> 1. With the exception of paranoia, which is too large to fit in
> program space for my ROM-based BSP. I asked if there was an
> elegant way to omit this task during build last week, but didn't
> see any replies. I wrote a script which applies patches to
> Makefile.in and configure, but would still like to know if
> there's a better way.
Unfortunately, none that I know of.
> mcollins at wdc.sps.mot.com
joel at OARcorp.com On-Line Applications Research
