How to create a multiple ADA task program on rtems?
guobing at sohu.com guobing at sohu.com
Sun Sep 24 06:37:37 UTC 2000
guobing at sohu.com wrote:
> Hi,all!Recently I've successfully run ADA "hello world" demo on PC386 BSP.But This >is a single task program.I want to create a multiple ADA task program on rtems.How >to implement it?Anyone can help me?Thanks.
"Joel Sherrill" <joel.sherrill at OARcorp.com> wrote:
>Nothing special.  Declare Ada tasks.  They will be elaborated when
>gnat_main is executed.
>Make sure to configure enough Ada tasks.  I think the default is 20
>though so you should
>be OK.
Thanks Sherrill.The procedure of ADA task executed on rtems is start_gnat_main -> gnat_main
-> pthread_create -> "Hello World" ADA program body.Is it right?I haven't understand how function "pthread_create" call "Hello World" ADA program body.Can you give me a
multiple ADA task program demo on rtems?Thank you.
ÏÖÔÚȥϤÄỹÓлú»á£¡£¡£¿
ÓÃÊÖ»ú¿´°ÂÔË£¬Ö»»¨Ê®ÔªÇ®µã²¥°ÂÔ˶ÌÐÅ£¬ÖÐÍòÔª°ÄÖÞºÀ»ª7ÈÕÓδ󽱡£
¼´¿ÌµÇ½ȥÖн±£ºhttp://sms.sohu.com
ËѺü£ºhttp://www.sohu.com
