compiling
russ
russ at embedit.com.au
Wed Sep 27 00:34:56 UTC 2000
Hi,
I'm still trying to convert from 4.0 bare m68k to 4.5 bare m68k. Can anyone explain why, after
m68k-rtems-gcc compiles the file to a .o then /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/cpp and
/opt/rtems/m68k-rtems/bin/as are called to do apparently the same thing? I suspect I've done
something wrong here in the makefile or a config file.
Thanks
russ
/opt/rtems/bin/m68k-rtems-gcc --pipe -B/opt/rtems//bare-m68302/lib/ -specs bsp_specs -qrtems -g
-Wall -ansi -fasm -O4 -fomit-frame-pointer -v -m68000 -c -o o-optimize/init.o init.c
Reading specs from /opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/specs
Reading specs from /opt/rtems//bare-m68302/lib/bsp_specs
m68k-rtems-gcc: unrecognized option `-qrtems'
gcc version 2.95.2 19991024 (release)
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/cpp -lang-c -std=c89 -v -isystem
/opt/rtems//bare-m68302/lib/include -D__GNUC__=2 -D__GNUC_MINOR__=95 -trigraphs -D__STRICT_ANSI__
-D__mc68000__ -D__rtems__ -D__rtems__ -D__ELF__ -D__mc68000 -D__rtems -Asystem(rtems) -Acpu(mc68000)
-Acpu(m68k) -Amachine(m68k) -D__OPTIMIZE__ -g -Wall -D__mc68000__ -D__mc68000 init.c |
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/cc1 -quiet -dumpbase init.c -m68000 -ansi -g -O4 -Wall
-version -fasm -fomit-frame-pointer -o - |
/opt/rtems/m68k-rtems/bin/as -m68000 -m68000 -o o-optimize/init.o
GNU CPP version 2.95.2 19991024 (release)GNU C version 2.95.2 19991024 (release) (m68k-rtems)
compiled by GNU C version 2.7.2.3.
(68k, Motorola syntax)
#include "..." search starts here:
#include <...> search starts here:
/opt/rtems/bare-m68302/lib/include
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/include
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../m68k-rtems/include
End of search list.
The following default directories have been omitted from the search path:
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../include/g++-3
/opt/rtems/lib/gcc-lib/m68k-rtems/2.95.2/../../../../m68k-rtems/sys-include
End of omitted list.
